Car Audio & Electronics Forum
Hi-Fi upgrades, XM Radio, Sirius, Bluetooth, and Radar Detector discussions here! |
#51
Thanks, lot of info for x5 is the same as E39 didn't know that!
Will widen my field of search next time. |
#52
To make things neat!!!
Well, after looking into Aux Input, and did some searching. YES, $31 for the OEM cable might be worth it. But the fun of this is a DIY project. So I follow this post, and some others I've found, and I found a way to make things VERY easy to make the cable.
This is the cable u'll need: http://www.frontx.com/pro/p090v1_030.html You might need to re-arrange pins to fit correctly, according to the 1st post of this thread if u have a NAV. If you do NOT have a NAV, u'll need this extra little guy: http://www.frontx.com/cpx075_9.html U'll need to re-arrange the pins and use the extra "1-pin" connector above, move yellow wire pin from the 3-set, to the "1-pin" and arrange them like this. .If you want to make things REALLY neat at the HU's connection, u can get this and use it as a harness. http://www.frontx.com/cpx075_4.html. This way, u won't need the "1-pin" little guy, just move all the 3 wires out and put it into this 10-hole "harness" and line the pins up correctly. If you want to add the capacitors and resistor into the wire, just cut the wire some where in the middle, and add them to it. A good example: ![]() Total Cost: less then $10. It's just fun for a DIY project, instead of paying $30 for the OEM cable. Then follow the DIY installation of the Aux Input cable. Last edited by noguts_78; 08-01-2007 at 03:47 PM. |
#53
you should have shown the rest of the woman that modeled that part lol
#54
(that is- those capacitors and resistors)
#55
Very nice MOD.
Does anyone have try this: http://www.bavariansoundwerks.com/pr...-X3-04---E83-/ It can display TEXT from the iPOD. Maybe it is another alternative for the iPOD adaptor from BMW. |
#56
DICE iPod Integration Kit for BMW http://www.europeanautosource.com/pr...roducts_id=268 This will give you steering wheel control, charge the iPod and provide better sound quality than the AUX adapter.
Tom G. | european auto source (eas) email: tom@europeanautosource.com web: www.europeanautosource.com tel 866.669.0705 | ca: 714.369.8524 x22 | fax: 714.908.1796 Blog | Facebook | YouTube | Flickr | Twitter |
#57
Thanks. |
#58
I have installation instructions I can send, feel free to email me directly.
#59
Anyone willing to throw in their .02 over here....I'm hoping someone has an answer.
http://www.bimmerfest.com/forums/sho...11#post4306711
New here? Please visit www.e38.org, THEN you ask questions 325hp 98 740iL, black/black - Eatin 540's & $hittin 318's PERFORMANCE:///M5 6spd conv., Iron sleeves, L/W Teflon coated pistons, 3 angle valvejob, P&P head, cams, electric fan, CF intake tube w/aluminum heatshield, Magnaflow 14816'd INTERIOR:Hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D, silver trim, 5% tint EXTERIOR:19" Beyern Mesh staggered, Shadowline kidneys, Axxis pads 01 X5 4.4 - F90BT, L5 |
#60
Bump for alternatives, besides deck replacement...
#61
soz
Guys Hi and sorry for bothering you.M English is not so good so i hope you understand me.
I cant understand all things above so i wonder something.You created one AUX or you just bought one.If someone bought one can send me the things that i need and i will pay him from paypal or tell me where to buy one.Really thanks.I am looking forward for your reply. |
#62
I've been trying to do this for the past 2 months without success. I have a 2005 (previous moodel) 320. I've shortcircuited pins 8 and 9, but still do not get the AUX on the screen when cycling the MODE button. Does this mean that it won't work with my radio? many thanks |
#63
Hey, I see the awesome work you did on making a cable yurself. They sell those for $80 plus tax (total $91) here in Canada. I want to make my own as I am also an engineer, be it Mechanical, I understand electronics enough to make the cable. My only issue is that I do not have a NAV system in my 2004 BMW 330ci and was wondering if you could tell me if your cable works for that or where I could find the differences.
Thanks for your help. |
#64
which pins do you consider to be 8 and 9?
If you look from the back of the unit, you have to be working with the ten pin gang to to bottom right and pins 8 and 9 are the 3rd and 4th pins on the top row of that 10 pin gang. May be you had the right pins but just in case!! |
#65
Well, isn't this just the slick little mod!
$5 @ Radio shack got 'r done for me. 300K resistors are hard to find but using two common 150K resistors in series works just as well. I'm using 1/8 watt versions in my "Frankencable". Also, the 4 pin mini power connectors on PC floppy drives work perfectly with the stock BMW connector supplied in the 2003 and > vehicles. Got an old PC laying around? Just unsolder the power connector from the floppy drive and use it for this mod. |
#66
So,, i want to make this cable up, but a couple of questions, in the diagram, the resistor is after the capacitor, but somebody said put it before the capacitors?
Which is it? The connector on the back of the headunit, is it 10 or 12 pin? Seen plenty of pics with 12 pin (2 rows of 6), but the diagram on page 2 says 10 pin? Thanks. Ignore my resistor question, i was reading the diagram wrong, big d'oh! Last edited by mjn; 09-03-2012 at 02:04 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| auxiliary audio input for pre 2002 540 | ppendyck | 5 Series | 9 | 01-16-2005 02:14 PM |
| Aux Audio Input: Need Part No. for E46 "Touring"?? | gordo325xiwagon | Car Audio & Electronics Forum | 7 | 08-24-2004 05:26 PM |
| Problem: Bluetooth and Auxiliary Audio Input | TLudwig | 3 Series / 4 Series | 3 | 08-05-2004 02:48 PM |
| Auxiliary Input Placement | TLudwig | 3 Series / 4 Series | 2 | 05-04-2004 06:23 AM |
| auxiliary input? | justcor | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 1 | 06-02-2003 06:02 PM |
