Buzzing/Humming noise when engine off? - Bimmerfest - BMW Forums
Old 04-16-2009, 05:59 PM
jman103099's Avatar
jman103099 jman103099 is offline
Mein Auto: f48 X1, f25 X3, e46 330ci
I am getting a buzzing or humming noise right after I turn the car off. It seems to only last 20-60 seconds. It appears to be coming from the rear passenger side of the car. I got under the car and listened, but cant pin-point where it's coming from. Not in the trunk/battery area. Maybe around the gas tank?
The problem is, it doesnt do it all the time - maybe only 2 out of 5 times I drive, then turn the car off. Any suggestions besides taking the car in (I have a feeling they wont be able to reproduce the problem). Anyone experience this?
2018 X1 (on order!)
2004 330CiC (8/15 - present)
2011 X3 28i (1/12 - present)
2011 328i (5/11 - 6/17)
2009 MINI Cooper (4/09 - 5/11)
2006 X3 (03/07 - 1/12)
1995 325i (05/06 - 3/09)
1985 325e (08/00 - 12/04)
Old 04-16-2009, 06:12 PM
Wrangler Wrangler is offline
Mein Auto: BMW X3
I hear, but failed to pin point the source. Gave up because it is sporadic.
Old 04-16-2009, 06:15 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Have it on our 2007, so I'd say it's normal.
My guess is it's the fuel pump maintaining pressure in the fuel rails. It's sporadic because it doesn't need to run all the time.
Anyways if it's a concern, take it to the dealer or give 'em a call.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 04-16-2009, 06:26 PM
Evlengr's Avatar
Evlengr Evlengr is offline
Ukemi - that's how I roll
Mein Auto: 2013 Audi S4 2010 MT MCS
Wierd I heard that tonight for the first time and was getting ready to get the VOM meter and tech test gear to track it down.
Almost sounded like a bad ground hum at first.
Thanks will see if I can pin point it, but thanks for helping to "Drill Down".
EE
2013 S4 Loaded (and NO RFT's) Awesome is an understatement
2008 MT X3 RIP you were a faithful sidekick and will be missed.
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
1997 Twin Turbo RX-7
1984 GTI Wolfsburg Edition Neuspeed and more
Old 04-16-2009, 06:52 PM
Zoltar's Avatar
Zoltar Zoltar is offline
Your Wish Is Granted
Mein Auto: 2009 X3 MT
Leak diagnostic pump.
http://www.bimmerfest.com/forums/sho...d.php?t=357167
Old 04-16-2009, 09:00 PM
Evlengr's Avatar
Ok I'll bite--what is leaking that needs diagnosis?
2007 AT X3 RIPOS
2005 GC
2000 Jeep Cherokee
Old 04-17-2009, 06:19 AM
HT417's Avatar
HT417 HT417 is offline
Mein Auto: 2008 BMW X5 3.0si
When I first noticed this over a year ago I discussed it with my SA and he said to only be concerned if it continued to run for more than 5 minutes. It hasn't yet but it's come close a couple of times.
Old 04-17-2009, 01:28 PM
x3lemon x3lemon is offline
Mein Auto: X3
I just got it today in my 2009 X3. It lasted 2 minutes or so and I pinpointed it to behind the rear passenger wheel well on the right hand side. I don't think it's normal as this is the first time I'm hearing it in 6000 miles. I'll take my car into the dealership next week.
Old 04-17-2009, 03:01 PM
Mein Auto: 2004 X3 2.5i
I'm with Zoltar - it's perfectly normal.
I have heard it occasionally over 5 years of X3 ownership.
The pump that is attached to the evaporative canister runs periodically at random times.
You will only hear it if it runs just when the engine has been turned off.
I imagine the advice about it only be a concern if it runs for longer than 5 minutes is based on a leak test not needing that much time to establish a negative or a positive.
Old 04-17-2009, 03:23 PM
540gone 540gone is offline
Mein Auto: 640 GC, Porsche Macan Tur
My 2008 that's 1 year old with 15,000 miles has done it off and on since the car was new. I have just assumed it was either the fuel pump or some sort of purging of the evaporative cannister or whatever, as no problem has developed.
I think it happens more often than most people realize, because if you just get out of the car and walk away, you never notice it.
BTW, the automatic transmission is and always has been just fine.
Old 04-17-2009, 05:45 PM
Big W Big W is offline
Mein Auto: F30 328 F25 X35, W209 AMG
I guess it's normal, my 2007 gti does the same thing, once I had a problem with the fuel pump relay and it stayed on forever
Old 04-17-2009, 06:14 PM
Snow-man Snow-man is offline
Mein Auto: 330Xi, Acura RDX, 968
Good input with the exception of the transmission comment. That has nothing to do with this thread. There is a place for that in the transmission thread.You will notice it more in cool to warmer days because of the vapors created from the temperature change.
Old 04-18-2009, 12:01 AM
jaldeborgh jaldeborgh is offline
Mein Auto: X3
Our 07 makes the same noise every once and a while - it only lasts a short time. I also assume it's normal.
John
2007 X3 3.0si - Wife's Car
2004 X3 2.5i - Daughter's Car
2003 K1200RS - Dad's Toy
2001 750 iL - Retired by me in 2005 - Great Car but wanted AWD
1995 750 iL - Retired by me in 2002 - Great Car
Old 04-19-2009, 03:22 PM
jman103099's Avatar
Wow, lots of replies! Thanks; I will also assume this is normal.
2018 X1 (on order!)
Old 09-03-2012, 03:25 PM
bmw1445 bmw1445 is offline
Mein Auto: bmw 525 2007
so i take it that buzzing sound from the right rear is normal???
