Discussion pertaining to the flagship BMW here. |
Change ignition coil and spark plugs?
Hi,
I was trying to find a DIY for changing the Ignition coils and spark plugs, but couldn't find one. Can someone point me in the right direction. Does anyone have a diagram of where the coils are located? Also, is this an easy task for someone who doesn't really work on cars, but used to change my oil and spark plugs on my previous car? Also I checked a couple websites and saw the Bosch OEM Ignition Coil with Spark Plug Connector, but also the BREMI/STI part? Which one would you guys recommend? Lastly, should I change all ignition coils or just the one that is misfiring? I am at 92k miles right now. Thanks in advance
'03 745Li |
OEM Part numbers :
http://www.realoem.com/bmw/showparts...04&hg=12&fg=05
My BMW ACS7 ![]() Last edited by TechFreak; 04-05-2010 at 05:22 PM. |
Just replace the bad one and only if it is bad. A misfire doesn't mean a bad coil.
My videos showing how to get the difficult spark plug boots out, and pictures showing the general process --> here.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... |
Well, I changed my Spark Plug and Ignition Coil on cylinder 7 (which is on the driver side) and was able to do it by just taking off the plastic engine cover. Took about 20 mins! The hardest part was getting the spark plug and socket out after loosening it. Kief's videos and pictures gave me the assurance and assistance I needed. It wasn't hard at all! I guess when I reach 100k I will know how to change all 8 of the spark plugs and that is when I will be a little more complex with the back cylinders (4-8)
Thanks TechFreak, Wilson009, and Kief and thanks for a great forum!
'03 745Li |
How do you know which cylinder is misfiring
read errors with the scanner or buy one for 70$ from autozone, works fine
failed coils is a standard for N62 i would say it is standard for all bmw's starting form 90' |
If you have a misfire, you'll take out your plastic covers. Then you will start pulling the sockets on the coils one by one. At the instant of pulling one and seeing no effect in the way the engine idles, you have found the missing cylinder.
The V8s are a pain in the ar** to have the spark plugs/coils of 4th and 8th replaces. I take the caps of the coils off to be able to slide them out. I set a record for replacing the spark plugs and injectors at exactly 1.5 hours. And believe me I was in pain. |
If you have miss fires, does the check engine light go on at any point?
I think i am constantly having miss fires of some sort. When the engine idles, I can feel whole car shaking little bit. And when starting cold its definitely shaking hard. btw what spark plugs did you use? |
A tip for pulling coils out: I grew tired, rather my fingers grew tired of the pain incurred pulling out the coils by the finger hole in the cap of the coil top. I took a long 3/8" extension, putting it through the hole in the cap, and was able to use two hands to get it to separate from the plug. Much easier and makes it pretty instantaneous. Before with my finger, I would have to twist it a bit and it was bloody murder on my fingers.
Best, josh |
