7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#26
Plus i am looking at his logic 7 , he said the passenger under seat woofer is making a humming noise .
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up |
#27
When I get the aux plug will I need to get a 3.5mm extension to go to my phone?
Paper ur my boy. Lets lock this thread
![]() 04 745i 22s 6" lips l.e.d halos,parking lights,license lights.smoked headlights& tails. Acs roof spoiler,fiberglass box 2 10's. Split personality exhaust |
#29
If any 1 needs any info on the Aux input's they are 2 = right , 7 = left , 8 = ground
feel free to PM me ...
#30
Aux introduced from 09/2006 build. If your vehicle was built before that date then you may not have the option.
Update the ASK and do the FA edit to #0906 |
#31
Paper (or anyone else),
i need some help with this. i followed Paper's instructions but i can't seem to get it to work. 1. i changed the aux parameter to aktive in the MMIGT module so now when i go to the entertainment list i see a white AUX option 2. i bought the cable and rewired it just like Paper suggested (2 right, 7 left, 8 ground) 3. i took out the ASK but then i saw that there is another cable in the spot where the aux cable is suppose to go? 4. i took out that cable and connected the aux cable instead i turned on the ASK unit. AM/FM works fine. i connected my iphone to the aux cable and played a song but when i switch to aux nothing happens. it just sits at aux with no sound. aux does not turn to orange like when other options are selected. it stays white and no sounds is heard. what is the cable that was connected in the aux spot?? what am i doing wrong? please help |
#32
Well 1'st you should fix all the problems
you have been having with your Ask Unit, & The other equipment you have been mentioning in your other post , before you try installing new features to your car . 2nd does the volume line pop up on the MmI when in auxiliary mode after you press it 2xs ??? Edit = You should trace the plug that is already plugged into your Ask Unit to see what it leads you to . It might just be you already have aux in your car . ( maybe look in your center console to check for the stock aux ) Also you might want to reset your MMI back to factory settings since you messed it up by playing with it , & changing features on It . Sent from my GT-N7000 using Bimmer App
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up Last edited by PAPER; 09-04-2012 at 09:34 AM. |
#33
Dang Paper, thanks for doing this DIY. SO much hostility in your video LOL. I know why, its just funny. Sorry. Based on your thread and videos it looks like I am going to need a new ASK AND new MMI to get this in my 2002. Thanks. I will be looking to purchase these upgrades soon. Let me know if you come across one. Im in Riverside.
Thanks Paper
the volume line does not pop up when i presss the aux 2 times or a few times. it stays white which tells me the ASK is not switching to aux. the plug that is in the aux spot goes back to the same thick cable that comes from the other ASK plug (the main plug). they combine into one thick wrap which tells me it was done in the factory? but how can that be? i checked the center console and the glove box but no aux plug. my car is 01/06 E65 so i dont think the aux was availble from the factory on that model how do i change the mmi back to factory settings? the only thing i changed in it (other than the aux parameter) is the legal disclaimer time out. i saw posts of people that enabled the aux on pre facelift ASK so it should work on mine as well (post facelift) |
#35
you stated you did some coding in your MMI . I think you might have changed some settings in there by accident , Maybe you put a blank space someplace & didn't notice it . Or maybe you did something else when you coded that affects the things on your ASK Unit that are not working . 1 wrong thing you might have accidentally done could be affecting the Aux volume & the mode button you claimed stopped working , along with your other issue's . Well I would unwrap the plug & try to follow it , But it's your car & that would be your decision to make . How many wires are on the plug that was in the Aux spot ??? could you maybe take some pic's with your phone & post them up so I can see the plug your talking about ??? As for resetting your MMI back to factory . You will have to use NCS again , but this time use expert mode to read & then code the MMI as for Pre-facelift Ask unit working with Aux (almost 110% positive it's not possible ) what you saw is an Ask unit that they changed the front face of ( basically they changed the front from a facelift front to a pre-facelift front on the Ask unit ) I did this for some 1 that did not want to spend the money on the wood trim needed for the FaceLift Ask unit , I also changed the A/C control front cause he didn't want to buy the newer FaceLift key or CD plastic section .
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up Last edited by PAPER; 09-05-2012 at 12:07 AM. Reason: double typed a couple words . |
#36
the plug that is in the aux spot has 5 wires (see attached pictures). the wires are connected to spots 1,3,4,9,10.
i tried to change the pins on the new cable to 3,4,10 as in the E39 but the result was the same (aux does not turn orange and no sound is heard when played from my iphone). i think the issue is with the ASK unit but i still cant figure out what is that cable that is connected to the aux spot?? Last edited by tamir15; 09-06-2012 at 09:24 PM. |
#37
Well does anyone know someone in dallas that can throw this in my 750 without going to the dealer?
#38
Paper, I think it was in one of your videos that you describe the POST facelift ASK has buttons on it and the Old ASK unit does not... Here is a pic of my ask unit. Has buttons on it??
Nope, the facelift ask will have a mode button and fm/am buttons on it. You also need to make sure the manufacture date is after a certain time.
97 740i e38 - SOLD 02 745i e65 03 Montero Limited ![]() |
#40
This is the one. Make sure its an 06 to 08 ASK Unit.
TUF-FKR, If your in the market for one here you go.
http://www.ebay.com/itm/BMW-E65-E66-...item4165a53815
Mode , FM & AM buttons , & the Pre-FaceLift does not . Quote:
#43
Anyone knows what is that cable that is connected to the back of my ASK unit in the spot where the aux cable is supposed to go?
(it is a post face lift ask with mode and am/fm buttons) |
#44
So if you had the mode button on the ask you should be able to add the AUX cable.
I have rear entertainment will this affect if this mod will work or not. Mine is a 06 750li |
#45
#46
just as a recap....will this work on a prefacelift ASK?
Sent from my GT-P6800 using Bimmer App |
#47
not necessarily. i have a post face lift ASK with the mode button and the aux cable wont work because it is 03/06 ASK model. people say you need an ASK that is 09/06 or later but i have not been able to verify that because i have seen forums where people connected the aux cable to pre face lift units |
#48
i am not sure. some people say yes and some say no. check out the attached link (need to translate it to English). it has a pre face lift unit and the aux cable works for them http://www.7-forum.com/forum/22/aux-...en-170318.html |
#49
#50
My car was built in 11/05 so a early 06. I guess I just have to get the cable and try.
