7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#26
![]() Quote:
Fuel pump on BMW's especially the E65/E66 platform are notorious for going out. So I wouldn't be surprised. As for the fuel filter, it is recommended to have it replaced every 20-30k miles as a maintenance item. So it might be way over-due and that's why it is currently acting up. Either way, these two items are super easy to replace. Just get 'em both swapped out.
1) 760Li- Logic7, Rear entert', Rear Climate, Comfort Access, 20" DP Wheels. 2) Lexus LX470- Mark Levinson Video/Audio, 22" Diablo Elite Wheels.
#27
Funny thing is this started happening after I took it in for an oil change at my Indy.
I have to find my coolant leak first. Hope it's not a weep hole issue. Fingers crossed
97 740i e38 - SOLD 02 745i e65 03 Montero Limited ![]() |
#28
Speaking of you hatin' your 7..........even though mine currently has only 52k miles, I am thinking of selling the 760 actually..
#29
#30
It might be just a hair-line crack on the coolant reservoir= Easy fix! |
#31
I highly doubt its the weep hole. Right b4 mines went a few months back I notice my coolant level was not at the rim as usual but NOT low enough either to trigger the warning light. About a week or 2 later upon pulling up to the house I smelled a faint sweet smell of coolant. I asked my girl to back the car up an sure enough it was pouring out rather rapidly. lucky for me my mechanic is at the end of my driveway through the light. When I got there he removed the plastic engine cover an "BOOM" coolant was pouring out from the weep hole. We both kinda looked at each other an chuckled. It was destine to happen. As for what Pkathee said, do not rush to premature decisions. My experience with the starting issue was notice the weekend b4 the weephole. My car would shut off on me at relights, an stall on the freeways. It was rather embarrassing slowing down to a stop in traffic an then once traffic starts to move you CAN'T. Well ultimately that lead to further problems an it got so bad my car was towed twice in one day. 1st my girl was on her way to work an it stalled on the freeway. She got it started again about 10 mins later and made it to the light outside her job. She tried to start the car for about 30 mins b4 having the car towed home. When the car arrived home I tried to start it an right way it worked. Later that day I went to pick her up in the car "BAD IDEA" it stalled on me on the freeway. that was the 2nd tow. I ended up replacing the integrated power supply module nothing. I then replaced the fuel pump still nothing. Finally I replaced the SBSR Module located in the "B" pillar (thanks to a member on the forum) an the car started right away. Sense then no problems at all.
Low coolant
Inspect the coolant tank - mine had a very slight crack that when it got warm, it would leak. It was tough to find in the driveway but eventually I noticed it was wet between the tank and the passenger side air filter. Not sure if all the e66's have two air filters or just the 760's. Also found the plastic tee located just above the alternator on the small line leading from the radiator to the water pump had evidence of past leakage. The 760 has one heck of a set of rad hoses...I simply replaced them all as they are very complex. In summary, look for plastic leaking. The expansion tank was in stock and about $100 so it was an easy fix.
