7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
Need some help with error codes
Hey everyone,
I came out to my car (2004 745i) the other day after work and the car started but immediately the AC shut off and I got the Transmission Failsafe Message. This happened 2 days in a row and I just turned the car off and restarted. The car was fine after. I pulled the following codes: 9C64 - I know I need a new AUC Sensor 931D - over voltage / under voltage (is this the alternator or the power module being bad?) 5014 - not sure? A158 - not sure? A161 - not sure? I have a new BMW battery that was registered. I have replaced the integrated supply module. I am wondering if the codes support replacing the power supply module or the alternator? When I am in the hidden menu the alternator shows between 13.8 and 13.9 volts. This should be good I think. The transmission was replaced under warranty and only has about 20k miles on it. The car has 85k miles. Based on these symptoms, do you have any suggestions? Thanks in advance.
Here are some screenshots with Dashsoft:
i got question...
i have scanners..nothing shows up...all systems check ok idrive system check...all systems ok] when i go to hidden menu on dash and read faut codes this is what shows up...i have no check engine light on or anything of that nature.. did some research on internet..nothing turns out here are few examples: 0931C 21 008 59AE 7B 1A3BD 20 000 5D3F 7C 29327 20 000 5D3F 7B 3A3BA 20 000 53DF 6E there were couple more codes...anyone knows how to decode this?? |
I noticed in the Second picture you posted of the EGS module the VIN and Mileage is not being reported. That is not the real issue here, but the VIN should be present in all modules. The issue I see is the over/under voltage error you are receiving. The alternator is attached to the bus system and is controlled by the power module in the trunk. If the two bus systems cannot communicate with each other you will have these types of errors in the system. Do you have driveability issues with the car, IE. Transmission shifts, rough Idle, poor performance?
I have never used the Dashsoft software before,I know in INPA and tool32 it shows the VIN for every module. The power module will slow down the AC motor due to an under voltage situation. In INPA you can enter the Power module and look at the voltage for all parts of the system including the alternator output, I would take a look at that first. I would then take a look at your Central Gateway Module for errors, this module is the gateway between the Power train system and the bus systems. If this module is faulty the power module will be unable to communicate with the alternator thus giving you under/over voltage scenario.
i tried to clear the codes with scanners(small one/big one),also sw reset through dash...and codes remain took few pics of what i found.. ![]() ![]() ![]() ![]()
so i contacted Paper and no reply...do you know him personally? thx
I will state as a fact that INPA is the only tool you can use to register your battery, if you used something else that is just going to be the start of your issues. Dashsoft, 4in1tool, BT tool, ect can not register the battery correctly on a e65/e66.
97 740i e38 - SOLD 02 745i e65 03 Montero Limited ![]() |
5014 = Trans control unit / Power supply ( power supply cut off limit ) A158 - Closed Current circuit can sensor/CIM ( Chassis Integration Module ) A161 - Battery disconnect Usually faulty power module A158 & A161 Error = most of the time show up with each other . HERE IS A LIST OF SOME FAULT CODES ON A PDF http://www.google.com/url?sa=t&rct=j...ewqJiAR2C4Sd1w
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up |
you need to get a better scanner , or use INPA to get the hex error codes from your car .
I purchased all the INPA cables and software but never was able to get it to work. I found it extremely difficult to use and sold it to 1bad540. Maybe I will try again.
maybe those codes are for ASK unit,L7 amp,navigation,since my speakers are not working(some of them)...this remains still a mystery but thanks anyways for your response btw i hear lots of people have INPA...how much can you buy them for? i mean the good ones not some china imitation...or are they all the same Last edited by bayerisheteknik; 09-04-2012 at 10:42 AM. |
topic since it was at the bottom of the page . i asked the tech who sometimes helps me out & Your answer is yes . ( According to him you will need to register the battery again )
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up Last edited by PAPER; 09-04-2012 at 11:35 PM. |
Sorry I'm not familiar with Pro scanner beside the cheap 1's they sell on ebay . ( could you be a little more specific , which Pro scanner & is it compatible with BMW ? ) Has it ever given you codes when something was wrong with the car ? Cause even my Craftsman OBD scanner gives me error codes on the E65 E66 .
Thanks Paper.
