Old 08-19-2012, 07:04 AM
nico12play nico12play is offline
Mein Auto: 1995 bmw 740il
Blower motor
i have a 95 740il and sometimes the a/c works but when something gets to hot it just shuts down. Now I was driving and had the a/c on, it was working fine then it just shut off and it will not come back on. Does anyone know what the problem is? Also only one side was working. One side was blowing cold and the other was blowing hot.
Old 09-03-2012, 09:07 AM
j.elston96750il j.elston96750il is offline
Mein Auto: 1996 bmw 750il
it sounds like there may be two issues going on, one sounds like the blower motor is going out, the second is the blend door motor or door its self has failed, i was able to fix both of these concern myself at no parts cost just labor. but you can probably take care of this yorself, respond back and ill try to walk you threw this.
Old 09-03-2012, 09:17 AM
i think i might have a answer to your problem my 750il had the same issue, the blower motor would shut down just like yours i have able to remove this, clean the brushes, and armature, then adjust the springs to the brushes, when i was making this repair i found the blend door motor linkage had broken which required alot of work, if this sounds like what you need respond but and i can give you detailes to make these repairs
Old 09-05-2012, 08:34 PM
kenvbe kenvbe is offline
Mein Auto: 97 750
I'm have the same issue. It ac or air period on works when I'm moving any ideas?
Sent from my PC36100 using Bimmer App
