Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 06-03-2012, 09:44 AM
tranquility tranquility is offline
Sportscars only.
Mein Auto: 2011 Z4 sDrive 35i
HVAC prbs
My HVAC controls (the green lights in all 4 circles don't light up, so there is no function at all) would not work about 10% of the time I start up the car. So the dealer diagnosed the prb and supposedly it was a faulty control unit, which was subsequently replaced. However, the prb still occurs: not sure if you guys have any ideas what it could be? It is very weird because it still works but sometimes it doesn't.
Old 06-03-2012, 10:16 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Hi! when all of the lights are off have you tried to switch the blower on for example? It could be a faulty relay or a loose fuse as it appears to be a power issue!!!! even though the control unit has been replaced.
Old 06-03-2012, 12:34 PM
Sportscars only.
I have tried pressing all the buttons but none of them work when my HVAC is acting up; when it works, it is fine, all functions go. I'm not technically-inclined, but I agree w/ your assessment...it must be sometime loose or a software glitch because my HVAC works most of the time.
Old 06-05-2012, 01:14 AM
Sportscars only.
bump.
Well, the rear defroster button still works even when the rest of the buttons don't whenever the HVAC acts up.
Old 06-05-2012, 05:01 AM
645/333's Avatar
Michael
given your car should still be under warranty, you should just take it back to BMW!! I did have a look on a Wiring diagram but it is only for the E85 Z4, 2007 just to see if anything was obvious, sadly I could not see anything.......
Old 06-05-2012, 08:58 AM
Sportscars only.
^Yup, I definitely will take it back. They seem to have missed the prb so hoping you guys could provide the answer.
Old 09-01-2012, 08:51 PM
Sportscars only.
For those that did the 'master reset' aka 'touching battery cables together', how long have you been prb-free? Any side effects? Thx.
Old 09-07-2012, 06:35 AM
cuddapah cuddapah is offline
Mein Auto: 2011 Z4 35i
Didn't have this problem during ED. After dealer replaced iDrive control module and reprogrammed, I noticed this issue. Dealer did 'master reset'. But I am noticing this issue frequently. I am taking in the car today for the infamous 'Engine Malfunction, Reduced Power' issue. I will have them recheck the AC issue.
2011 BMW Z4 sDrive 35i * Titanium Silver Metallic * Black Kansas Leather * Cold Weather Package * Premium Package * Premium Sound Package * 7-Speed Double Clutch Transmission * Style 293 Wheels * Navigation System * BMW Apps * European Delivery * Performance Center Delivery * Joy Unlimited !
Old 09-08-2012, 11:51 AM
Sportscars only.
Darn, so you had the 'master reset' procedure done and you still have this HVAC prb? Pls keep us posted on any possible solution(s). Good luck on a fix. I still have this prb sporadically also.
