Old 08-25-2012, 08:44 AM
LydoZ3 LydoZ3 is offline
Mein Auto: United Kingdom
Problem with tick over z3 1.9 4cylinder
Hi, I've recently had the intake manifold off to fit a new coolant flange and crank case vent. I've put it all back together and it's running rich and struggles when I rev the engine. I thought it could be the icv so I've bought and fit a new one but is till running rich. Could it be the mixture or somethin with the choke. Any help would be grateful.
Old 08-25-2012, 09:47 AM
wifesauto wifesauto is offline
Mein Auto: sloporsche
imo go back over your work. you may have a vacuum leak
Old 08-25-2012, 01:28 PM
I'm gonna check over it tomorrow , I've been reluctant to because to check the intake manifold I Have to remove the fuel line. It's a pain in the ass! Still cheaper than takin it in to the garage
Old 08-25-2012, 09:07 PM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 1996 Z3 1.9L M44
+1 on possible vaccuum leak.
1996 Z3 (M44)
Old 08-26-2012, 07:35 PM
KillerSE7EN KillerSE7EN is offline
BMW Fan Boy
Mein Auto: 96 z3/ 04 325i/ 11 x328i
Double check to make sure your fuel injectors are sitting in the manifold correctly. When I took mine off to clean the intake it idled really rough until I revved it up a few times. Did you change the lower manifold gasket and torque it to spec?
Old 09-01-2012, 10:02 AM
I've done all that and it's still running rich and becomes jittery every 60seconds for a few seconds. The spark plugs where black aswell so I've cleaned them up,
Old 09-03-2012, 02:40 PM
BMW Fan Boy
Any cracks in the 4 hoses going to the injectors?
Old 09-03-2012, 03:12 PM
I don't think so, the only hoses are breathers from the injectors, there's only the fuel rail and that's steel I think. I've replaced the breather hoses from the injectors. Would that have anything to do with it, I couldn't see it myself but I'm lost for ideas
Old 09-08-2012, 05:51 AM
BMW Fan Boy
Any way you can post a video?
