Old 08-28-2012, 01:45 AM
Blink_412001 Blink_412001 is offline
Mein Auto: 2008 528i
Break noise pls help
Hello I have an e60 08 528i. I think my breaks need to be changed because when I press on the pedal I can hear the annoying sound of The breaks but my dealer said its only dust is it true? It's still under warranty. Or is it that they don't wanna do it?
Old 08-28-2012, 08:09 AM
Campfamily's Avatar
Campfamily Campfamily is offline
Mein Auto: 2008 550i
At low speeds, the brakes on my 550 have squeaked since the day I bought it. There are a bunch of threads on this forum about squeaking brakes, some have gotten the dealers to change pads, others haven't. I've just lived with it, doesn't really bother me.
2008 550i, Carbon Black, Black Dakota, 6MT, Sport Package, Nav, Logic7, Comfort Access, Cold Weather, Folding Rear Seats, iPod SOLD, but not forgotten
Old 08-28-2012, 08:35 AM
ntocamping ntocamping is offline
Mein Auto: 550i
Same here. Low speeds mine will squeal a little. Not really a screech almost like a boost type sound though. Dealer said normal and no fixy
Old 08-28-2012, 10:38 AM
luxcar luxcar is offline
Mein Auto: 2008 550i, HUD, SAT, L7
Same here with 08 550
2008 550i M-Sport, SAT, HUD, Premium package, Comfort Access, L7, Comfort and Ventilated seats
2007 Acura MDX, Elite, Running boards, roof rack
Old 08-28-2012, 04:41 PM
Theduke Theduke is offline
Mein Auto: 535i xDrive, 6MT, Msprt,
Living with it Would drive me nuts.
Old 09-07-2012, 03:02 PM
mleedom mleedom is offline
Mein Auto: 2008 550i sport pack
My 08 550 does the exact same thing. It sounds like a very common thing with BMW.
Old 09-07-2012, 06:47 PM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
I had the same problem, the noise was reduced to near gone by not only changing breaks, but the disc at the same time.
Sent from my Android Bug
Old 09-07-2012, 08:54 PM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
When I had that problem I told my SA and he said it shouldnt make noise. They ended up doing a complete brake job since that squeaking noise was the built in noise warning. Ever since the brake job my brakes are quiet, even under extreme braking conditions.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Old 09-08-2012, 08:49 AM
F1.tifosi's Avatar
F1.tifosi F1.tifosi is offline
Send a message via Yahoo to F1.tifosi
Mein Auto: BMW 535i Sport, 08 Accord
Yes, the noise is definitely signs of break pad issues... Better to check with a dealer or BMW service guys..
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |F/R Cameras | Escort 9500ix |
Old 09-08-2012, 10:01 AM
NoQuarter's Avatar
NoQuarter NoQuarter is online now
Mein Auto: 2008 535xi
3 E60s and my brakes have never sqeaked with OEM rotors and pads
Old 09-08-2012, 11:58 AM
BickUW89's Avatar
BickUW89 BickUW89 is offline
Go Dawgs!
Mein Auto: E60 550i SP
Don't put up with squeaking brakes!
Several posters have said that their brakes "have always squeaked," and there seems to be an impression that this is "normal" for BMW brakes.
Not so!! Notwithstanding the wear sensor noise from worn pads, if your brakes are squeaking, it's because the pads and guide pins aren't properly lubed. I have/do own three 5ers (E39, E60, and F10), and can tell you that brake squeaking is not "normal." It's not detrimental, so a dealership won't "fixy", but it is annoying, and you don't have to put up with it. This is a simple 30-minute DIY project.
Here's my own recent experience: For the first three years of ownership, the brakes on my E60 never made any noise whatsoever. Once the front pads had worn down to the sensor at about 52,000 miles, I of course got that feedback that it was time to change the pads and rotors.
When I changed the pads and rotors, I lubricated the contact points of the new pads and calipers, and put everything back together, but I noticed a bit of squeel after a day or two. It wasn't loud, but it was annoying and NOT normal, so I took the brakes apart to relube them.
This time I (again) thoroughly cleaned the pads and calipers, but this time I re-lubed not only the brake pad-caliper contact points, but also put a thin coat of lubricant on the shafts of the two guide bolts. Problem solved. No brake squeal whatsoever.
BMW Ergo Zoom
IMHO: E39 < E60 > F10
2016 F82 //M4 (ED July 6, 2016)
2011 F10 535xi (ED July 15, 2011)
2008 E60 550i (ED July 22, 2008) (Retired)
2000 E39 540i (Retired)
Member BMWCCA #402733
Old 09-08-2012, 07:00 PM
z0lt3c's Avatar
z0lt3c z0lt3c is offline
what does this button do?
Mein Auto: 08 535xit
If the rotors are evenly worn, the pads have useful life left, and the sensor is properly located, the OEM pads are known to squeak because they use copper in the formulation of the pads. When the copper residue builds up on the rotor, and to a lesser extent the wheels, it's know to make a squealing noise. Those who generally don't get the problem regularly clean the brake dust and those who get the problem usually don't clean off the break dust as frequently or as well. The easiest solution is to switch to aftermarket pads which use a different compound, one without copper and one which doesn't create as much dust. The OE pads perform OK but they use a midgrade compound at best.
Old 11-19-2014, 05:50 AM
BMW535xia BMW535xia is offline
Mein Auto: 535xi
Okay, and thanks .............. do the pads that the dealer installs have the copper "imbedded" in the pad itself? am having an issue with squeaking @ full stop, and am suspecting rear pads.
