E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
#26
The 4 values per cylinder M54 is the best 6 cylinder BMW engine. It's in my 330i.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton. Last edited by Dave 330i; 09-09-2012 at 01:23 PM. |
#27
The only improvements the ZHP needs are an LSD, lighter wheels n the S54 motor
#28
The dip stick got the job done very quickly and precisely because I see the level. Please tell me how the electronic monitoring indicator is better. It takes longer and I cannot verify it is accurate. I have to "believe" that it is correct.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton. Last edited by Dave 330i; 09-09-2012 at 01:28 PM. |
#29
Actually, the lighter N52 makes higher hp than an M54 and has a screaming 7K redline to die for. The '2006 330i is kind of the cult car of E90s because of it. |
#30
A quick google search reveals a LOT of issues with it (not to mention the firsthand stuff I see and hear from my buddy who owns a shop). The M54 is PROVEN to live 300k miles and up, we don't have that data yet on the N52. |
#31
![]() I'd say, from having monitored both forums here, other forums other places, and from having had an M54, that there is no clear winner as far as reliability. Too bad BMW won't tell us. |
#32
The N52 is pretty impressive but not that much when compared to the ZHP M54 with the 6800 rpm redline. IMHO, both are a wash due to the E9x 330i's extra 150 lbs of weight, it robs any advantages or performance at all compared to an E46 ZHP. As for the E9x with the N54/55, I don't see those lasting 200k or even 300k miles just due to the nature of FI and the turbos giving out. Last edited by av98; 09-10-2012 at 07:06 AM. |
#34
but as for major repairs like head gasket, timing chain etc. you'll find that the N52 engines are ALOT easier than the m54. this is coming from experience considering i just did both timing chain and oil pump chain + guides.
iATN
#35
A friend of mine has an E93 328i. At one point, she was ready to sell it because it was acting up after some spirited driving. Error lights here, check engine there, "F*ck off and die" on the OBC display... you know how it goes. After debating whether or not to say "to hell with it" and sell the car, she ended up keeping it and telling herself, "After I fix this, it will be good to go for a long time." I'm willing to bet she'll have another issue within 12 months. On another note, you can look around and find a lot of 335i's for ridiculously cheap prices. Reason being: they're lemons! And I mean there are a TON of them! A local independent dealership has two black on black 335i's, one automatic and one six-speed. Both are priced right at $20,000 and have less than 80,000 miles. They were bought back by the dealership and then labeled as lemons. Fuel injector issues, I believe. Whether or not this means the entire car is bad is beyond me, but it definitely is disheartening.
http://www.caranddriver.com/reviews/...kage-road-test E90 330i review http://www.caranddriver.com/reviews/...330i-road-test "All of this adds up to a car that runs smoothly, feels wonderfully safe and secure on the road, and drives with a rare precision. As our exclusive test numbers show, it is also very quick for a less-than-$40,000 compact sports sedan: 0 to 60 mph in 5.6 seconds and the standing quarter-mile in 14.3 seconds at 98 mph. Although these figures were recorded on a surface with poor grip, they match the performance of the current-generation 330i with Performance package with its much larger rear tires. Our Euro-spec test car ran a bit beyond its 155-mph governor. U.S.-bound cars will be limited to 130 with the standard suspension and 150 mph with the Sport package." Last edited by av98; 09-10-2012 at 07:50 AM. |
#37
In this case, btw, you're arguing against the M54 aficionados: the N54 (and N55) engine block is heavily based upon the beloved M54. It's apparently got a stronger bottom end that more easily handles turbo-charging than the N51/2/3. If you like, I can accede the point that problems with the N54/N55 are seemingly limited to parts that weren't on the M54. Except for the water pump, which has far fewer problems than the M54 ones (too bad it's so much more expensive.) IMO, all this is water under the bridge anyway, now that the F30 is out. It really points out the fact that it's not engineering (for the most part) that is driving changes to the 3-series. It's MARKETING, and most of us aren't the target market. |
#38
(Screw the maintenance on those things, though... have you seen what it takes to remove a friggin' headlight bulb?)
Those might be golden opportunity for someone who's wishing to rebuild half of the engine anyway for some sort of racing purpose.
#40
Sent from the Bamavarian Nexus.
it seems that much more bmw 3 series owners tend to E46, is that true? in this case, BMW failed to develop the new bmw 3 series of E90?
#42
Although it's not entirely clear, in looking at the sales figures in wikipedia, in the US the E9x series sold about 50,000 more over it's 7-year lifetime than E46. The E46 is less expensive than the E9x simply due to age.
#43
Plus the majority of E9x owners are not longterm committed, instead they are mainstream out the door after 3 years owners- not really enthusiasts. If that drives sales volume for BMW, great. But I'd rather have owners that love everything about their car and know it inside out. Yes, we work on our cars, opening the hood and checking the oil dipstick after the car turns off 3-5 minutes later for the proper reading. |
#44
The reality is that those were the same original owners of E46s.
#45
Surprisingly, most E46 owners are still in them, only a few have transitioned. Reminds me of E30, E36, MR2 AW11 and Miata owners that keep their cars till they die or make them 2nd cars.
#46
Since about 1/3 of BMW E46 3-series were leased (I can give you a reference for that if you want it), it kind of calls your blanket statement "few" into question. Frankly, I simply don't believe that you can prove your assertions. Even anecdotally, look at the number of "newbie, just bought a ..." that are posted in this forum. |
#47
But I'll bet that you still can't prove your assertion for either population.
| Tags |
| automatic, e46, e9x, handling, manual |
