E36 M3 (1995-1999)
Old 02-17-2012, 03:24 PM
ChuckG ChuckG is offline
Mein Auto: 99 M3
Leatherique Seat Restore Project. Before and After pics!
I used the Leatherique Kit #2 (16oz of each liquid) and the whole thing took my girlfriend and I about 6 hours over 3 evenings to complete. I'm very pleased with the results. Let me know what you think?
Passenger outside upper bolster, BEFORE:
Passenger outside upper bolster, AFTER:
Passenger outside lower bolster, BEFORE:
Passenger outside lower bolster, AFTER:
Passenger inside lower bolster, BEFORE:
Passenger inside lower bolster, AFTER:
Passenger inside upper bolster, BEFORE:
Passenger inside upper bolster, AFTER:
Driver inside upper bolster, BEFORE:
Driver inside upper bolster, AFTER:
Driver inside lower bolster, BEFORE:
Driver inside lower bolster, AFTER:
Driver outside lower bolster, BEFORE:
Driver outside lower bolster, AFTER:
And as everyone knows, the worst of the worst... Driver outside upper bolster, BEFORE:
Driver outside upper bolster, AFTER:
Overall before:
Overall after:
1999 Cosmos M3 Coupe, TMS Stage4+ - Work in progress
2008 Interlagos M3 Coupe - Retired
Old 02-18-2012, 10:16 AM
X3-terrestrial's Avatar
Aficionado
Amazing! Can you post the exact product you used? Does it have a dye? I'm absolutely doing this!
-Mario Andretti.
___________________
River City Bimmers BMW CCA
2002 ///M3 Coupe, Steel Gray Metallic on black leather, HK, three pedals.
1991 E30 325ic, AW, Black Leather, Black top, Three Pedals.
Old 02-18-2012, 07:37 PM
Mein Auto: 99 M3
I used leatherique re-dye kit #2 http://leatherique.org/detail.aspx?ID=31
It has a rejuvinator oil, cleaning agent, prep solution (you sand with this, I think it's just a de greaser), and final step is dye.
Old 02-18-2012, 08:46 PM
Aficionado
Cool! Thanks!, absolutely worth the price, your seats look like new!
-Mario Andretti.
___________________
Old 02-22-2012, 09:27 PM
CTBimmerGuy CTBimmerGuy is offline
Mein Auto: 1999 M3 Convertible
Really great work. Thanks for the post. I'm going to give it a shot on my seats as well.
Old 02-22-2012, 09:36 PM
JoshuaG's Avatar
JoshuaG JoshuaG is offline
Natasha 95M3
Mein Auto: 95' E36 M3
That's incredible.
Originally Posted by kaos_325i View Post
Maybe I haven't been here long enough to realize the knowledge you have to share. But, from all I can tell you are just an over opinionated, rude, prick.
My .02
Old 02-23-2012, 11:04 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Do you have to remove the seats to do this?
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
Old 02-23-2012, 05:50 PM
Aficionado
You maybe don't HAVE to, but probably it's easier, and you don't risk staining something else inside the car.
It just takes 5 minutes per seat to remove them.
-Mario Andretti.
___________________
Old 02-25-2012, 11:08 PM
Read a post from a guy that did the first seat while it was in the car. Said he had poor results with the top and bottom of the seat sticking together and other problems. Ended up having to take the seat out and do it again. If you're doing the entire seat, top and bottom instead of just a smaller area I believe it's best to remove the seats from what I've read. Also as has been mentioned it's four bolts and a un clipping a wire harness or two and they are out. I'm going to install a new reclining gear in my passenger seat while they are out and fix two problems at the same time.
Old 03-06-2012, 11:05 AM
Mein Auto: 99 M3
Update to the project:
I ordered a 2oz bottle of BL02 (baby blue), BL06 (blue), and R04 (bright red) from Furniture Clinic. The center stripe ended up being a mixture of about 75% BL06 and 25% R04.
I also repaired the cracks in my stripes with the heavy filler cream from FC, then I used their Matte finish sealant/top coat applied with an airbrush in 3 coats.
Here are some additional pics. The matte finishing coat is currently drying. Final pictures to follow after assembly.
Old 03-06-2012, 11:20 AM
petener999's Avatar
petener999 petener999 is offline
Mein Auto: 750i, x5 4.6is, E46 M3
Great job!!
Old 03-06-2012, 07:05 PM
I'm working on my seats right now thanks to your post and a bunch of others on this site. Removed both front seats from the car (easy). Going to fix the broken reclining gear ($39 on Ebay) on the passenger seat as long as I have them out of the car. Found the broken gear inside the seat transmission box and ordered a new one. Spent several hours wet sanding and removing failed dye on the driver seat which is always the worst seat. Used a little crack filler to test results in a couple of the worst spots. So far so good. I bought Kit#2 from Leatherique with 2 oz. of crack filler. Wet sanding and removing the cracked dye is taking quite a while but the leather does get really supple as you remove the old dye. Wet sanding leather is a little scary at first but once you realize there's no turning back you just keep moving forward. I'm taking pictures at various points along the way and will probably post my own thread if the project goes well. The car I'm working on is a 98 M3 in Helrot Red with Magma and black interior. Leatherique has the Magma dye color (custom color) I need. I haven't applied any yet but it looks like a perfect match.
Old 03-07-2012, 09:38 AM
Mein Auto: 99 M3
I also had to replace the reclining gear on both these seats. I did that a couple months back, wish I had done it all at the same time. Good luck, can't wait to see. I love magma interior!
Old 03-07-2012, 09:39 AM
Mein Auto: 99 M3
Seats are re-assembled. Here's the finished product. I ended up swapping the back and bottom cushions between driver and passenger seats to move the more worn outside bolsters to the inside. I also get to have the slightly nicer passenger cushions as my drivers seat now.
New Passenger Seat:
New Drivers Seat
As you can see in the background my steering wheel is next.
Old 03-07-2012, 09:44 AM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: E46 944 Turbo
Stunning results!!! Nice work, I was cleaning last year, and I took some color out of the passenger seat. This might be the way to go.
Old 03-07-2012, 09:41 PM
Great work Chuck. Thanks for taking the time to write up your DIY and post your pics. Your DIY and the results you achieved convinced me to do the same. My seats are out and I'm finished with the first coat of Magma dye and the results are stunning...same as yours. It's really hard to believe the seats come out looking like new but they do! I've got a DIY thread going as well for anybody that's interested. I wouldn't have attempted it Chuck if you hadn't posted your DIY.
Old 03-08-2012, 08:57 AM
Mein Auto: 99 M3
Glad to hear it. I should write up a proper DIY with step by step but I always forget to take pictures in the middle of the process as I tend to get in the zone.
I look forward to seeing the pictures of your results.
Old 06-25-2012, 02:03 AM
Wahwill Wahwill is offline
Mein Auto: 97 m3/4
I'm thinking of doing this as well. Did you simply choose the generic black color when purchasing the kit#2? Or did you have to provide a custom color code?
How does the leather feel compare to original? And how is it holding up so far?
Old 06-25-2012, 05:13 PM
xDan xDan is offline
Mein Auto: 97' E36 M3
Amazing work! They seriously look like their in mint condition!
Old 08-24-2012, 04:48 PM
Kaylieandseven Kaylieandseven is offline
Mein Auto: M3
Wow. This is truly jaw dropping. I'm wondering how long it will last though. Is this some kind of coating that goes on top and wears back to its original state? Or will it stay that way from now on if u condition it from time to time.
Old 09-10-2012, 11:09 AM
Milla Milla is offline
Mein Auto: 00 M5 DINAN S, 97 M3/4/5
WOW!!!! That looks amazing!!!
I currently HATE my Leatherique and ordered Chemical Guys and Zymol - the seats feel so damn DRY!
Now the seats you have look impeccable. How soft is the leather now?
[ 97 Techno Violet M3/4/5 | 01 Phoenix Yellow M3 | 00 Imola Red M5 DINAN S1 | 09 335d Water Blue ]
I own heels and a clutch pedal.
I support Central Florida BMW Owners & Fello Racing!
TWITTER/millakins | INSTAGRAM/millakins
____ NURPLE ____ M3PO ____ MCINQUE ____
Old 01-22-2014, 10:32 AM
IMSARS69 IMSARS69 is offline
'ol corps rac'r
Mein Auto: M3
Are you saying you'd been using just the regular Leatherique Rejuvenator Oil and weren't happy with the results?
And then did you try the Chemical Guys and Zymol, or both? Did they cause the seats to become dry?
I've been advised by a professional leather restorer that swears by the Leatherique Rejuvenator Oil and had intended to use it. Wasn't going to go into the full restoration process outlined in this thread for now, but was wanting to help the seats out some and hopefully offer some protection for them in the time being.
Any clarification on this would be very helpful.
Anyone else care to offer their experience with just the Leatherique Rejuvenator Oil would also be appreciated.
TIA...
IMSA RS 69
'ol corps rac'r
Rac'n Class of '69
Car #69
Co-Designer, Co-Builder, Co-Driver of
First Ever IMSA All American GT Rac'r... 'The Vegrant'
John Bishop's answer to European domination of Big Time American Road Rac'n
Out of Pocket Cost - $5K
Look on John Bishop and Charlie Rainville's face when it pulled into Daytona Speedway's paddock for it's debut at the '74 IMSA GT Thanksgiving Finale... Not exactly the $200K tube-frame 'space car' they was expecting... - Priceless!
Old 01-29-2014, 10:31 AM
TMACM5 TMACM5 is offline
E60 M5 *****
Mein Auto: E60 M5 Silverstone II
This is pretty awesome, thanks for posting it up!
1999 BMW E36 M3 - Lots of work...
2007 Audi RS4: Sprint Blue Pearl, APR Tune, ECS Tuning 10MM spacers on all 4 corners
1991 BMW E30 318IC: Laguna Green on tan interior, H&R springs, Konis, H&R sway bars, and a few other goodies
*SOLD*2006 BMW M5
*SOLD*2003 BMW M3 Vert
*SOLD*1999 BMW M3 Convertible (Dinan S3)
*SOLD*2001.5 Audi S4
*SOLD*2002 VW Jetta Wagon 1.8T
*SOLD*2001 Porsche Carrera 4
*SOLD*1996 BMW M3
Old 02-20-2014, 11:11 PM
ACK-FIN ACK-FIN is offline
Mein Auto: 1995 AVUSBLAU M3
My first post
Oh my Gawd!! I recently picked up a pristine low mileage 95 with black interior. All the leather is nearly perfect except for the driver's outter upper and lower bolsters and the center lid. Luckily my worst spot is better than your best before your work. Since I want to fix even the smallest issue I was about to buy covers for ~$800 plus installation. Well, that is not going to happen now. You did this a while ago - how well has it heald up? I hope to hear it still looks the same as when you did it. Thank you for the write-up and great pictures.
Does anyone have a list of all hose dimensions and lengths? I'm considering silicon or, better yet, viton hoses. My 95 RX-7 had about 30 feet of 1/4" and 10 feet of 3/8" vacuum hoses because of the sequential twins. Well, since rotaries run so hot viton was the best choice. I started developing vacuum leaks and it was nearly impossible to track it down so I bit the bullett. If it lasted so well under those conditions I'd sure feel secure using viton here.
Last edited by ACK-FIN; 02-20-2014 at 11:37 PM. Reason: added last paragraph to ask a question
Old 07-27-2014, 12:53 PM
jbarryos jbarryos is offline
Mein Auto: '02 540i 6 speed
Very Nice
Wow, very nice and it looks like you did it all in your Living room!!
