X6 E71 / E72 (2008 - current)
The newest sport activity vehicle from BMW is a crossover-coupe style and is expected to appear sometime in 2008! |
Hi all,
i have an '09 E71, i really like to retrofit the iDrive to be just like the 2012 on-ward ones. If anyone knows where to get the parts, or who to be in-touch with, do let me know. Thanks much. |
I believe you are looking at $3k to $4k in parts before labor to install. This is quite literally a computer buried in your dashboard and requires replacing the screen and several control modules. Replacing the screen is actually a good thing as the new one is bigger and higher resolution. This assumes you can find a compatible kit for our style car, or you are able to get all of the part numbers from a later model car and make them fit (probably wise to go with 2010 the first year of the new gen idrive in the X6). Then you need someone to code the whole car as the idrive it essentially the "brain." Going the later model part number route could be risky (riskier than attempting this in general). You could essentially 'brick' your car.
In idrive terminology you are looking at going from the CCC system to the CIC system. Here is someone that did it on an E60: http://www.m5board.com/vbulletin/e60...ation-log.html and an M5: http://www.bmwblog.com/2010/08/07/co...-5-series-e60/ And finally a possible place to get the system: http://www.bimmerretrofit.com/portal/shop That is about the extent of my knowledge. Try searching this forum, xoutpost and google in general for more information. |
PS if it works, report back with some pictures.
One of the reasons i had some info at hand was my own curiosity in how feasible this was. I decided it wasn't a top priority given the price and risk. I making some other updates first... |
BimmerTech Phone (USA): (646) 439-7920 (7:00am - 3:00pm ET) :: info@bimmer-tech.net :: www.bimmer-tech.net Installation facilities worldwide. Follow us on
The total could be a little less than i was thinking if I went the DIY install route and i could do the PnP activation instead of the OEM. |
If you send us your VIN by email I will let you know what options you should order, but if your car has the PDC and/or rear view camera you should choose the PnP Camera/PDC fix and the PnP Navigation/Voice Control activation.
