Old 09-02-2012, 03:21 PM
nwvalleyjock nwvalleyjock is offline
Mein Auto: 2011 535i
Partial success on my first programming attempt! Cable finally came from Hong Kong (was stuck in US Customs for over a week) but it appears to be well-made, works just fine, and only cost $29.
Since I'm taking the car to the dealership this week for its annual maintenance and possibly some software updates (hesitation issue, slight pull to right, etc.) I didn't want to go nuts today given that I've read that software updates by the dealer will wipe out my altered settings. So I'll do more next weekend, after I get the car back.
What I did do successfully was program it in module CAS so the key fob will allow me to close the windows & moon roof -- functionality, I might add, that my 2007 328xi had standard. Interestingly, it doesn't seem to fold my mirrors, though. Now I did not notice that I should have also changed the related item in the FRM module, so maybe that's why the mirrors didn't fold …... just a guess .. and something I can honestly live without, anyway. I rarely fold them in except when parked long term at the airport, anyway. I also changed the TPMS settings in the HU_CIC module, though it did not add tire pressure and temperature to my display. Big disappointment, as that was the one change I really wanted ... and I'm pretty sure I have the TPMS since I have metal valve stems, not rubber. Oh well, maybe someone can figure that out since the "cheat sheet" says that change works for some people but obviously not all. Darn. Finally, I also changed the Speed Limit Info settings in HU_CIC but didn't change the related setting in KOMBI, so that's not working yet (and I have the rear-view mirror cam, as I have Lane Departure and Automatic High Beams) but should be when I fix that.
Two questions from today's experience, though. I ran the batch file that is posted elsewhere on this site to back up my CAF files after reading them in E-sys. After I was done making my changes above, I went to look for the original files, and though I found a folder My_CAF_Files with a sub-folder date & time-stamped properly, that folder was empty. What might have gone wrong? I'm not too upset that I don't now have an original unaltered set of files, but I'd like to make sure it works going forward. Second question is that I didn't even see the HKFM module so I could code the inside button and key fob to close the trunk when pressed. Is that because I only had the v45.1 psdzdata files to work with? Should that module appear if I upgrade to the v46.6 files I see on here now?
Anyway,. I wanted to share my experience today so that other newbies might not feel so intimidated by the process of programming the car. It's really not too bad if you follow the step-by-step instructions given in the Getting Started document. Really!
Old 09-03-2012, 12:03 AM
April1 April1 is offline
Mein Auto: X3 2011
CAF files will be copied to a date time stamped folder if:
1. E-Sys is installed at the default location else you need to edit the batch file
2. After making the changes to cafd files, they are saved.
Old 09-04-2012, 09:06 AM
Beer55 Beer55 is offline
Mein Auto: 335i E92
Hi I'm new here. Do not speak English so I have to work with Google translator and I hope it works.
I encode for some time and have the V46.6 work load but not, or are too old.
Does anyone have a link for 47.4?
Would be very grateful.
Is there a Esys the German experts speaking?
Would have access to a 750iL F02 and F10 M5 both have no more VMAX limit. NOT made ***8203;***8203;by Dynan.
Is it interesting?
Old 09-04-2012, 09:23 AM
chris88 chris88 is offline
Mein Auto: bmw x3 F25
Hallo Beer55
Experte bin ich vielleicht nicht, aber spreche deutsch, und hab schon einige Sachen erfolgreich codiert an meine f25
Grüsse aus der Schweiz, Chris
Old 09-07-2012, 10:36 AM
esmond esmond is offline
Mein Auto: 740i F01
help to send links of 47.4 to gpssg at hotmail
really appreciated. thanks.
Old 09-07-2012, 08:05 PM
Check your email.
Old 09-08-2012, 06:10 AM
drkay drkay is offline
Mein Auto: F25 N55 Vermillion Red
Fixed, copied files per directions. Had to create "e-sysest" folder on "C" drive as it did not exist. Will try on vehicle soon.
Old 09-08-2012, 09:10 PM
lufei lufei is offline
Mein Auto: f18-535li
mistake at
First time full backup of Car's configuration files:
12.Right click on each green CAFD and click on "Read Coding data". Afre codes are read, green icon will change into a folder icon.
report -"1" Errors
Transaktions-Report: Aktion:Codierdaten lesen
CAS[40]
readCPS O.K
cafd_0000000f-005_022_007 Fehler:
File for "cafd_0000000f-005_022_007" not found***65281;[c012]
Pls tell me how can i do ?
Thanks.
[IMG]http://www.autoimg*****album/userphotos/2012/9/9/500_7df3_bb4e670a_bb4e670a.jpg?7291[/IMG]
[br]
[IMG]http://www.autoimg*****album/userphotos/2012/9/9/500_4581_d751054e_d751054e.jpg?7806[/IMG]
Old 09-08-2012, 09:14 PM
Mein Auto: X3 2011
Give us more info to understand your problem better. Your car model , psdz day used?
Are you able to read any other cafd file?
Old 09-08-2012, 10:11 PM
sorry, i am chinese. so don't good at english.
my car is 2012 F18 535Li
what is mean of "psdz day used" ?
i can't read any cafd file.
it said can not found files.
Old 09-08-2012, 10:14 PM
my soft is E-SYS 3.184 + PSDZdata v.46.6
E-SYS 3.184 download from
http://www.bimmerfest.com/forums/sho...d.php?t=624780
v.46.6 PSDZdata download from
http://www.bimmerfest.com/forums/sho...d.php?t=632736
Old 09-08-2012, 10:28 PM
Mein Auto: X3 2011
If you are able to read at least few cafd files, it's then just psdz data set issue. Change to 46.3 or to next higher version.
Old 09-08-2012, 10:32 PM
i can't read any cafd files.
psdz now is 46.6 new than 46.3 ?
how can i do ?
thanks.
Old 09-08-2012, 10:48 PM
Mein Auto: X3 2011
Please read the manual installation steps and see if you have followed correctly. Also have you assigned the key to E-Sys?
Old 09-09-2012, 09:01 AM
Coding CAFD files:
9.Select the edited CAFD file on SVT box and Click on "Code FDL" in coding box on right.
said "Failed to sign FDL [C158]"
I think it is "Code Away.est" files wrong. [from bmdcoding pin=2690]
Can u tell where to download it ?
Thanks a lot !
Old 09-10-2012, 07:44 AM
i can download from car and and i can upload to car now.
i can edit it. but i can't save it.
why ?
Old 09-10-2012, 07:45 AM
i can give you cafd files.
can u help me to do edit ?
and sent it back to me after edit.
i can upload it to my car.
i want to fix dvd in montion.
Old 09-12-2012, 05:05 AM
JamesShih JamesShih is offline
Mein Auto: E92 335i Coupe
Can anyone send me the downlink of psdzdata v47.4?
Thank you.
Old 09-12-2012, 05:44 AM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Thank you.
PM Sent.
Old 09-12-2012, 05:51 AM
why ?
Are you getting an E-Sys Error? If so, what exactly is the error?
Is your problem just with HU_CIC? Are you able to FDL Code other ECU's and save the coding?
Old 09-17-2012, 07:29 PM
Jrbust91 Jrbust91 is offline
Mein Auto: 2009 750Li
After I make changes and "code FDL", I read the file again and it does not show my changes it shows the previous values, is this normal? Does it take time to update the values also?
Old 09-17-2012, 07:37 PM
It's immediate as soon as the FDL Coding is complete. You are hitting the Save Icon after making your changes and before FDL Coding? After you FDL Code, does it show that it was successfully processed in the Pop-Up Window?
Old 09-18-2012, 09:42 AM
yes, save changes, back green arrow, select module, code fdl , goes through no errors, but the change is not reflected when I read the module from the car.
Old 09-18-2012, 09:59 AM
What E-Sys version are you using?
Is this happening on every FDL Code you make, in multiple ECU's, or have you tried just one ECU, one FDL Code?
Old 09-18-2012, 10:21 AM
This is mainly happening on the CAS Module 3003 FH MASTER, trying to code the fold in mirrors, this is on a 09, 750 I beleive it is F002 chasis, using the F10 cheat sheet.
