#176
Some scary stuff
I have become very aware of cooling system problems with this model since being on this forum ,my old e28's used to leak @ the plastic side tanks seals after huge mileage and in many cases it was no more than a small weep.
I have really enjoyed this post(cheers to bluebee and others), would I be right in saying the failures of parts are restricted to certain models? my car has had thermostat housing and vuscious fan done and so far no probs on 208,000kms. When I purchased my thermostat housing the seller who has a lot of experience servicing bmw's told me this part is a big seller due to the fact they are made from new with recycled plastic from the factory,he went on to say he had no returns on his part as it was made from virgin plastic (aftermarket),your comments please. Our car does a huge mileage every week on long open roads any evidence of this being better for a cooling system? Last edited by E39 touring; 12-31-2011 at 11:26 PM. Reason: spelling |
#177
They both stink. As for failures, here's yet another related failure posted just today (although this may have been due to road debris): - So I found what made a horrendous noise in my engine the other day.. Quote:
#178
For the record, today a 540i owner found his "cooling system voltage regulator" broken:
- E39 (1997 - 2003) > BMW repairs, identify part Quote:
#179
Yet another disintegrating fan blade situation:
- E39 (1997 - 2003) > Broken fan blades Quote:
#180
Mine cracked on the way home from work Fri when I decided to go around someone in a deep cell call doing 30 in a 45. After I passed him, I looked back and noticed that the 540 now had a smoke screen. Pulled into a parking lot and had AAA flatbed it 3 miles to home. Replaced the radiator tonight and had only lost 1.75 gals of coolant. I will be replacing the rest of the poopy coolant system this spring.
This little SOB was replaced this past Sept. As you can see, no cracks. ![]() ![]() And here is the crack... ![]() The replacement(Behr/Hella ![]() And here's the one from BMW back in Sept that I managed to get out of the old radiator without breaking it. Just a little difference... ![]() I found it much easier to remove/replace the radiator through the bottom, not pulling it upwards, even with the fan left in. I did have to unscrew the brake ducts for a little more room.
Life is too short to drive fwd cars. ![]() MNBMW.COM |
#181
The red arrow is where my radiator seems to be leaking!
94 530i sold (That was difficult for me) 01 530i >144,500+ miles SOLD ![]() 06 330XI winter's especially fun drive (SOLD) 10 M3 Sedan (sweet) 13 Nissan GT-R Black Edition ![]() 13 Porsche Cayenne Diesel ![]() BMWCCA 4215 |
#182
For the crosslinked record, this thread today shows how a German-made Behr expansion tank failed:
> E39 (1997 - 2003) > BEHR expansion tank leaks after 5000 miles
#183
Many miles on my 523i touring (135,000 @last count) have done top plastic pipe (thermostat housing) viscous fan coupling and I check the gauge and system for problems as often as possible,look around the refill tank and the hoses,the top plastic pipe fails early in life mine did as did the viscous fan.
The top hose mounting in the radiator is a failure point,but don't run around waiting to replace your whole cooling system untill you have problems if you are on a budget,not all the problems on this forum happen all the time or to your car ,just watch your temp gauge. |
#184
My car has 142k miles on the original radiator and expansion tank. No leaks, no overheating.
I don't like replacing everything without having a reason. These parts look o.k. I check these and also the belts every few thousand miles. Is there anyone here having the original rad + exp tank with more mileage than my one? I saw horrible failures in this topic but I don't have an objective picture what is the average life time of a radiator. Many owners are not reading bimmerfest and many of the readers have no issues with the radiator, so they don't post here. |
#185
Consider that if any part of this already weakly designed system fails, it very well could mean the end of your engine. I was very fortunate that it happened where it did. The car was packed for a 400 mile trip and we were ready to take off when it let loose. We took the Camry (you know, the sensible, reliable brand)and when we got home I just pushed it into the garage and did the repair.
Either you are part of the solution, or you are part of the problem. Last edited by occhis; 03-09-2012 at 06:25 PM. Reason: add info |
#186
As if we didn't have enough places to look for leaks, RDL posted today that his plastic bleed screw leaked up the middle!
- -> E39 (1997 - 2003) > Leaking Bleed Screw
#187
Well, it's 'my' turn again!
I noticed a puddle on my driveway today ... So I started looking for the telltale white spots: And, watching for a while, I found the culprit! Note: I last replaced my Behr expansion tank in 2010 as noted by the markings on the side.
#188
You know, there's just no excuse for that substandard plastic garbage. It makes me so mad to think about it. I'm on my third one and I know my number will come up again sometime. Any thoughts about switching over to the Evans NPG product?
I'll have to dig though to see exactly where the leak is coming from (it could be the small drain hose, for example). I won't know 'till I disassemble.
#190
Yet another crack in the neck ...
#191
Thanks for posting my story Bluebee! I was about to add my $0.02.
Just an update, I found a radiator shop close by that replaced the radiator and the upper and lower hoses for about $500. Only had it a day so far but it seems to be good. I agree that if you replace the radiator go ahead and get the hoses changed. My upper one was okay but the lower hose was softer than a sponge. My car is around 84k miles as well but has spent the past 4 years in HUMID Texas heat which I'm sure played a role.
2003 525i | Sterling Gray Metallic |
#192
Thank you for the update. So few people do that - but - it's very useful - especially for the newbie (we all were once) to see how others handled the same issues they're seeing, years later.
We all stand on the shoulders of others!
#193
There are pics of zip-tie fixes of broken radiator fan shrouds in this thread today:
-> E39 (1997 - 2003) > Fan Shroud ? Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 10-05-2012 at 09:37 AM. |
#194
Yet another BMW E39 cooling system engine fan explodes - due to a variety of potential causes:
#195
I have been happy with EROparts bits they are sold for many brands of euro cars and have used them on my VW's to good result.
#196
This thread today showed nice pictures of the heater hoses which were leaking on a user's V8:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 12-13-2012 at 05:06 PM. |
#197
when my expansion tank cracked, the crack was invisible. I've got great eyes and I couldn't see anything!! It wasnt until I pressurized the system that I would see coolant seeping out of the plastic. It was quite odd, it looked like coolant was magically appearing out of the plastic!!
I purchased a new expansion tank at my local BMW dealership, and they told me that my new part is covered under a 3 year warranty, parts AND LABOR!! Even though I replaced it myself, they said if it fails again within three years, THEY will replace it FOR ME!! Wow! Last edited by fullthrottle540; 12-13-2012 at 07:18 PM. |
#198
Besides why rip out parts and change when many of the replacements are not up to the mark. The one that gets me is the BMW main agents that when you go in for a service say by the way you need to do this and do that,wake up and see they make a good mark-up on the parts and there inflated labour charges thats what its all about. |
#199
Another M54 fan explosion today - this one tracked to a bad fan clutch:
> E46 (1999 - 2006) > What the heck happened to my fan??? Quote:
#200
Parts, if anyone wants them.
I have a radiator, expansion tank, fan, fan clutch, and cowl sitting in the garage I would like to get rid of if anyone is interested. I took these out of my 540i6 in 2006, back when my car had about 32000 miles on it and this stuff has been sitting in the garage since. The radiator won't fit my 540iT, so I am unlikely to use thus stuff.
Here is my post from the 2006 Zionsville install: http://forum.roadfly.com/threads/113...System-Install
HRE 543s w/Michelin Pilot Sports Koala Quaiffe LSD w/ 3.38 Gears H&R Springs/Bilsteins Eibach sway bars Zionsville Alloy Radiator and Cooling Kit Authority CAI and ECU tuning M5 calipers, EBC Green Stuff pads, European M5 floating rotors SprintBooster Eurodash Euro armrest w/ tray Rogue Engineering Tranny Mounts Aspheric Mirrors V1 in Center Rear Headrest w/Remote Display in ashtray Lidatek (custom dash switch) M5 grills Debadged Saab license plate frames & trunk handle |
