Old 09-11-2012, 09:16 AM
SeanPhang SeanPhang is offline
Mein Auto: 02' 530iA/steptronic@123k
Talking VANOS done without much difference
Well, I did my VANOS this past Saturday. My alternator needed to be replaced, and I took out the fan and fan shroud for easier access. So I decided to do the VANOS, because the beisan kit has been sitting on the shelf for half a year now!
The alternator job was very easy. For the VANOS, the hardest part for me was to open up the valve cover, because the gasket was so plasticized . But I kept at it for about 10 minutes and it finally gave way. And the sight of the camshaft and the timing chain was truly beautiful. Also, when taking out the mounting bolts for the valve cover, be very careful not to drop the washer into sparkwells!!! I dropped one, and wasted like an hour getting it out because it fell to the very bottom.
After doing the job, no SES light or anything, didn't even encounter the initial startup hiccups mentioned in the procedure. But I also didn't feel much improvements, definitely not the 'wow' I was hoping for. I've driven it about 40 miles after the job now. The only thing I can think of which I am not 100% sure I did right is that when putting back the vanos unit, the procedure mentioned to 'push the intake piston to mate with splined shaft', which I did try, but the intake piston would not move at all, so I assumed it's already mated and moved along.
I researched on the site about this and Raj mentioned a bunch of issues like vacuum leaks which will mask the improvements. So I guess I have some issues to hunt down before feeling 'mental erection'. The bad (kind of) thing is I don't have SES light to guide me to any apparent issues.
All in all, I am still glad I did it, because the original seals are definitely bad, and I changed the valve cover gasket, which has been leaking oil. If anyone has insights and suggestions, please comment. Much appreciated!
06/10: rear shocks
08/11: cooling overhaul, O2 sensors
09/11: auto transmission drain & refill
09/12: alternator, VANOS seals, differential oil change
04/13: 2nd auto transmission drain & refill, changed fuel filter
Last edited by SeanPhang; 09-12-2012 at 07:25 AM. Reason: change title icon to reflect mood
Old 09-11-2012, 09:21 AM
doru's Avatar
doru doru is online now
Mein Auto: 2003 530iA
Because there was a "patch" to cover up the vanos issue. Every car that went in to the dealership after 2002 or 2003 for any reason (free checkup etc, under warranty) got that treatment. For the M54B30 engine the difference is very subtle, and you might feel it in a week or two. try to disable the traction control, put it in steptronic, and give it some gas at a stoplight. I can bet you will spin tires, which before you couldn't. I know, I can.
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 09-11-2012, 09:35 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Is it Safe to Dance?
Mein Auto: 2001 540i/6
Maybe your vanos wasnt bad yet or the previous owner already installed them. Were the old seals the same color as the new ones?
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 09-11-2012, 09:37 AM
See before and after VANOS tests here:
- How to objectively test VANOS seals in operation (1)
Old 09-11-2012, 09:38 AM
The seals are never replaced before. And the pistons could freely move in the cylinder when I took them out, which was definitely not good, I think.
06/10: rear shocks
Old 09-11-2012, 10:08 AM
Fudman's Avatar
Fudman Fudman is offline
If the old O-ring seals were rock hard, they were the original seals. The new Viton seals feel like rubber and will stay that way. The outer teflon seal feels hard and stiff always. Give it a few hundred miles. The seals need to break in. Then report back.
Old 09-11-2012, 10:32 AM
Fudman, I am paying close attention to the car's performance during this break-in period. Will report back after several hundred miles. Will also try doru's suggestions.
BTW, I also added a small metal mesh to the alternator air duct near the fog light. Because the old alternator has a bunch of trash trapped in through there.
06/10: rear shocks
Old 09-11-2012, 11:50 AM
gchand's Avatar
gchand gchand is offline
Mein Auto: 03 530i sport
Sean,
Sounds like you did the right things - VANOS seal upgrade certainly can't hurt, taking care of the need to replace the VCG, and the screening of the alternator air duct is a great idea.
I have the Besian upgrade kit too waiting for time to install, but do not have any of the negative performance effects listed for the OE seals so don't really expect any noticeable difference if I get them replaced soon.
Old 09-12-2012, 05:22 AM
Old 09-12-2012, 06:45 AM
Ed Cheung Ed Cheung is offline
Mein Auto: E39
that is gross....
96 528i AT w/steptronic. => 97 540i w/ steptronic.
Old 09-12-2012, 07:02 AM
Well. I drove the car yesterday. And as doru pointed out and I paid attention, I felt something new when a red light just turned green and I applied the pedal. It was definitely much snappier than before, especially in the 1500-2500rpm range! It feels great (again)!
06/10: rear shocks
Old 09-12-2012, 07:10 AM
bkgreene39's Avatar
bkgreene39 bkgreene39 is online now
Mein Auto: 1998 BMW 528i
how did it feel in first gear before vanos upgrade?
Old 09-12-2012, 07:14 AM
I have an auto and I think it starts at 2nd gear by default to save gas.
06/10: rear shocks
Old 09-12-2012, 07:17 AM
Mein Auto: E39
And you will find it more willing to be on 5th gear. When I still have the 528, it will stay on 5th only on or above 100km, after the vanos seal done, it will stay in 5th at 80km.
Old 09-12-2012, 07:21 AM
That will be good for my wallet, I guess. How do you know you are in which gear though, by feel?
06/10: rear shocks
Old 09-12-2012, 07:27 AM
doru's Avatar
If you put in "sport" - which is the shift lever to the left, then it will start in 1st gear, and will hold gears longer. the next step up is "steptronic". If you want to take full advantage of steptronic, you need to re-flash the auto-tranny with the ESS tuning or Dinan software.
Old 09-12-2012, 07:37 AM
I bet you'll notice something different! I noticed it only 50 miles after installation.
Originally Posted by gchand View Post
Sean,
06/10: rear shocks
Old 09-12-2012, 07:39 AM
Being a poor grad student, I seldom put the knob to the left. But I guess I will indulge myself for a while and fully enjoy the car with the new seals!
06/10: rear shocks
Old 09-12-2012, 07:54 AM
bkgreene39's Avatar
Do it here and there, you will def enjoy it! have fun with the vehicle thats why you own it and put work into it. My vehicle came before steptronic, i have the 4 speed gm tranny with the s1, s2, s3, options. When i want to launch in first i put it into s1, yea fuel economy sucks for sure but thats to be expected.
Old 09-12-2012, 08:38 AM
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
Maybe your vanos needs some Viagra or Cialis!
2002 530i
alternator, vanos
