E34 (1989 - 1995)
Old 08-12-2012, 07:11 AM
holly079782 holly079782 is offline
holly079782
Mein Auto: bmw e34 2.5i
Bmw e34 washers
Hello, Can any body help with this?........
I recently had to move the washer fluid resevoir to gain access to an awkward screw on the headlights.
I have since moved it back to its correct position but the washers are not working properly?
The spray is weak and the motor is making a high pitch sound?
Any help would be much appriciated
Old 08-12-2012, 10:37 AM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
Make sure you have all the hoses plugged in tightly and not pinched anywhere . And that there is enough fluid in it .
Sent from my Desire HD using Bimmer App
Old 08-17-2012, 02:54 PM
holly079782
washers
Hello, Thanks very much for your reply. I haven't had chance to look at it properly but your info is much appriciated. Will have a look this weekend. Thanks again
Old 08-17-2012, 10:32 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
might have run out of water. also i think the stock E34 is the same setup as E30s in that the motor is mounted on the side of the washer bottle? make sure this is sitting down snug.
E30 above Sold
Last updated 2nd January 2014
Old 08-20-2012, 08:50 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
Could be the nozzles finally plugged up too. It's kind of a drag to detach the hood liner, but it's worth giving a full check-out of the entire plumbing if time permits.
Good food, good people, good times.
Old 08-21-2012, 02:22 PM
Weisebar Weisebar is offline
Mein Auto: E34 525i
If you find that your jets on the hood are clogged get yourself a needle from an accupuncture practitioner and clean out. Works great.
Old 08-21-2012, 08:15 PM
paperplane94 paperplane94 is offline
Mein Auto: 1989 525i M20B25
If the motor is making a high pitched whir then it is starved of fluid.
Make sure there is something in there and that their are no blockages.
Old 09-12-2012, 12:53 PM
Radian's Avatar
Sometimes, they can be truly stuffed and just need to be replaced.
