Door Chime
I have a 2002 330ci The remote locks dont work I have done the key reprograming several times with no success. In conjunction to the remote not working the door chimes chime with the door open and no key in the ignition. What could this be? Had the front windsheild replace along with the rain sensor. The wind sheild was replace due to taking a hit from a foul ball during my daughters softball game. Dont know if the the problem started then or not. Does anyone have any idea what would cause the door to chime when door is open with no key in it and the remote not working. Any ideas would be helpful.
Silly question, but it has to be asked: Are your headlights on?
Freude m Fahren. |
no
Sounds like the car might think the key is still in the ignition... you cannot operate the keyless remote with the key in the ignition. The "sensor" in the ignition may be sticking... just a fleeting thought.
Thanks, E46_Ci do you know where that sensor is and how hard it is to to replace or even test. Your exactly right it is acting like a key is still in the ignition even though ther is not one.
Thanks |
I'd get a can of electronic contact cleaner spray and blast away at the keyhole. Then, spray a small amount of high quality "dry lube" to ease key insertion and rotation. The sensor is just a mechanical microswitch prone to sticking with the grime of the ages.
2006 325Ci |
I had a can of air. I blased the key hole and did put the graphite lube into the key hole. Still no change. I give it a couple of days for the lube to work it way throughout the key area. I quess we will wait and see if this works in the next couple of days. In the mean time any other solutions I could apply. Thanks
I don't think air is enough. If the mechanical sensor is stuck due to grime mixed with old lubricant, you need some sort of solvent to dislodge the contaminants.
2006 325Ci |
radio shack fo rthe cleaner???
I bought the spray cleaner and blasted the key hole and reapplied the graphite lubricant. Still getting the same response. Car chimes when key is out of the ingition, the door is open, light off and key fob remotes do not work. Any other ideas on a possible solution.
Thanks in advance |
This problem is fixed. It was a fuse.
lesson learnt ALWAYS check your fuses 1st
same problem
The name is jaymie. I'm new to the forum and I have been having the same door chime with no key door open and my key fob does NOTHING
. I checked fuses first and my fuse # 67 is blown. The thing is when you insert a new fuse the fuse arches as soon as you touch the metal in the fuse hole and then blows.
