Today on my Bimmer I... - Page 269 - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-11-2012, 10:11 AM
Milla Milla is offline
Mein Auto: 00 M5 DINAN S, 97 M3/4/5
Let's see if I can get my leather to a better state... my Vaders are much better than these seats and they're older
[ 97 Techno Violet M3/4/5 | 01 Phoenix Yellow M3 | 00 Imola Red M5 DINAN S1 | 09 335d Water Blue ]
I own heels and a clutch pedal.
I support Central Florida BMW Owners & Fello Racing!
TWITTER/millakins | INSTAGRAM/millakins
____ NURPLE ____ M3PO ____ MCINQUE ____
Old 09-11-2012, 10:44 AM
Groznyy_Volk Groznyy_Volk is offline
Mein Auto: 1999 323i (E36)
Originally Posted by E36 Phantom View Post
It's not eBay's fault, it's the LEDs fault. The car measures the resistance on each lighting circuit, LEDs have lower resistance, so the system thinks a bulb is out. Anytime you upgrade to LED's, you need another resistor on the circuit to keep it from doing that.
Hmmm. I see. After doing some reading online, I ended up ordering "error free" LEDs last night (8 bucks for a pair). I'll probably just end up using the current ones for interior lighting instead.
"Horsepower is how fast you hit the wall. Torque is how far you take the wall with you."
E38 99' 740iL (02/07 - 06/12)
E36 99' 323i (07/12 - 06/14)
E46 01' 330i (04/14 - Present)
Old 09-11-2012, 05:45 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Originally Posted by ZeGerman View Post
Rear vent window seals and sills, plus a trunk gasket and the front cowl. Oh, and those "SRS Airbag" tabs which go on the door panels.
Sweet! Sorry I couldn't relay more info Karl, been really busy lately.
Today on my E30, I think I found the problem with it not running.
Turbo Build Here
Old 09-11-2012, 05:57 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
Well what was it?
-CJ
Old 09-11-2012, 09:12 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yeah, not worries man. I took a close look and found that the rubber with the felt which goes around the entire perimeter of my vent windows is fine, and it's just that other smaller and less expensive seal which has deteriorated. That's good news, since the felted rubber things are like $65/ea, and the ones I ended up needing are $14/ea. Can't wait to get that stuff replaced, then I'm going to plastidip the shadow trim to clean it up. I'm expecting it to turn out pretty well, since plastidip seems like the perfect substance for such things.
I wasn't too happy about buying a new trunk seal, since they're somewhat expensive, but I've been trying to chase down a small leak for years. My current trunk seal looks fine, but whether it's doing it's job when the lid is closed is up for debate. Every once in a while when it rains, I will find about a tablespoon of water in the spare tire well. Not only are my taillights fairly new, with beefy gaskets, but I even went so far as to use special caulk on the gaskets to really seal things up. Didn't make a bit of difference, so the hunt continues... It leaked the exact same amount before I changed my taillights, anyway, so I don't think they're the cause. I'm just trying to get all my seals and other cosmetic things taken care of before the rainy season starts up again.
1998 BMW 328is
1966 Pontiac GTO
Old 09-11-2012, 11:10 PM
Eight Thirty Eight Thirty is offline
Hellawut??
Mein Auto: who knows?
Karl could it be leaking into there Via the drainage ports on the sunroof cassette?
check that seal out.
I know there are 4 drainage tubes in the coners of the car. not sure where they go though.
-Franklyn
Old 09-12-2012, 12:14 AM
E36 Phantom's Avatar
I Am The Machine
Well, tonight was rather disappointing. Discovered the radiator is shot, has a breach in the top seam. Also, cooling system is pressurizing like no other which is probably what caused the breach. That's what made me think the water pump was shot, but really it was coolant spraying from the rad onto the fan and getting flung up. Looks like a hg breach between a coolant passage and a cylinder.
Anyway, flushed the coolant system and got warm compression numbers, they're lower than before.
I'm concerned that the blue devil treatment won't get into the proper places without full cooling system pressure, but I'm afraid to replace the radiator just to have it overpressurize and blow again. Ugh.....thoughts?
Sent from my Galaxy Tab using BimmerApp
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 09-12-2012, 04:53 AM
Needs Boost
Mein Auto: Red Sled
Chad, I have severe coolant pressure from my blown mls but haven't messed up any cooling parts or had a leak
Sent from my ADR6400L using Bimmer App
Turbo Build Here
Old 09-12-2012, 05:36 AM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
When I did the HG on my car, there was that copper sealer crap all in the head. It took the machine shop 4 washes in a tank to get the stuff out of the coolant passages. It seems as if you just need to bite the bullet and fix the HG. If the blue stuff doesn't work (sounds possible), the HG job will be even more of a PITA.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 09-12-2012, 06:38 AM
C14 Rider's Avatar
C14 Rider C14 Rider is offline
Mike
Mein Auto: 2010 Audi S4
I picked up some LED's for the footwells out of a chrome shop...
Now if I can just get loaded and headed home (I'm in Atlanta in the Peterbilt) nothing ever goes as planned in trucking I swear..
2010 Audi S4 Premium Plus/3.0L Supercharged V6/Quattro/6 speed/25k and climbing/
Old 09-12-2012, 09:05 AM
ZeGerman's Avatar
Warm Leatherette
The sun roof drains underneath the car, and when clogged, will fill up the interior floorboards. I'm 99% certain they don't go anywhere near the trunk.
1998 BMW 328is
1966 Pontiac GTO
Old 09-12-2012, 10:46 AM
JoshuaG's Avatar
JoshuaG JoshuaG is offline
Natasha 95M3
Mein Auto: 95' E36 M3
What about under the battery? Under my battery I have a small hole for a battery vent. I found out too late that the grommet was bad. I’ll be welding a new panel in there soon. Water was spraying up from road and ended up in the trunk.
Originally Posted by kaos_325i View Post
Maybe I haven't been here long enough to realize the knowledge you have to share. But, from all I can tell you are just an over opinionated, rude, prick.
My .02
Old 09-12-2012, 02:55 PM
ZeGerman's Avatar
Warm Leatherette
Originally Posted by JoshuaG View Post
What about under the battery? Under my battery I have a small hole for a battery vent. I found out too late that the grommet was bad. I'll be welding a new panel in there soon. Water was spraying up from road and ended up in the trunk.
This is a great idea, but I don't think it's my problem. I inspected the grommet in the past, and it looks fine. More importantly, water still gets in even when I don't drive the car for days. I clean up any water I find, and it will come back eventually if we have a good rain, even if the car doesn't move at all. This leads me to believe it isn't getting in via the grommet. Another thing I had considered was the rubber boot which goes around the gas filler inlet. Mine was originally pushed in around the edges, and I thought that might be the source, but I put it back so everything was correctly installed, and it didn't change anything. I'm not sure if water getting in there would go to the trunk, anyway. Haven't looked at it closely...
1998 BMW 328is
1966 Pontiac GTO
Old 09-12-2012, 03:00 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
Got fold down seats Karl?
Get in there and have someone run a hose over the car (if you havent done that already)
-Dino
Old 09-12-2012, 03:06 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, I have folding rear seats. The only reason I haven't done that is because I was hoping I could find it without needing to disassemble the entire trunk, which I think will be necessary. At any rate, the trunk seal will be on my doorstep in a week or so, so I'll give that a go and then up the ante if it doesn't fix it.
1998 BMW 328is
1966 Pontiac GTO
Old 09-12-2012, 03:14 PM
JoshuaG's Avatar
Natasha 95M3
Or as messy as it sounds hit the spair wheel well with talc and folow the wet spot..... this reminds me of a bad joke...
My .02
Old 09-12-2012, 03:20 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
or a good joke
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '14 GMC Sierra SLE Z71
Old 09-12-2012, 06:08 PM
dc_wright's Avatar
dc_wright dc_wright is online now
What about the antenna base grommet and the antenna base?
Old 09-12-2012, 06:12 PM
Needs Boost
Mein Auto: Red Sled
What antenna?
Turbo Build Here
Old 09-12-2012, 06:48 PM
dc_wright's Avatar
Oops! Forgot only verts have the antenna mounted on the right rear fender......
Old 09-12-2012, 07:09 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
tail lights, trunk seal...possible rear window seal...these are the places i would check.
but apparently the e28's have a bad habit of leaking around the rear lights....so i would double check them on the e36.
i would assume the proceedure to repair is similar.
df
Old 09-13-2012, 06:01 AM
Kdoherty's Avatar
The vcg is going smoothly I never expected how clean my head was. The old vcg is as hard as the valve cover plastic though
Old 09-13-2012, 06:06 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Check out that varnish!
Mine was as hard as the cover too. At first I was wondering where the gasket was, then realized the hard crap on the edge was the gasket!
I should have replaced the rubber grommets though. Still leaking a little bit.... Le sigh.
Looks good though chief.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 09-13-2012, 06:21 AM
Kdoherty's Avatar
brutal i thought i was in luck because i have an in/lb clicker trq wrench.... too bad it bottoms out at 120in/lbs....
Name:	Photo on 9-13-12 at 9.20 AM.jpg
Old 09-13-2012, 08:34 AM
ZeGerman's Avatar
Warm Leatherette
Yep, we don't have "antennas". Well, we do, but they're hidden in a top secret location.
1998 BMW 328is
1966 Pontiac GTO
:3
