Old 06-27-2012, 05:51 PM
grilodan grilodan is offline
Mein Auto: E70 X5 35i Sport Activity
Damn it ... this is painful.
- 2013 X5 35i Sport Activity (Born 08/12) - Titanium Silver /Oyster Nevada /Dark Bamboo - ZCV /ZCW /ZPS /Sport Package /Adaptive Drive /Soft-Close Doors/Running Boards /HUD /Shift Paddles /Comfort Seats /6NR /6NF
- 2011 535i (Born 08/10) - Titanium Silver /Black Dakota /Anthracite - ZCV /ZCW /ZPP /ZP2 /6FL /6NF (Sold 08/12)
- 2010 335i (Born 02/10) - Titanium Silver /Black Dakota - ZCW /ZPP /6FL (Sold 09/10)
- 2007 328i (Born 07/07) - Jet Black /Black Dakota - ZSP /ZPP /6FL (Sold 04/10)
Old 06-29-2012, 08:53 AM
ImSW1 ImSW1 is offline
Mein Auto: F10
I've literally activated every option related to tires I could. I've turned off TPMS and turned on FTMS. I've had both of them on at the same time. I've seen more errors and codes flash up on my dash than I care to see. I've swapped out my current wheels with my stock wheels to see if anything would show up even though both sets have BERU sensors in them. Nothing but the dashes, the labels and green tires.
Zilch, zip, nada when it comes to actual readings...pure frustration. I've pretty much given up since there is no specific trigger or pattern to why it doesn't work. It's just random and I don't like random.
Sean
Old 06-29-2012, 04:49 PM
Stealth.Pilot's Avatar
Stealth.Pilot Stealth.Pilot is offline
The Driver
Mein Auto: 2013 M5
Has anyone tried just buying new TPMS sensors?
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP
Old 06-29-2012, 05:46 PM
dmunz dmunz is online now
Mein Auto: 535i GT
What about wheel size or tire brand?
As long as we are diggin deep here...
Could it be tied to having different sized wheels (front to back) or the tire brand?
If you guys want to post, I'll add this to the spreedsheet and put up another copy.
For me:
2012 535i GT
TMPS: no data
Wheels: 19" and different
Tires: Dunlops
ISTA/P: 2.45.1 / 2.45.2
FWIW
DLM
"...hovering like a fly waiting for a windshield on the freeway..." p.g.
Old 06-29-2012, 08:21 PM
I hear you Sean. I did the same and got no results.
As for wheels, I have OEM 18". Same size back and front. Never changed.
Old 06-30-2012, 05:27 AM
Erregend's Avatar
Erregend Erregend is offline
535i M-Sport ED May 2011
Mein Auto: '11 M-Spt 535i & '04 SLK
I bought 17" rims with all-season/winter tires from TireRack and included the sensors.
Coded the TPMS with them mounted...works great with pressure and temperature accurately displayed.
Remounted original BMW wheels with summer tires last week. Display works fine after TPMS reset.
(I need to confirm, but I think this set of sensors is not nearly as accurate as the set from TireRack.)
Old 07-02-2012, 11:40 AM
Sean,
Just coded a post 09/10 2011 535 and it worked like a beauty within the first 50 feet of driving. I think it is safe to assume that all 2011 F10 before 09/10 do not have the right hardware to allow pressure and temperature to display.
As for the 2012s we have here, I have no clue as to why it doesn't work. But I have yet to witness a pre-09/10 car work.
Old 07-17-2012, 11:52 AM
radarguy radarguy is offline
Mein Auto: 2011 535ix sport
Yes!
Better late than never. I finally coded the TPMS today and it works. The front left is about 7 deg F hotter as others have reported and the pressures track my handheld gauge within 0.5 psi.
Model: 535 xDrive w/ Sport Package, DHP, Sport Tranny (not M-Sport)
Build Date: Jan 2011
Status: Working
Did you ever change the wheels and/or tires: Yes
TPMS Type: Metal Stem
Tires: 19" LS2 replaced with 18" ContiProContact SSR. Replaced wheels, TPMS and tires Oct 2011 with BMW wheels and TPMS
Air/Nitrogen/Other: BMW approved mixture of 78% nitrogen 21% oxygen, 1% more exotic gasses
Old 07-17-2012, 10:04 PM
wonfuk wonfuk is offline
Mein Auto: 2012 TiAg 535i M-Sport
Model: 2012 535 M Sport
Build Date: 3/12
Delivery Date: 6/12
Status: Working
Did you ever change the wheels and/or tires: No
TPMS Type: Metal
Tires: Pirelli
Air/Nitrogen/Other: Air
2012 TiAg 535i - Black Dakota Leather, M Sport/Prem/Tech Pkgs, Sport Auto Trans, Heated Seats
(retired) 2001 Topaz Blue 530i
Old 07-30-2012, 07:51 PM
marcosg marcosg is offline
Mein Auto: 2011 BMW F10 528i M Sport
I have a 2011 528i M Sport (build 2/2011). Can someone please refer me to the working coding instructions for TPMS. I will try it and report back.
Thanks in advance.
Old 07-30-2012, 08:12 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
Thanks in advance.
Code HU_CIC / 3001 EXBOX - RDC_SAFETY = aktiv / Werte=01.
It's for TPMS, and not FTMS.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 07-30-2012, 08:18 PM
Thanks Shawn for your promot response.
What about HI_CIC / 3001EXBOX - RDC, should this be set to aktiv as well?
What is the difference between TPMS ad FTMS?
Old 07-30-2012, 08:24 PM
I'm not sure from memory on HI_CIC / 3001EXBOX - RDC, although I would think so.
TPMS is Tire Pressure Monitoring System, aka Reifen Druck Control (RDC) and FTMS is Flat Tire Monitor System, aka Reifen Pannen Anzeige (RPA). If your valve stems are rubber instead of metal, you have FTMS. FTMS operates on tire rotational speed and has no actual sensors to measure pressure and temperature.
- BMWCCA #446923
- flick
Old 07-30-2012, 08:46 PM
Thanks again.
I have coded the car accorindgly and will be going for a test drive.
I just want to confirm that I have the right setup and sensor.
Attached are two photos of the metal tyre valve. Is the correct one?
Also atttached is photo of the Tyre status, It is displaying "Flat Tyre Monitor Active". Is this correct?
Thanks,
ID:	334964   Click image for larger version
Old 07-30-2012, 09:01 PM
Thanks again.
Thanks,
The Stems look rubber and the display reads FTM Active, so I don't think you have TPMS.
TPMS would read TPM Active.
- BMWCCA #446923
- flick
Old 07-30-2012, 09:53 PM
Old 07-31-2012, 03:54 AM
I would drive it for a few miles first just to see. The valve picture looks like the correct ones and maybe they just use a different call out in Austrailia.
After all, they spelled tires incorrectly.
Old 09-12-2012, 09:27 PM
bmguy bmguy is offline
Mein Auto: 550xi
Well, to revive an old thread!
I have gone out on a limb, expecting to be lucky and get the TPMS working; No such lic; I went and picked up, and had installed part# 36 10 6 856 227 in each tire.
I had turned one what appears to be the one value related to this; and no luck; The tires are all green, display "--" where they should be a number. I drove for about 25km on them, hiway and no luck;
Like other comments I have seen, even after turning on TPMS, the screen still shows "flat tire monitor active"
it sounds like it should not be doing that? any idea's how to change this?
also; any way to confirm that these cars have the required receiver in the wheel well? visually?
if someone can send a picture of what to look for with this part, I can see if I can find it in my car, maybe they didn't install the receiver and hence the trouble?
Is there any other fields I should activate or try?
Old 09-13-2012, 07:38 AM
Chuck W.'s Avatar
Chuck W. Chuck W. is offline
Mein Auto: 12 BMW 535I MS Alpine Wht
I am guessing this is a software issue. I had my car coded and had the TPMS PSI/Temp Data working. Then, I took the car in in July and had the Global update done. The update wiped out all of the prior coding. When I had it recoded the TPMS data came up with the dreaded ---. Ugh. It appears that it depends on what version of software you have whether or not you can activate this feature.
2012 BMW 535I 14K Miles
ED Pick Up on 12/03/2011; US Pick Up on 01/27/1012
Alpine White, M Sport, Blk Nappa, Cold Weather, Luxury Seating, Premium, Premium Sound, Tech, Sports Trans, Active Cruise, Heads-Up
Mods - Quad Exhaust Tips, HID Fog Lights, Clear Front Reflectors, M5 Spoiler, Calipers Painted Black, 12.5 mm Rear Wheel Spacers, 5% Tint Rear - 35% Tint Front - 50% Tint Windshield
Coding by itschase (Chase)
Next; ED of 2014 M4
Old 09-13-2012, 10:14 AM
Mein Auto: 550xi
This is so odd!
I'm thinking there is a new feature somewhere that we need to find/activate for this to work; maybe they moved it around.. I wish I new german, so I could hunt through the list and see... I have a good friend who speaks German, but hs is a 2 hour drive (each way) away - I'm going to see if he can spend the day, and hunt through those menu's with me
Old 09-13-2012, 11:38 AM
That sucks. I love having this capability. Now I'd have to think twice about getting a software update.
Old 09-13-2012, 04:28 PM
This only works with TPMS, Option 2VB.
1) Go to www.bmwvin.com and put your Short VIN in an make sure you have 2VB.
2) Assuming you have 2VB, make sure the following is coded:
ICM:
IcmKod_B_SA2VB = verbaut
CIC:
RPA_CIC = nicht_aktiv
RDC = aktiv
RDC_SAFETY = aktiv
If you do not have 2VB (TPMS), RPA_CIC (FTMS) should be aktiv, and PSI/Temp will not work.
If you have 2VB, and all the above coding is correct, and you still do not have PSI/Temp, your screwed.
- BMWCCA #446923
- flick
Old 09-13-2012, 04:39 PM
Mein Auto: 550xi
Ohh; looks like I'm out of luck! If I read this properly, I dont have that? wish I had check that before buying all the TMPS stuff!
S223A ELEKTRONISCHE DAEMPFER CONTROL(EDC) Electronic Damper Control (EDC)
S229A DYNAMIC DRIVE Dynamic Drive
S248A LENKRADHEIZUNG Steering wheel heater
S258A BEREIFUNG MIT NOTLAUFEIGENSCHAFTEN Tire with run-flat functionality
S2NBA M LM RAEDER DOPPELSPEICHE 351 M,19" BMW LA wheel, M Double Spoke 351
S2TBA SPORT-AUTOMATIK GETRIEBE Sport automatic transmission
S2VAA ADAPTIVE DRIVE Chassis & suspens. setup"Adaptive Drive"
S316A AUTOMATISCHE HECKKLAPPENBETAETIGUNG automatic trunk lid mechanism
S319A INTEGRIERTE UNIVERSAL-FERNBEDIENUNG Integrated universal remote control
S322A KOMFORTZUGANG Comfort access
P337A M SPORTPAKET M Sports package
S3AGA RUECKFAHRKAMERA Reversing camera
S415A SONNENSCHUTZROLLO FUER HECKSCHEIBE Sun-blind, rear
S416A SONNENSCHUTZROLLOS Roller sun vizor, rear lateral
S423A FUSSMATTEN IN VELOURS Floor mats, velours
S430A INNEN-/AUSSENSPIEGEL AUT.ABBLENDEND Interior/outside mirror with auto dip
S431A INNENSPIEGEL,AUTOMATISCH ABBLENDEND Interior mirror with automatic-dip
S453A AKTIVE SITZBELUEFTUNG VORN Climatised fornt seats
S455A AKTIVSITZ FUER FAHRER/BEIFAHRER Active seat for driver and passenger
S456A KOMFORTSITZE ELEKTRISCH VERSTELLBAR Comfort seat with memory
S465A DURCHLADESYSTEM Through-loading system
S488A LORDOSENSTUETZE FAHRER/BEIFAHRER Lumbar support, driver and passenger
S494A SITZHEIZUNG FUER FAHRER/BEIFAHRER Seat heating driver/passenger
S496A SITZHEIZUNG FUER FONDSITZE Seat heating, rear
S4CEA EDELHOLZAUSF.FINELINE ANTHRAZIT Fine woodgrain vers., Fineline anthrac.
S4NBA KLIMAAUTOMATIK MIT 4-ZONENREGELUNG Autom. climate control with 4-zone ctrl
S4U1A KERAMIKAPPLIKATION F.BEDIENELEMENTE Ceramic appliques for controls
S502A SCHEINWERFER-WASCHANLAGE Headlight cleaning system
S508A PARK DISTANCE CONTROL (PDC) Park Distance Control (PDC)
S522A XENON-LICHT Xenon Light
Code Description (interface) Description (EPC)
S524A ADAPTIVES KURVENLICHT Adaptive Headlights
S548A KILOMETERTACHO Kilometer-calibrated speedometer
S5ACA FERNLICHTASSISTENT High-beam assistant
S5ADA SPURVERLASSENSWARNUNG Lane departure warning
S5AGA SPURWECHSELWARNUNG Lane-change warning
S5DFA AKTIVE.GESCHW.REG.+STOP&GO FUNKT. Active cruise control+Stop&Go function
S5DLA SURROUND VIEW Surround View
S609A NAVIGATIONSSYSTEM PROFESSIONAL Navigation system Professional
S610A HEAD-UP DISPLAY Head-up display
S620A SPRACHEINGABESYSTEM Voice control
S639A KOMPLETTVORB. HANDY USA/CDN Preparation f mobile phone cpl. USA/CDN
S655A SATELLITENTUNER Satellite tuner
S677A HIFI SYSTEM PROFESSIONAL HiFi System Professional DSP
S697A AREA-CODE 1 Area-Code 1 for DVD
S6AAA BMW TELESERVICES BMW TeleServices
S6ABA STEUERUNG TELESERVICES Control for Teleservices
S6FHA FOND-ENTERTAINMENT PROFESSIONAL Rear Professional entertainment center
S6FLA USB-AUDIO-SCHNITTSTELLE USB/Audio interface
S6NFA MUSIC-SCHNITTSTELLE FUER SMARTPHONE Link, Music Player in mobile section
S6NRA APPS Apps
S6UKA NIGHT VISION MIT PERSONENERKENNUNG Night Vision with human recognition
S6VCA STEUERUNG COMBOX Control for Combox
S6WAA INSTRUMENTENKOMBI. M. ERW. UMF. Instrument cluster, expanded equipment
S710A M LEDERLENKRAD M leather steering wheel
S715A M AERODYNAMIKPAKET M Aerodynamics package
S754A M HECKSPOILER M Rear spoiler
S760A INDIVIDUAL HOCHGLANZ SHADOW LINE High gloss shadow line
S775A INDIVIDUAL DACHHIMMEL ANTHRAZIT Headlining anthracite
L838A KANADA-AUSFUEHRUNG NATIONAL VERSION CANADA
S8KCA OELWARTUNGSINT. 24.000KM/24MONATE Dummy-SALAPA
S8S4A DECODIERUNG VARIABLE LICHTVERTEILUN Decoding variable light distribution
S8SCA LAENDERSPEZ. TELESERVICEFREISCH. Telematics access request,country-spec.
S925A VERSANDSCHUTZPAKET Transport protection package
S1CDA BRAKE ENERGY REGENERATION Brake Energy Regeneration
S212A AUSSTATTUNG BREMSANLAGE LAENDER Equipment, brake syst. country-specific
S302A ALARMANLAGE Alarm system
S403A GLASDACH, ELEKTRISCH Glass roof, electrical
S4URA AMBIENTES LICHT Ambient interior lighting
S5DSA KOFFERRAUMNOTENTRIEGELUNG Emergency release, luggage compartment
S645A RADIO-STEUERUNG US BMW US Radio
S823A HEISSLAND-AUSFUEHRUNG Hot-climate version
S845A AKUSTISCHE GURTWARNUNG Acoustic belt warning
S850A ZUSAETZL. TANKFUELLUNG EXPORT Additional Export tank filling
S853A SPRACHVERSION ENGLISCH Language version English
S876A FUNKFREQUENZ 315 MHZ Radio frequency 315 MHz
S8SMA FAHRGESTELLNUMMER,V.AUSSEN SICHTBAR Car ident. number visible from outside
This is what the dealer sent me, it has different codes on it
2NB M LM L.A. WHEELS DOUB.SP. 351 M,19"
2TB SPORT AUTOMATIC TRANSMISSION
2VA ADAPTIVE DRIVE
223 ELECTRONIC DAMPER CONTROL (EDC)
229 DYNAMIC DRIVE
248 STEERING WHEEL HEATING
258 RUNFLAT TYRES
3AG BACKUP CAMERA
316 AUTOMATIC TAILGATE OPERATION
319 INTEGRATED UNIVERSAL REMOTE CONTROL
322 COMFORT ACCESS SYSTEM
337 M SPORT PACKAGE
4CE FINE-WOOD TRIM FINELINE ANTHRACITE
4NB AUT.AIR CONDITIONING 4-ZONE CONTROL
4U1 CERAMIC EMBELLISHER FOR CONTROLS
415 SUNBLIND FOR REAR WINDOW
416 SUNBLINDS
423 FLOOR MATS, VELOUR
430 INT/EXT RR VW MIRROR W AUT ANTI-DAZZLE
431 INTERIOR RR VW MIRROR W AUT ANTI-D
453 ACTIVE SEAT VENTILATION, FRONT
455 ACTIVE SEAT F DRIVER AND FRONT PASSENGER
456 COMFORT SEATS, ELECTRIC. ADJUSTABLE
465 THROUGH-LOAD SYSTEM
488 LUMBAR SUPPORT DRIVER/FRONT PASSENGER
494 SEAT HEATING F DRIVER/FRONT PASSENGER
496 SEAT HEATING FOR REAR SEATS
5AC AUTOM. HIGH-BEAM HEADLIGHTS CONTROL
5AD LANE DEVIATION WARNING
5AG LANE CHANGE WARNING
5DF ACTIVE CRUISE CTRL+STOP&GO FUNCT.
5DL SURROUND VIEW
502 HEADLIGHT WASHER SYSTEM
508 PARK DISTANCE CONTROL (PDC)
522 XENON LIGHT
524 ADAPTIVE HEADLIGHTS
548 SPEEDOMETER WITH KILOMETER READING
6AA BMW TELESERVICES
6AB CONTROL TELESERVICES
6FH REAR-SEAT ENTERTAINMENT PROFESSIONAL
6FL USB-/AUDIO INTERFACE
6NF EXT.CON.OF THE MUSIC PLAY.I.MOBILPH
6NR APPS
6UK NIGHT VISION WITH OBJECT RECOGNITION
6VC CONTROL COMBOX
6WA INSTRUMENT CLUSTER W. EXTENDED CONT
609 NAVIGATION SYSTEM PROFESSIONAL
610 HEAD UP DISPLAY
620 VOICE INPUT SYSTEM
639 COMPLETE PREP. CELLULAR PHONE USA/CDN
655 SATELLITE RADIO
677 HIFI SYSTEM PROFESSIONAL
697 AREA-CODE 1
710 M LEATHER STEERING WHEEL
715 M AERODYNAMICS PACKAGE
754 M REAR SPOILER
760 INDIVIDUAL HIGH-GLOSS SATIN CHROME
775 INDIVIDUAL ROOF-LINING ANTHRACITE
8KC OELSERVICEINT. 24.000KM/24MONTHS
8SC COUNTRY SPEC. RELEASE OF TELESERVICE
8S4 DECODING VARIABLE LIGHT DISTRIBUTIO
838 CANADIAN VERSION
925 SHIPPING PROTECTION PACKAGE
1CD BRAKE ENERGY REGENERATION
212 NATIONAL BRAKE SYSTEM EQUIPMENT
302 ALARM SYSTEM
4UR AMBIENT LIGHT
403 GLAS ROOF, ELECTRIC
5DS LUGGAGE-COMPARTMENT EMERG. RELEASE
645 RADIO CONTROL US
8SM VIN, VISIBLE FROM OUTSIDE
823 HOT CLIMATE VERSION
845 ACOUSTIC BELT WARNING
850 ADD FUEL TANK FILLING FOR EXPORT
853 LANGUAGE VERSION ENGLISH
876 RADIO FREQUENCY 315 MHZ
If you read it the same way I do, and the 2VB option is in fact not listed in that list, have you ever seen anyone add the missing parts to make this work? (is that possible) - I'd be willing to spend a bit more if there was some good idea on what a parts list etc
Old 09-13-2012, 05:01 PM
You have a very impressive list of options, including NVE, but for some reason BMW blessed Canadians with FTMS instead of TPMS.
The Dealer option codes look the same to me (drop the first and last digit from the BMWVin list), except the BMWVin list will always be complete whereas the dealer list is always selective.
The part you bought, that is just for the wheel assembly / valve stem? I suppose you cold try and retrofit the receiver piece, and then add 2VB to your VO and code you car and see if it works.
- BMWCCA #446923
- flick
Old 09-13-2012, 05:05 PM
Hell. It looks like they made up for it though by giving you not one, but two KOMBI's.
Be sure to code both of them.
- BMWCCA #446923
- flick
