E36 (1991 - 1999)
Old 09-13-2012, 09:09 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Originally Posted by ZeGerman View Post
Yep, we don't have "antennas". Well, we do, but they're hidden in a top secret location.
Yep, mine's in Area 51.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 09-13-2012, 09:27 AM
Kdoherty's Avatar
Kdoherty Kdoherty is online now
bimmerfest Supporting Member
Mein Auto: 1996 328i
fired her up, and asides the old oil that leaked onto the headers, no leaks. cool
insert witty signature quote
Old 09-13-2012, 10:46 AM
Kdoherty's Avatar
Pictures from the VCG job and such. my garage is lit worse than a cave which is why even with flash the pics came out craptastic.
ID:	341704   Click image for larger version
ID:	341705   Click image for larger version
ID:	341706   Click image for larger version
ID:	341707   Click image for larger version
Old 09-13-2012, 11:41 AM
C14 Rider's Avatar
C14 Rider C14 Rider is online now
Big Mike
Mein Auto: 1999 328is 2010 Audi S4
Today I swore at my OBC after a "Low Beam Failure" code magically appeared..
I was having a nice drive home when I rolled into work zone that called for lights on, shortly after turning them on the evil code showed up..Both HID's are working fine no idea what tripped the code I thought it was gone..
1999 BMW 328is/M Sport Package/5 speed/122k and climbing/
2010 Audi S4 Premium Plus/3.0L Supercharged V6/Quattro/6 speed/25k and climbing/
Old 09-13-2012, 01:11 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
The low beam failure is somewhat common on E36s equipped with aftermarket HID headlights.
1998 BMW 328is
1966 Pontiac GTO
Old 09-13-2012, 01:39 PM
C14 Rider's Avatar
Big Mike
yeah, I had it when I first installed them then it went away for a while.......now its back
On a happy note I did change my footwell lighting over to red LED's..
Old 09-13-2012, 03:28 PM
ZeGerman's Avatar
Warm Leatherette
What happens with the LEDs when the lights fade out? Do they just go from being fully illuminated to fully off, or do they still fade out like the standard bulbs do?
1998 BMW 328is
1966 Pontiac GTO
Old 09-13-2012, 03:39 PM
C14 Rider's Avatar
Big Mike
They fade out in sync with the other lights..
Old 09-13-2012, 04:27 PM
ZeGerman's Avatar
Warm Leatherette
Nice - I may consider upgrading at some point.
1998 BMW 328is
1966 Pontiac GTO
Old 09-13-2012, 04:47 PM
C14 Rider's Avatar
Big Mike
no idea why I did this mod but it looks cool..
Old 09-13-2012, 04:59 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
If you like it, cool. Personally, I'm partial to the warm glow of incandescents for interior lighting. It also doesn't knock out your night vision as much, although red leds would mitigate that.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 09-13-2012, 05:04 PM
ZeGerman's Avatar
Warm Leatherette
Yeah, if I was going to install LEDs, I'd want them to be as close to incandescent-appearing as possible - not that cool blue/hyper white color.
1998 BMW 328is
1966 Pontiac GTO
Old 09-13-2012, 05:10 PM
C14 Rider's Avatar
Big Mike
I've got the bright white LED's in front and back that come on when a door is opened....
Maybe I'll throw some red's in those spots and see how I like them, the damn thing will look like a rolling 'ho house..
Old 09-13-2012, 05:35 PM
King of the Ballers
Yup.
I see no problem with incandescent interior lights, if it ain't broke don't fix it. But if it makes you happy, go for it.
You're a derbanana
Old 09-13-2012, 07:00 PM
r33p04s's Avatar
r33p04s r33p04s is offline
Mein Auto: E36/4/5
Gotcha. BTW, did you know you can get them brand new for pretty cheap at BimmerWorld? They've been running this "sale" on them for years now:
http://store.bimmerworld.com/invento...les-p1066.aspx
Finally took a look at the link...
Do you know if the non-m front hub/bearing fit the //m front spindle? i know they don't in the back... would save me some $ and time if they did and would only have to get rotors
tia
Old 09-14-2012, 08:29 AM
ZeGerman's Avatar
Warm Leatherette
I have no idea off the top of my head. Check RealOEM.com to cross-reference part numbers.
1998 BMW 328is
1966 Pontiac GTO
Old 09-14-2012, 12:21 PM
C14 Rider's Avatar
Big Mike
just a wash job today nothing major..
Old 09-14-2012, 07:43 PM
r33p04s's Avatar
Mein Auto: E36/4/5
tia
They are the same p/n and size (83mm) just swap over hubs/bearings and upgrade rotors
now to get to work on painting them so I can flush the brakes and p/s while I'm at it
Old 09-15-2012, 11:47 AM
King of the Ballers
Finally.....something on this project actually went smoother than expected. Just changed the radiator on the E36, took like 15 minutes. That's a brilliant design.
In order of plan today:
  • Run car with cooling system flush for a little while
  • Pull hoses to tstat and flush everything with tons of water
  • Hook it all back up and start the blue devil......
  • Let run for a few hours to see what happens
  • IF everything goes well.....flush the system again
  • Pull the new radiator and run tons of water through it
  • New tstat, housing gasket, reinstall fan and radiator
  • Pull mani, put heater hoses back the way they were, and replace all the gaskets on the intake path
  • New plugs
  • Compression test
  • Drive!!!
If it doesn't go well.......part out.
You're a derbanana
Old 09-15-2012, 01:09 PM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
Today I replaced the PO's ghetto shift knob, replaced boot and ordered fresh e46 sport seats to replace my horrific standard seats.
Old 09-15-2012, 03:49 PM
Adamt166's Avatar
Adamt166 Adamt166 is offline
99 323i Vert
Mein Auto: 99 323i Vert
Today I washed, clayed, and waxed it. I started to polish it,l and after I did the hood I couldn't tell any difference so I stopped. I'm starting to notice but I don't know if its only in my mind or if it really is more reflective..
Sent from my ADR6300 using Bimmer App
ID:	341970   Click image for larger version
Old 09-15-2012, 04:17 PM
King of the Ballers
Polish goes before the wax bro. All you're doing is polishing off the wax.
You're a derbanana
Old 09-15-2012, 04:19 PM
Adamt166's Avatar
99 323i Vert
Yeah I know. I meant I started to polish and didn't do the whole car, then waxed. In order I cleaned, clayed, polished he hood, and waxed.
Old 09-15-2012, 06:29 PM
King of the Ballers
Just thought I'd update - knew today was going too smooth. Just reread the directions on the Blue Devil, it works by the temperature difference so it needs to be applied to a totally cold engine. Guess I'm waiting for Monday night. Ugh.
You're a derbanana
Old 09-15-2012, 07:33 PM
Mando3 Mando3 is offline
Mein Auto: BMW 2006 325i
First time posting in this thread….
Today I quick detailed, painted the flaking rails at the top of the car (with rustoleum), and fixed a couple of rock chips…. it was a paint day.
Cheers!
:3
