F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
#26
The picture of the iPod Nano in the Five was shown as part of the Bluetooth section of the presentation. As the Nano now has Bluetooth, you do not need a cable at all.
I think that we will see the incompatibility of the iPhone 5 with many BMWs, including my X3 and 135i. The 135i uses a Y-cable, and plugs the USB into one and the analog audio into another on the car. I can see BMW making a new version of this cable, with a combo Lightning AND 3.5mm tied together with the correct spacing. It would work, as would the new Apple adaptor plus a separate 3.5mm cable. To work best, BMW would need a SW update to set the volume on the headphone jack to match the expected volume levels, then use the car's amp for the volume after that. Audio quality would suffer as the signal has to go through the headphone amp first. My X3 is using the aux in, with a aux-splitter cable, much like the expensive BMW part. I will need a pair of cables now to replace the single and have to tear apart the car to rewire it. In the short term, this will probably be a Apple USB cable and a 3.5mm audio cable. But I can see Chinese entrepreneurs selling a combo cable with a wider connector combining the Lightning and 3.5mm in a single unit. Cradles will probably fail due to size constraints, and the requirement to get to the analog audio port, which is not yet supported. |
#27
The difference between using a Snap-in adapter and just a USB cable is the following:
Here's a pic (third screen is the Plugin screen):
#28
The insertion angle may exceed the limit of the OEM 30-pin connector at the snap in, IMO. |
#29
I currently have a docxtender cable and never plug my phone directly into the doc (my case is too large). I imagine if you purchased a 30pin extender cable you could attach an adapter to the end and have the phone outside of the armrest.
#30
2013 ///M5 Individual Monte Carlo Blue, Platinum Full Individual Merino, Platinum Alcantara, Piano Black, Exec Pkg, Drivers assistance pkg, Bang and Olufsen, 20" wheels, Eisenmann Sport, STIR+, LI Quad HP |
#31
I am not saying this is how it works on the iphone, but it is possible that via the 30 pin connector this function was available. Until we get our hands on the phone, the connector, and someone shows how the BMW wiring works we won't know. We also won't now how much we lose with the adapter, but we will definitely lose something.
2013 535i Space Grey, Biege, M-SPort, Premium, Tech, Cold Weather, Luxury Seating, PDC, 6MT ED-10/11/2012 - PCD Redelivery-12/14/12 Last edited by miamiboyca; 09-13-2012 at 03:11 PM. |
#33
- Look up the 30-pin connector pinout of the now "old" Apple connector. There is no antenna pin. - The OEM baseplate do have an antenna connector. - The Lightning adapter is confirmed to not support iPod Out/video. |
#34
Please post what the adapter does internally. Please post the wiring diagram that show how the OEM connector pins out Please post the internal pinout of the "adapter" Please post the internal specs of how Apple feeds their receivers. Utmost appreciation for being able to share this info
2013 535i Space Grey, Biege, M-SPort, Premium, Tech, Cold Weather, Luxury Seating, PDC, 6MT ED-10/11/2012 - PCD Redelivery-12/14/12 |
#35
Yeah, that is what I thought. I couldn't find it either.
#37
Considering how poor radio reception is in BMW's in general, I'm not sure that's a good thing or not.
#38
To summarise what I know and have found out:
1. The old 30 pin connector does not have an RF connection (as pointed out by Technic). The snap in adapter provides inductive coupling from the iPhone antenna to the cars antenna. There is no direct connection. 2. The new 9 pin connector is a digital interface. The adapter has a chip that is used to verify the connection as legitimate. It may also do some protocol conversion, not sure about that. 3. The adapter does not support the so called iPod interface protocol (which was supported over the USB interface) so there will be no control of the play back system and cover displays etc. from iDrive. Presumably this is a protocol change so it is possible that BMW can update software to use the new interface. 4. The analogue component and composite video interface in the old 30 pin connector is no longer supported, so the video feed in the current BMW iDrive interface will no longer work. Presumably the new 9 pin connection supports a digital interface (probably some variant of HDMI) which will require more than a software change to iDrive. If a new adapter is designed it will need to take the digital video feed and convert it to component video which may not be to the media industries liking who outlawed component video because it is easy to use for copying purposes. Overall it does not look very promising for an adapter that can take the iPhone 5 and make it work in the same way as the older iPhones with the 30 pin connector.
Cheers Whitby 2012 528i MSport, Space Grey, Nav, Premium 2013 X1 XDrive 28i Msport, Valencia Orange, Ultimate, Lighting |
#39
Completely different situation. Apples and oranges as the saying goes...
#40
Current: 2013 535i M Sport, Imperial Blue, Black Nappa, Premium/Technology/Cold Weather/DA/DA+/Ceramic Controls/Premium Sound Retired: 2001 E39 530i Sport, 1976 2002 |
#41
#43
Yes, I know it doesn't; never said it did. I was simply trying to steer you towards information to clarify.
#45
FYI: Album Art/Cover Art are image data files, not video.
The USB port handle those with the music data files. |
#47
Exactly...
#48
#49
1+ bar on Verizon. It works quite well.
04 Successfully lobbied BMW NA and BMW FS to prohibit dealers from using residual values based upon Euro Delivery MSRP and to use US MSRP saving BMW Enthusiasts several thousand dollars on each lease 14 550i Euro Del 14 X3 11 550i Euro Del 08 550i Euro Del, Retired 06 330i Euro Del, Retired 04 545i Euro Del, Retired 01 530i Euro Del, Retired |
#50
An interim solution is mentioned in the comments. Stick your iphone4/4s in the snap-in or usb and tether off your iphone5's data connection. The snap-in was pretty nice to keep the solution clean, i also got better cell/data reception but the video and ipod plug-in interface wasn't very useful for me. |
