Mixing PS & PS2? - Bimmerfest - BMW Forums
Old 09-13-2012, 03:36 PM
gabriellebosco gabriellebosco is offline
Gabrielle
Mein Auto: '06 330ci ZHP
Mixing PS & PS2?
It's a long and unfortunate story why, but I have one year old (~10,000 miles) Michelin Pilot Sports on the rear of my 330ci ZHP and brand new PS2s up front. Does anyone have experience or thoughts on mixing these tires? Thanks!
Old 09-13-2012, 03:52 PM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
I used to run the opposite. PS1 on the front and PS2 in the rear, it works, however the PS2s tramline more than the PS1s so just expect them to groove more when running over surfaces. Otherwise, that combo works out. For reference I was running them on my 05 330i ZHP with the staggered setup similar to your car- Fronts= 225/40/18 and Rears= 255/35/18 then a year later 265/35/18- both rear tire replacements were PS2s. It took me a year and a half to wear out my PS1 fronts then went PS2s all around. However, in your case since the rears wear out faster 3 times to 1 vs the fronts you'll be running PS2s all around within half a year with the mileage on your PS1s.
Old 09-13-2012, 04:03 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
For awhile I had a different tire on every corner (long story). I had a PS2 on front left, Kumho on front right, Potenza on back right and some no name brand on the back left. Car actually drove quite well.
On my mustangs I used to find it dangerous to put grippier tires up front than in the back, but on a BMW, they are pretty forgiving. I think you will be fine.
Old 09-13-2012, 04:18 PM
MELLOWYELLOW06 MELLOWYELLOW06 is offline
Mein Auto: 2012 750Li & 650i
You should be fine. I wouldnt do different brands but this should be just fine.
Old 09-13-2012, 05:11 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d, 328d, Toyota T100
As others have said, you'll be fine.
Just a suggestion: if you have a square setup (not staggared), you should put the best pair on the rear. Pretty much everyone (including tirerack) says that that is what you should do for maximum stability.
Old 09-13-2012, 05:50 PM
Fast Bob's Avatar
Keeping it surreal
If you`re running the stock ZHP staggered setup, the question has already answered itself. In the dry, it`s not an issue....in the wet, it most certainly IS an issue....different tread patterns and rubber compounds can have very different adhesion levels in the wet, which can cause hydroplaning when you least expect it....
The road goes ever onward....
(R.I.P. Jever)
Old 09-13-2012, 06:08 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Good point.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 09-13-2012, 06:38 PM
av98's Avatar
ZHP = Patlabor
The PS1 (v groove center) vs PS2 (double line grooves) patterns are very similar not much diff in the rain. However, the PS2s have a higher grip quotient which will cause under or over depending on where they are. For my setup it was understeer because they were on the rear. But you don't see this difference in regular driving, only on auto-x or track.
As I've mentioned the tranlining on the PS2s are more noticeable compared to anything else.
Old 09-13-2012, 09:09 PM
Gabrielle
A little background may change the response... I have a baby now which as a mom means 1.) my track days are pretty much over and 2.) on occasion I may have precious cargo in the back of that car so it cannot be unsafe for regular driving in wet/dry conditions (I do have an SUV and separate snow tires/wheels for winters in NJ). Considering this, and framing the question again as more of a safety/handling issue vs. a high performance issue, does it change the response? Not that I want to give up performance, just more concerned about control. Really appreciate the feedback!
Old 09-13-2012, 09:41 PM
Mein Auto: '04 330Ci 6-speed
Yes, it changes safety/handling issues, but I'd not worry if you don't drive aggressively with precious in the back.
Old 09-13-2012, 09:52 PM
av98's Avatar
ZHP = Patlabor
+1, keep it under 7/10ths and you will be fine. For reference, when I had that setup my son rode with me all the time in his carseat from 1-2 years old.
No snow, in NorCal, so only rain experience and it was fine.
Old 09-14-2012, 11:56 AM
mawana's Avatar
mawana mawana is offline
Mein Auto: Yaris (6sp) CC
PS1 mixed with PS2 - I wouldn't sweat it!
..but if you do, there is a very good market for used Michelin tires out there.
"Common sense is the collection of prejudices acquired by age 18." ~ Albert Einstein
BMWCCA 405578
Garage
1. 2015 k46 S1KRR
2. 2008 e90 M3
past: 2003 e46 ZHP
Old 09-14-2012, 12:57 PM
cwsqbm's Avatar
cwsqbm cwsqbm is offline
I do'nt make mistakes.
Mein Auto: Quadricycle
Its nice to have all new tires at the same time. However, the tires wear at different rates so you'll eventually be at a place where the tires are different front to rear. Mixing front to rear isn't a bad thing either, as long as the tires have roughly the same amount of grip. Mixing summer tires with winters or all seasons wouldn't be good as then one end could have much more/less traction than the other and cause a spin. Commercial trucks usually run different tires front to rear since the tires do different jobs. The front tires are "steer" and the rears are "drive".
.................................................. ...............................So long, Photobucket. .................................................. ..........................................
