Old 08-27-2012, 05:37 PM
fhinfo fhinfo is offline
Mein Auto: X3 F25 20d xDrive
One touch turn signal blinks 5 times instead 3 times
Hi everyone,
As we all know the F10 has one touch turn signal blinks 3 times and it blinks constantly when you push it harder. My question is how to change the value via e-sys from 3 times to 5 times?
Thank you so much!
Old 08-30-2012, 10:01 AM
Alan L. Alan L. is offline
Mein Auto: LCI 550i Msport
This would be pretty useful. i find sometimes 3 clicks isn't enough in certain situations and 5 would be perfect.
Old 09-06-2012, 05:41 PM
mrbombastic mrbombastic is offline
Mein Auto: 2012 535i
This might be it
Found this
CAF [FRM__03CT]
3400 FRM_TMS_AHL_LWR, F0
SCHW_AKTIVIERUNG_OFFSET Werte = 05
The English translation Comment = threshold level for activation of the automatic. Indicator reset.
Will try it when i get a chance
Old 09-07-2012, 01:53 AM
gspannu gspannu is offline
Mein Auto: F10 2015 Model
Originally Posted by mrbombastic View Post
Found this
CAF [FRM__03CT]
Any update on this… ?
Old 09-08-2012, 05:01 AM
Found this
CAF [FRM__03CT]
Did not work. Back to the drawing board.
Old 09-08-2012, 06:41 AM
chris88 chris88 is offline
Mein Auto: bmw x3 F25
this is the wrong section. LWR is Leuchtweitenregulierung, and SCHW is Schwenk. This is for xenon move up, down, left and right.
Old 09-08-2012, 06:43 AM
look at FRM, 3050 Blinkzyklen_anzahl_tipp
Old 09-13-2012, 11:05 AM
lbjgh's Avatar
lbjgh lbjgh is offline
Mein Auto: 2013 X3 M-Sport
watching for updates.
Old 09-14-2012, 09:43 AM
gicamuci gicamuci is offline
Mein Auto: 2011 535i xDrive
Original values for me are einmal/werte=01
And comment is saying 0 - einmal and 2 - dreimal
Kind of misleading...
I would expect seeing dreimal/werte=2 cause the three blinks are enabled in idrive.
Right ?
So... how do we add/change fünfmal or sechsmal ?
Regards,
Alex
2012 w204 Mercedes-Benz C350 4MATIC MY 05/2012 Obsidian Black/Sahara
2011 F10 535i xDrive MY 01/2011 Sophisto Grey/Black
Old 09-14-2012, 02:12 PM
AutobahnCowboy AutobahnCowboy is offline
Mein Auto: BMW
you got it
my F30 doesn't have FRM Modul but i found Blinkzyklen_Anzahl_Tipp in FEM-Body
there is an other Option like PIA-Blink... some like this. This Wert must be set to "Mehrfach Blinken" its in the Description of Blinkzyklen_Anzahl_Tipp
i changed the Werte-Value up to 5 and it Blinks 6 Times
so
Comment is not nessesary, after changing the Value it sets to UNKNOWN but dont matter
0 = 1 Blinking
(1 = 2 Blinking)
2 = 3 Blinking
99 = 100 Blinking
Have Fun!
sry for my english speaking :P
its "only" lerned shool-english
Old 09-14-2012, 02:21 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Originally Posted by AutobahnCowboy View Post
you got it
so
0 = 1 Blinking
(1 = 2 Blinking)
2 = 3 Blinking
99 = 100 Blinking
Have Fun!
Very nice!
Old 09-14-2012, 03:16 PM
Weird,
I have tried all kinds of value to put in Blinkzyklen_Anzahl_Tipp (such as Werte=01~10) but nothing change at all. After I change the value instead of default, I still can change blink once or triple in iDrive. Did I miss something?
Old 09-14-2012, 03:48 PM
Originally Posted by fhinfo View Post
Weird,
I wouldn't expect the iDrive choice to change, only that if Triple Turn is checked in iDrive, it will physically blink what ever number of times you have the Werte Value set to.
Old 09-14-2012, 07:20 PM
No go for me
I could not find PIA-Blink Change WERT to 5, did not make a difference. Where is PIA-Blink, my car is F10.
Old 09-15-2012, 07:17 AM
F10 535xi 01/2011 in FRM -> 3050 -> Blinkzyklen_Anzahl_Tipp -> UNKNOWN/Werte=05
Doesn't change anything. Still blinking 3 times.
Regards,
Alex
Old 09-15-2012, 09:32 AM
Same here!!!
Old 09-15-2012, 09:40 AM
So where exactly is this other option PIA-Blink ? Which module ? Asking cause it makes sense to change that also to "Mehrfach Blinken" (Multiple Blinks).
Then maybe older F10s don't have this other option, like for example the FEM-Body I don't remember seeing it on my F10.
Regards,
Alex
Old 09-15-2012, 01:13 PM
Mein Auto: BMW
FEM-Body on F30 should be equal to FRM on F10 like chriss88 mentioned
i captured it against with 4 Impulses and both changed/important Values
here the exact path´s for me
FEM-Body
-> 3060 LceMaster, 1C
---> Blinkzyklen_Anzahl_Tipp
-----> einmal, dreimal (not important)
-----> Werte=XX (your wanted Impulses, 0 conforms 1 - 09 is 10)
and
FEM-Body
-> 3064 LceConfiguration, F6
---> Pia_Default_Tippblinken
-----> Einfachblinken, --> Mehrfachblinken <-- (Choose Mehrfachblinken)
-----> Werte=01
if you dont have FEM-Body or FRM try to hit "Read Coding Data" on all Modules and open each one itself and search for "blinkzyklen" and "pia". i got for each searchstring only one positiv hit!
i also checked how the car will react after i uncheck the idrive "3 times blinking" and activate it again
unchecked it blinks only 1 time, after checked it it blinks 4 times like i coded it.
so the checkbox doesnt set the value to "3 mal blinken" but rather only activate the "Mehrfachblinken" with the Werte-Config in Blinkzyklen_Anzahl_Tipp
Hope you can get it work!
Old 09-15-2012, 07:37 PM
FEM-Body
and
FEM-Body
-----> Werte=01
Still weird~
My F10 has "Blinkzyklen_Anzahl_Tipp" but nothing is called "Pia_Default_Tippblinken". I have checked each ECU I have shown on E-sys, Also I tried to find the keyword "Mehrfachblinken" under FRM is also nothing found. Does anyone who has F10 get the issue with me?
Thank you!
Old 09-16-2012, 04:15 AM
Same here. No "Pia_Default_Tippblinken" in any module.
Regards,
Alex
Old 09-16-2012, 08:21 PM
webb webb is offline
Mein Auto: korea
Still weird~
Thank you!
Not find, too. F10.
Old 09-17-2012, 04:41 AM
Question Not In F10
I have a f10 and could not find that PIA setting in any module. maybe this is only in F30. Maybe one of the coding expert could chip in.
Old 09-18-2012, 04:26 AM
DreamCar's Avatar
DreamCar DreamCar is offline
Moderator
Mein Auto: F10 M5
I may be completely wrong
But In our very initial findings... We believed that pia is basically to mark the parameters that can be exported in to profile ... Per say if we have hud turn signal pia and if we enable it then it will be part of the XML when We export the profile and We can import into other car like a loaner so that we don't have set them again in that car.,,
if it is the case then we can ignore that setting if you look around you will find lot of pia parameters
Old 09-18-2012, 05:15 AM
Anyone that took the global update on their F10 did the search for this value - "Pia_Default_Tippblinken" ?
Regards,
Alex
Old 09-18-2012, 05:23 AM
Originally Posted by DreamCar View Post
In our very initial findings... We believed that pia is basically to mark the parameters that can be exported in to profile ... Per say if we have hud turn signal pia and if we enable it then it will be part of the XML when We export the profile and We can import into other car like a loaner so that we don't have set then again in that car.,,
I may be completely wrong but if it is the case then we can ignore that setting if you look around you will find lot of pia parameters
I think PIA is, or has become, more than just Profile related. According to this thread:
http://www.bimmerfest.com/forums/sho...d.php?t=645540
The new 2013 models with the HU_NBT CIC now require HUD_PIA_BLINKER to be set in order for the HUD Turn Signals to be even functional, so it is conceivable here too that Pia_Default_Tippblinken or its F10 equivalent if it exists is required in order to change the number of flashes.
