Old 09-12-2012, 02:06 PM
Nick9597's Avatar
Nick9597 Nick9597 is offline
Mein Auto: 2010 BMW 328i
Door Creaking? 2012 2013?
I have owned two X5's with major door creaking issues. A 2008 and a 2011. We are considering turning in the 2011 next year instead instead of purchasing it in the hopes that the 2012 or 2013 does not creak. I am speaking specifically about the door creak, not the other cheap plastic creaking...even though it would be nice if that was gone too.
So what I'm asking any and all that own or lease a 2012 or 2013 X5, do the doors creak still? Does the "soft close" doors help the creak?
Thanks for any help.
Old 09-12-2012, 06:48 PM
ard ard is offline
Resident Curmudgeon
"Major"? What do you mean? Creaking from the seals all the time? or only when opening/closing?
Old 09-13-2012, 06:50 AM
Billyraymallard Billyraymallard is offline
Mein Auto: 2011 x5 35i
Still creaks but for me went away after break-in period. Teflon tape fix should work too.
For what it's worth, have had on other cars, too. But went away.
Old 09-13-2012, 10:26 PM
Nick9597's Avatar
Major is a subjective term, but what I mean by it is, doors creak when driving, when body flexes. Teflon tape hasn't helped, adjusting the doors hasn't helped. The only thing that helps is lubing the felt on the doors, that usually lasts about a day or two then the creak comes back. Another (stupid) solution is to drive with the windows down about 1/2 inch and that eliminates the creak.
Old 09-14-2012, 06:39 AM
BMWinSC BMWinSC is offline
BMWinSC
Mein Auto: 2012 X5 35d, 2003 325 Cic
I drive a new 2012 X5 35d and have noticed a similar sound from the driver's door when going over bumps, etc. A squeak or creak - my wife wouldn't believe the car made that sound initially but now she is convinced. The dealer has looked at it once last weekend, said they heard the same sound, and lubricated "something". I didn't have time to get into details. Needless to say, the sound was there on the drive home. We'll revisit.
They did apply the felt tape to the B-pillars and the clicking everyone talks about is gone. My SA also knew of the problem as soon as I started talking about it.
My X5 was part of the recall for improper fitting steering gear or gasket. It didn't have to be fixed per my SA. Not fun to get a call and recall notice on a car with 400 miles on it though.
Old 09-14-2012, 06:43 AM
Rosmoss Rosmoss is offline
Mein Auto: 2011 X5 50i M Sport
Mine is a 2011 so not directly addressing the OP's question but I had the creak, took it in and they fixed it. Crossed fingers because that was two years ago and we're still good. I have soft close doors so that alone isn't a remedy (it's also a pretty pointless feature in my opinion but I digress).
Old 09-14-2012, 07:32 AM
Nick9597's Avatar
Can someone please explain to me what B pillars are? I have a lot of plastic creaking coming from the rear area as well as the door creaking.
Old 09-14-2012, 07:38 AM
BMWinSC
It's the column between the front and rear doors that houses the front seat belts. The bottom portion is hard plastic and is likely the source of the clicking.
Old 09-14-2012, 08:11 AM
Nick9597's Avatar
Thank you for the info. I'll check that out. But for my X5, the creaking has been from the doors (previously described above) and from the plastic crap in the rear cargo area.....actually, all of the plastic creaks come to think of it.
Old 09-14-2012, 03:34 PM
peteo peteo is offline
Mein Auto: X5 35d
My drivers door creaked while driving over speed bumps or anyting else that would flex the car. I was able to pretty much get rid of the creak by putting a small wedge between the door panel and the metal of the door. It is at the front of the door and only visable with the door open. I could cut it to render it invisible but haven't done it.
Pete
2010 X5 35d
2010 R1200RT
Old 09-14-2012, 03:39 PM
Nick9597's Avatar
Could you explain this a little more in detail? I'd like to give it a try.
Old 09-14-2012, 03:45 PM
Mein Auto: X5 35d
I'll take a picture and show you. give me a minute
Pete
2010 X5 35d
2010 R1200RT
Old 09-14-2012, 03:48 PM
Nick9597's Avatar
Thank you so much!
Old 09-14-2012, 03:52 PM
Mein Auto: X5 35d
The blue square you see is a pice of plastic wedged between the door panel and the door frame. It is about an eight of an inch thick. Does that help?
Pete
2010 X5 35d
2010 R1200RT
Old 09-14-2012, 04:02 PM
dkreidel's Avatar
dkreidel dkreidel is offline
Aviator
Mein Auto: cars with studded tires
GF's new 2013 doesn't make a sound after 3,500 miles of driving on highways, poor country roads and gravel.
dk
'16 550xi - alpine white over Amaro brown • every freaking option
'11 Z4 - mojave over beige • 6 speed manual • Münich delivery
...and a bunch of old English motorcycles
Old 09-14-2012, 05:21 PM
Nick9597's Avatar
Interesting. Yes, I see what you did.
How does this help prevent the door creak?
Old 09-14-2012, 09:28 PM
Mein Auto: X5 35d
In my case the panel was rubbing against the door frame causing the creak. First task is determine just where your creak is coming from then what can be done to stop it.
Pete
2010 X5 35d
2010 R1200RT
