BMW Coding and Programming
Discuss coding options and features on your BMW here. |
One touch turn signal blinks 5 times instead 3 times
Hi everyone,
As we all know the F10 has one touch turn signal blinks 3 times and it blinks constantly when you push it harder. My question is how to change the value via e-sys from 3 times to 5 times? Thank you so much! |
This would be pretty useful. i find sometimes 3 clicks isn't enough in certain situations and 5 would be perfect.
Current - 2013 N55 535xi Msport SAT Retired - 2009 N54 335i Msport 6MT Retired - 2000 M52TU 323i ASA Supercharged 5MT More photos of my car here |
This might be it
Found this
CAF [FRM__03CT] 3400 FRM_TMS_AHL_LWR, F0 SCHW_AKTIVIERUNG_OFFSET Werte = 05 The English translation Comment = threshold level for activation of the automatic. Indicator reset. Will try it when i get a chance |
Any update on this… ?
this is the wrong section. LWR is Leuchtweitenregulierung, and SCHW is Schwenk. This is for xenon move up, down, left and right.
look at FRM, 3050 Blinkzyklen_anzahl_tipp
watching for updates.
Original values for me are einmal/werte=01
And comment is saying 0 - einmal and 2 - dreimal Kind of misleading... I would expect seeing dreimal/werte=2 cause the three blinks are enabled in idrive. Right ? So... how do we add/change fünfmal or sechsmal ?
Regards, Alex 2012 w204 Mercedes-Benz C350 4MATIC MY 05/2012 Black/Sahara 2011 F10 535i xDrive MY 01/2011 Sophisto Grey/Black |
you got it
my F30 doesn't have FRM Modul but i found Blinkzyklen_Anzahl_Tipp in FEM-Body there is an other Option like PIA-Blink... some like this. This Wert must be set to "Mehrfach Blinken" its in the Description of Blinkzyklen_Anzahl_Tipp i changed the Werte-Value up to 5 and it Blinks 6 Times so Comment is not nessesary, after changing the Value it sets to UNKNOWN but dont matter 0 = 1 Blinking (1 = 2 Blinking) 2 = 3 Blinking ... 99 = 100 Blinking Have Fun! sry for my english speaking :P its "only" lerned shool-english Last edited by AutobahnCowboy; 09-14-2012 at 02:23 PM. |
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
Weird,
I have tried all kinds of value to put in Blinkzyklen_Anzahl_Tipp (such as Werte=01~10) but nothing change at all. After I change the value instead of default, I still can change blink once or triple in iDrive. Did I miss something? |
I wouldn't expect the iDrive choice to change, only that if Triple Turn is checked in iDrive, it will physically blink what ever number of times you have the Werte Value set to.
No go for me
I could not find PIA-Blink Change WERT to 5, did not make a difference. Where is PIA-Blink, my car is F10.
F10 535xi 01/2011 in FRM -> 3050 -> Blinkzyklen_Anzahl_Tipp -> UNKNOWN/Werte=05
Doesn't change anything. Still blinking 3 times.
Same here!!!
Then maybe older F10s don't have this other option, like for example the FEM-Body I don't remember seeing it on my F10.
FEM-Body on F30 should be equal to FRM on F10 like chriss88 mentioned
i captured it against with 4 Impulses and both changed/important Values here the exact path´s for me FEM-Body -> 3060 LceMaster, 1C ---> Blinkzyklen_Anzahl_Tipp -----> einmal, dreimal (not important) -----> Werte=XX (your wanted Impulses, 0 conforms 1 - 09 is 10) and FEM-Body -> 3064 LceConfiguration, F6 ---> Pia_Default_Tippblinken -----> Einfachblinken, --> Mehrfachblinken <-- (Choose Mehrfachblinken) -----> Werte=01 if you dont have FEM-Body or FRM try to hit "Read Coding Data" on all Modules and open each one itself and search for "blinkzyklen" and "pia". i got for each searchstring only one positiv hit! i also checked how the car will react after i uncheck the idrive "3 times blinking" and activate it again unchecked it blinks only 1 time, after checked it it blinks 4 times like i coded it. so the checkbox doesnt set the value to "3 mal blinken" but rather only activate the "Mehrfachblinken" with the Werte-Config in Blinkzyklen_Anzahl_Tipp Hope you can get it work! Last edited by AutobahnCowboy; 09-15-2012 at 01:18 PM. |
My F10 has "Blinkzyklen_Anzahl_Tipp" but nothing is called "Pia_Default_Tippblinken". I have checked each ECU I have shown on E-sys, Also I tried to find the keyword "Mehrfachblinken" under FRM is also nothing found. Does anyone who has F10 get the issue with me? Thank you! |
Same here. No "Pia_Default_Tippblinken" in any module.
Not find, too. F10. |
I have a f10 and could not find that PIA setting in any module. maybe this is only in F30. Maybe one of the coding expert could chip in.
I may be completely wrong
But In our very initial findings... We believed that pia is basically to mark the parameters that can be exported in to profile ... Per say if we have hud turn signal pia and if we enable it then it will be part of the XML when We export the profile and We can import into other car like a loaner so that we don't have set them again in that car.,, if it is the case then we can ignore that setting if you look around you will find lot of pia parameters Last edited by DreamCar; 09-18-2012 at 04:28 AM. |
Anyone that took the global update on their F10 did the search for this value - "Pia_Default_Tippblinken" ?
#25
http://www.bimmerfest.com/forums/sho...d.php?t=645540 The new 2013 models with the HU_NBT CIC now require HUD_PIA_BLINKER to be set in order for the HUD Turn Signals to be even functional, so it is conceivable here too that Pia_Default_Tippblinken or its F10 equivalent if it exists is required in order to change the number of flashes.
