Old 09-13-2012, 08:20 AM
chull chull is offline
Mein Auto: 325iT
The picture of the iPod Nano in the Five was shown as part of the Bluetooth section of the presentation. As the Nano now has Bluetooth, you do not need a cable at all.
I think that we will see the incompatibility of the iPhone 5 with many BMWs, including my X3 and 135i. The 135i uses a Y-cable, and plugs the USB into one and the analog audio into another on the car. I can see BMW making a new version of this cable, with a combo Lightning AND 3.5mm tied together with the correct spacing. It would work, as would the new Apple adaptor plus a separate 3.5mm cable. To work best, BMW would need a SW update to set the volume on the headphone jack to match the expected volume levels, then use the car's amp for the volume after that. Audio quality would suffer as the signal has to go through the headphone amp first.
My X3 is using the aux in, with a aux-splitter cable, much like the expensive BMW part. I will need a pair of cables now to replace the single and have to tear apart the car to rewire it. In the short term, this will probably be a Apple USB cable and a 3.5mm audio cable. But I can see Chinese entrepreneurs selling a combo cable with a wider connector combining the Lightning and 3.5mm in a single unit.
Cradles will probably fail due to size constraints, and the requirement to get to the analog audio port, which is not yet supported.
Old 09-13-2012, 08:45 AM
sheil sheil is offline
Mein Auto: VO 1M
The difference between using a Snap-in adapter and just a USB cable is the following:
    1. BMW Plugin - changes the iDrive screen to the same look and feel as the iPod function on an iPhone. It allows you to take advantage of all the iPod features (Genius, album art, compiling playlists, etc) that are not available via the basic USB connection. With future iPhone software updates, new features will also be available in the car. An additional benefit comes in the way of increased interface speed
    2. Video playback - enables video playback from the iPhone/iPod
Here's a pic (third screen is the Plugin screen):
Old 09-13-2012, 09:03 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Originally Posted by Stealth.Pilot View Post
Yeah I started the thread.
The point being made is that the snap in dock may not be available for 6-9 months.
In the meantime, those who want snap in functionality can use Apples new Dock Adapter cable to connect the old snap-in adapter to the new iPhone 5. The iPhone 5 won't sit in the cradle, but the cable will allow it to charge and have full snap-in like integration with the car.
By looking at the size of the Lightning adapter and the current iPhone OEM snap-in adapter shape I doubt that you will be able to even plug the iPhone 5/adapter into the snap in at all.
The insertion angle may exceed the limit of the OEM 30-pin connector at the snap in, IMO.
Old 09-13-2012, 09:18 AM
djsilo djsilo is offline
Mein Auto: 2012 550i xdrive
I currently have a docxtender cable and never plug my phone directly into the doc (my case is too large). I imagine if you purchased a 30pin extender cable you could attach an adapter to the end and have the phone outside of the armrest.
Old 09-13-2012, 09:37 AM
Stealth.Pilot's Avatar
The Driver
Mein Auto: 2014 M5
They offer both an adapter and an adapter cable. The latter wont pose a problem.
2014 Porsche 911 Turbo S
2015 Mercedes C300 4MATIC
Memberships: BMW CCA, Peachstate PCA, NMA, AAA, RAC
Sold:
2015 Jaguar F-Type R
2014 BMW M5 Individual Dinan Stage 1
2013 BMW M5 Individual
2012 BMW 550i Dinan Stage 2
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 09-13-2012, 12:32 PM
Technic's Avatar
Mein Auto: 2017 M3
From the point of view of the adapter and the snap-in, it is a moot point -the adapter does not support iPod Out/Video: http://www.bimmerfest.com/forums/sho...9&postcount=23
Old 09-13-2012, 04:09 PM
miamiboyca's Avatar
miamiboyca miamiboyca is offline
Mein Auto: F80 6MT
That is not necessarily true. I have not seen the cabling specs on the iphone but there have been phones that through their connection port give you a directly pipe to the RF receivers in the phone (remember when you had a connector near the antenna where you could connect another antenna?)
I am not saying this is how it works on the iphone, but it is possible that via the 30 pin connector this function was available. Until we get our hands on the phone, the connector, and someone shows how the BMW wiring works we won't know.
We also won't now how much we lose with the adapter, but we will definitely lose something.
2015 M3 - Mineral White, Sonoma, Exec, LED, Adaptive Suspension, HK, 19" Light Alloy, 6MT ED 7/7/15 - Adrian
2013 535i - Space Grey, Biege, M-SPort, Premium, Tech, Cold Weather, Luxury Seating, PDC, 6MT ED-10/11/2012 - PCD - Greg Poland
Old 09-13-2012, 05:15 PM
Technic's Avatar
Mein Auto: 2017 M3
We also won't know how much we lose with the adapter, but we will definitely lose something.
Those are not unknowns.
- Look up the 30-pin connector pinout of the now "old" Apple connector. There is no antenna pin.
- The OEM baseplate do have an antenna connector.
- The Lightning adapter is confirmed to not support iPod Out/video.
Old 09-13-2012, 05:27 PM
miamiboyca's Avatar
Mein Auto: F80 6MT
Technic, that is great that you have access to the info - Can you please...
Please post what the adapter does internally.
Please post the wiring diagram that show how the OEM connector pins out
Please post the internal pinout of the "adapter"
Please post the internal specs of how Apple feeds their receivers.
Utmost appreciation for being able to share this info
Old 09-13-2012, 05:43 PM
Technic's Avatar
Mein Auto: 2017 M3
That's what Google is for, sir...
Old 09-13-2012, 05:46 PM
miamiboyca's Avatar
Mein Auto: F80 6MT
Yeah, that is what I thought. I couldn't find it either.
Old 09-13-2012, 07:15 PM
tadtaggert tadtaggert is offline
Mein Auto: M6 F12
Originally Posted by gspannu View Post
The one extra thing that the cradle connector gives (over the standard USB connection) is an inductive antenna connection via the car's shark-fin antenna - hence a better signal.
Considering how poor radio reception is in BMW's in general, I'm not sure that's a good thing or not.
Old 09-13-2012, 10:10 PM
whitby whitby is offline
Mein Auto: BMW
To summarise what I know and have found out:
1. The old 30 pin connector does not have an RF connection (as pointed out by Technic). The snap in adapter provides inductive coupling from the iPhone antenna to the cars antenna. There is no direct connection.
2. The new 9 pin connector is a digital interface. The adapter has a chip that is used to verify the connection as legitimate. It may also do some protocol conversion, not sure about that.
3. The adapter does not support the so called iPod interface protocol (which was supported over the USB interface) so there will be no control of the play back system and cover displays etc. from iDrive. Presumably this is a protocol change so it is possible that BMW can update software to use the new interface.
4. The analogue component and composite video interface in the old 30 pin connector is no longer supported, so the video feed in the current BMW iDrive interface will no longer work. Presumably the new 9 pin connection supports a digital interface (probably some variant of HDMI) which will require more than a software change to iDrive. If a new adapter is designed it will need to take the digital video feed and convert it to component video which may not be to the media industries liking who outlawed component video because it is easy to use for copying purposes.
Overall it does not look very promising for an adapter that can take the iPhone 5 and make it work in the same way as the older iPhones with the 30 pin connector.
Cheers,
2015 Glacier Silver 428i Gran Coupe
2015 British Racing Green Mini Cooper S 4 Door Hardtop
2012 Space Grey 528i MSport - retired
2013 Valencia Orange X1 xDrive 28i Msport - retired
Old 09-13-2012, 10:13 PM
miamiboyca's Avatar
Mein Auto: F80 6MT
Completely different situation. Apples and oranges as the saying goes...
Old 09-14-2012, 09:52 AM
ksqrd ksqrd is offline
Mein Auto: 2013 535i
Thanks for the very helpful post. TUAW is reporting preliminary Apple-derived information that an adapter to enable video out may be forthcoming (but probably to either VGA or HDMI). Interesting how this will play out.
Current: 2013 535i M Sport, Imperial Blue, Black Nappa, Premium/Technology/Cold Weather/DA/DA+/Ceramic Controls/Premium Sound
Retired: 2001 E39 530i Sport, 1976 2002
Old 09-14-2012, 10:07 AM
shaunatl shaunatl is offline
Mein Auto: E46 M3, i3, i3, SpecE30
Can you provide a link to the source for this information?
Old 09-14-2012, 02:00 PM
Sonic Boom Sonic Boom is offline
Mein Auto: 7 series
http://www.tuaw.com/2012/09/13/light...-ipod-out-doe/
Old 09-14-2012, 02:08 PM
Originally Posted by Sonic Boom View Post
Thanks, but the information provided in that post does not match up with #3 in the list above. The 30 pin adapter doesn't support "iPod Out" or video output, but it appears that most other functionality is supported. "iPod Out" is not required for the items listed above, specifically album art and "control of the play back system".
Old 09-14-2012, 02:21 PM
Mein Auto: 7 series
Yes, I know it doesn't; never said it did. I was simply trying to steer you towards information to clarify.
Old 09-14-2012, 02:24 PM
Old 09-14-2012, 03:27 PM
Technic's Avatar
Mein Auto: 2017 M3
FYI: Album Art/Cover Art are image data files, not video.
The USB port handle those with the music data files.
Old 09-14-2012, 03:44 PM
Exactly...
Old 09-14-2012, 06:19 PM
LMK LMK is offline
Mein Auto: 2014 550i xDrive M-Sport
http://www.wired.com/autopia/2012/09...ning-bmw-mini/
Old 09-14-2012, 09:01 PM
pharding pharding is offline
Mein Auto: 14 550i
Anyone know the gain provided by the roof-mounted telephone antenna? I can't seem to find any specs.
1+ bar on Verizon. It works quite well.
04 Successfully lobbied BMW NA and BMW FS to prohibit dealers from using residual values based upon Euro Delivery MSRP and to use US MSRP saving BMW Enthusiasts several thousand dollars on each lease
17 540i Euro Del
14 550i Euro Del
14 X3 2.8i
11 550i Euro Del, Retired
08 550i Euro Del, Retired
06 330i Euro Del, Retired
04 545i Euro Del, Retired
01 530i Euro Del, Retired
Old 09-14-2012, 10:00 PM
nsfw nsfw is offline
Mein Auto: F34, F31
ugh. i think everything is a little premature at this point, but if BMW apps doesn't work then i'll be super pissed that i spent the money on whole setup. I already know the snap-in is lost.
An interim solution is mentioned in the comments. Stick your iphone4/4s in the snap-in or usb and tether off your iphone5's data connection.
The snap-in was pretty nice to keep the solution clean, i also got better cell/data reception but the video and ipod plug-in interface wasn't very useful for me.
