E34 (1989 - 1995)
repair of motor m50
hello.
I cihan turkey I have a non-VANOS M50 E34 520i my vehicle engine to the renewal process I want to increase the volume of the cylinder I want to make, for example 2.8 or 3.0 liters I need spare parts for this process, which will be for example, 2.5 crank and 2.5 or 2, 8 cylinder head must dimensions of the cylinder will be, but how many mm (84mm-86mm-87mm) What will be the piston rods result going to be change in the air flow meter result going to be change in the idle valve injectors, ECU, intake manifold change Can you help me my vehicle is a 1991 full model M50 engine electric seats sunroof rear-curtain (manual) 4 glass electric air conditioning 17inch m contour wheels 10 speakers and the original amp headlights and fog wash did no accident fail english sorry |
The easiest way to do the engine modifications you want is to get a doner car from a crash and transfer the parts over. You would need so many parts to make a modified engine work it easier to get all the parts from one other car that you know worked. It is a very hard job no matter how you try to do it. Another suggestion is to simply sell your car and buy the one you want with the larger engine.
Ys, buy a crashed e36 328i and go from there
