Old 09-07-2012, 05:33 AM
dudley07726 dudley07726 is offline
Mein Auto: 2012 X3 2.8, 2013 MB E350
Low Coolant Warning
Getting this mesasage on the NAV screen. A bit surprised. Had the X3 since March and it only has 3600 miles! Will call dealer for an appointment.
Old 09-07-2012, 06:08 AM
02420X3 02420X3 is offline
Mein Auto: 2011 X3 35i
You may be able to just stop by and have them top it off. If it happens a second time then that would be cause for more concern, and for a thorough checkout.
Old 09-07-2012, 08:37 AM
gfeiner's Avatar
gfeiner gfeiner is offline
Mein Auto: 2012 X3 xDrive35i
Even easier: top it off yourself.
Old 09-07-2012, 09:08 AM
Connected Drive - Service request
Bringing it tomorrow.
Old 09-08-2012, 09:47 PM
Coder Coder is offline
Mein Auto: 2011 X3 xDrive35i
What a perfect opportunity for an old line: "They all do this."
Seriously, just after a reading a post on this last year, our 2011 X3 displayed the same warning, albeit at around 12,000 miles. The post suggested that this was common and related to hoses expanding after some heating/cooling cycles. Not sure I really believe that, but after adding maybe 2 cups of coolant it hasn't happened again; we're approaching 21,000 miles. Note that when adding coolant, at least on the 6 cylinder, there is a fill level ridge/insert inside of the filler. Fill to just cover this.
BTW, I used BMW antifreeze for the 'big' top-off beacause I'm anal and we live in a cold climate. Could just as well have used distilled water from the grocery store, given the minute amout used.
Old 09-09-2012, 11:09 AM
Brought it in yesterday figuring that a mechanic would check it and add some coolant. No, the service advisor had a container of coolant (by his station) and added it himself right at the check-in station and off I went. Odd, I thought!
Old 09-16-2012, 05:47 AM
Doug in NC Doug in NC is offline
Mein Auto: 2011 x3 28i
I got the same low coolant message at about 11,000 miles. I thought this was odd as I haven't seen any leaks. I add a small amount, guessing less than a cup.
Old 09-09-2013, 04:04 PM
TokenMaster's Avatar
TokenMaster TokenMaster is offline
Token Master
Mein Auto: Coded F30
I brought my F30 today for this very same reason. Got the warning Friday and will come on again after a few minutes of driving. One of the technician topped it off, but I noticed that it was above the Max level before he even put some more coolant into it. This didn't go well for me and I insisted on talking to one of the service managers. Turns out, there's a recall for the coolant expansion tank "B17 01 13". Had to leave my car for that and the wind noise I complained about.
Code My Bimmer| FDL Coding Video Guide -Blogger/Youtube | EST Software Token demo | E-Sys Launcher Premium and PRO
Never download already patched E-Sys from Torrent sites
Old 09-09-2013, 04:08 PM
Token Master
And looks like they're going to change the oil too for low mile use. It's been a year and it's only at 8900 now
Old 09-09-2013, 04:57 PM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
Any idea what the manufacturing date range is for the coolant expansion tank recall?
Old 09-09-2013, 05:02 PM
Token Master
I have no idea. It doesn't show up on the recall section of bmwusa.com. Lead technician mentioned something about transparent tank. Not sure if newer car have the non-transparent tank but I'll find out tomorrow what they replaced it with.
Old 09-09-2013, 05:30 PM
But the recall is on the F30's, not necessarily applicable to the X3.
Old 09-09-2013, 10:53 PM
IRBD IRBD is offline
Mein Auto: '13 335xiM / '13 X3 35iM
Same happened to me with about 6,000 miles. I put in a fresh bottle of Costco water and it's fine. Remember, the freezing temperature of a water / coolant mix is much lower than straight coolant (or straight water).
Old 09-10-2013, 02:52 AM
Token Master
Yes, it was for F30 but I wasn't sure it was limited to that series. The point is that BMW don't seem to actively notify owners, but passively acting on it, waiting for customers to come complain. And if you don't talk to the right people, you'll never know. I mean, I went there and the guy just topped it off, and was ready to send me away, so it's worth talking to your service manager and ask.
Old 09-10-2013, 02:58 AM
Token Master
I thought the optimum mixture is 50/50 to 60/40 coolant to water ratio? If you added plain/pure water, you lowered the coolant ratio to say 45-55, lowering the freezing point but making it less efficient as a coolant. It's probably OK where it's mostly cold all the time though
Old 09-10-2013, 05:23 AM
I always check the TSB/recall bulletins for the X3 is there is nothing on there for the coolant tank.
Old 09-10-2013, 06:52 AM
I have a 2012 5 series and a 2013 X3 35i, both of the expansion tanks are not transparent. One have to open the cap to figure out how much coolant is in there, what is dangerious and dumb design. On top of that, the max and min indicators are hard to read, instead of a marker on the side of the tank, it is a step like level indicator which is very confusing. This design adds no benefit to its function or the user and it actually makes it less user friendly in my opinion.
Old 09-10-2013, 09:24 AM
Token Master
Is this where you enter your short VIN to find out recalls applicable to your vehicle, or a list of all TSBs? BMW USA used to have this page listing all recalls for all series but I can't seem to find it anymore.
Recall check page didn't yield anything when I checked prior to going to the dealership
Old 09-10-2013, 09:28 AM
Token Master
I can see your frustration. The semi-transparent tank max level is exactly at the middle/seam, while the markings aren't exactly clear, it is very convenient to just look at it to get a visual indication of where the fluid level is
Old 09-10-2013, 10:23 AM
Remember that when my system lost 0.5l it was a 50/50 mix, so when I added 0.5l of water the mix is now 47.5/52.5. Even at 40/60 I'm good to -25C. I read somewhere that if you use a 25/75 coolant/water ratio the temperature drops 10-15 degrees and you've only dropped the cooling ability (heat capacity) of the system by 5%. Reason is that the specific heat of coolant is less than that of water - coolant (antifreeze) holds less heat than water, so the higher the percentage of water the more heat is moved. I believe the optimal ratio to get the lowest freezing temperature is 65/35, but at that mix the cooling capability is down by 20% (pure water gives 100% cooling capacity, but the engine corrodes).
Old 09-10-2013, 12:19 PM
Do you have a semi-transparent tank? My tank is black and I cannot see thru it at all.
Old 09-10-2013, 06:37 PM
Token Master
OK, so it isn't much then, and you seem well aware of the trade off of using water and coolant combination. Good info for eveybody
Old 09-10-2013, 07:58 PM
Token Master
I do and the replacement is still semi-transparent. Work order mentioned about about corroded sensor connectors. They replaced the tank and cable
Old 09-11-2013, 10:37 AM
Is your X3 a US model? If so what year? I have a black tank for some reason.
Old 09-11-2013, 11:58 AM
His vehicle is an F30 not an X3 so we don't even have the same tank he does. Makes it kinda confusing when it is posted on an X3 board.
