Old 09-13-2012, 02:29 PM
bowang bowang is offline
Banned
Mein Auto: 2007 X3
Battery for 2007 X3: EverStart MAXX-H6 or MAXX-H8?
Hello,
Walmart Battery Finder shows that the EverStart MAXX-H6 fits my 2007 X3. Some owners in here mentioned that MAXX-H8 fits as well. Does anyone know which one is better? MAXX-H6 is about $110, how much for the MAXX-H8?
Thanks!
Old 09-13-2012, 02:52 PM
usaret usaret is offline
Mein Auto: A Gamma Goat
Originally Posted by bowang View Post
Hello,
Thanks!
The H8 is bigger and thus has higher capacity. In Ohio in the winter this may come in handy. Especially for the relatively minor difference in cost between the two.
Old 09-14-2012, 07:48 AM
Banned
Mein Auto: 2007 X3
Thank you very much!!
Old 09-14-2012, 08:11 AM
You're welcome.
Old 09-15-2012, 05:00 AM
ncord ncord is offline
Mein Auto: 2006 X3
I used the H8 from Walmart and it fits perfetly.
Old 09-15-2012, 07:41 AM
codog2 codog2 is offline
Mein Auto: 5
Just installed mine this morning (05 x3). Perfect fit. More CCA (720 versus 900).
Don't worry if the vent tube is missing from the new battery. The original will fit
Old 09-16-2012, 04:22 PM
PC in Ohio PC in Ohio is offline
BMW CCA Member
Mein Auto: 2007 X3
good to know. I just had my battery checked (original on my 2007) and it's putting out ~ 850CCA according to the guy at Advance Auto. I'll be keep an eye out though for a new one just in case.
Do you have to go to the dealer to get it certified?
Old 09-17-2012, 04:39 AM
Mein Auto: 2006 X3
I didn`t. Just installed it and thats it .Its been 6 months now.
Old 09-17-2012, 08:11 AM
From what I've been able to find our cars are not new enough to need battery registration (someone please correct me if I'm wrong).
http://www.munichmotorsport.com/wordpress/?page_id=164
http://www.hella.com/produktion/Hell...mt/IBS/IBS.jsp
The new X3's have an IBS negative cable: http://www.realoem.com/bmw/showparts...69&hg=61&fg=30
And ours is just a plain cable with clamp: http://www.realoem.com/bmw/showparts...34&hg=61&fg=30
Another reason I REALLY LIKE my 2009.
Old 09-17-2012, 09:56 AM
Banned
Mein Auto: 2007 X3
I installed a new battery (AutoCraft H8-AGM) from Advance Auto Parts last Saturday. So far everything works great. It's only $125.99 after using a link my friend sent to me. The link saved me $35 instantly. The battery can be used on both X3 and X5. I got free installation at local store.
Here is the link (up to 40% on everything): http://advanceautoparts.**************************
H8-AGM Spes:
Acid Included: Yes
Battery Type: AGM
Battery Usage: Auto/Truck
BCI Group Size: H8
Cold Cranking Amps: 900
Cranking Amps: 1000
Deep Cycle/Starting: Dual Purpose
Maintenance Free: Yes
Reserve Capacity: 160
Terminal Type: SAE
Weight: 59.45
Length: 13.94
Width: 6.938
Height: 7.5
Old 10-23-2013, 08:07 PM
Snowcatt Snowcatt is offline
Mein Auto: 2010 M3
M3 Battery
My 2010 M3 battery is getting weak (670 CCA now, 900 new) and the display is indicating low voltage. The dealer says the replacement battery has to be certified; they also say if that isn't done it could cause other electrical problems because the electrical system could over charge the new battery. Does anyone have any information on this?
Old 10-24-2013, 12:14 PM
05X3newbie 05X3newbie is offline
Redheaded Firecracker
Mein Auto: 2005 BMW X3
I use the H6 (only because they did not have H8 and I was in a pinch) - everything fits like a charm including tubes. Highly, highly recommend. Make sure to take your old battery in for a core refund if you don't upon purchase. Scored something like $19 back.
Old 10-24-2013, 02:01 PM
Mein Auto: 2004 X3 2.5i
For a 2010 M3 I would expect that the new battery should be registered by a BMW dealer or and indy having the right equipment.
For the E83 X3 there is no ability to register it and a new battery, whether an AGM or traditional flooded cell, just has to live with what the unsophisticated charging system wants to do.
