F10 Coding using a MacBook Air - Bimmerfest - BMW Forums
Old 09-16-2012, 08:24 PM
ksqrd ksqrd is offline
Mein Auto: 2013 535i
I have an F10 on order that is now about 10 days away that I definitely want to code. Only problem is my laptop is a 2011 MAcBook Air, with flash memory and therefore limited storage, as well as no Ethernet port. No flaming, please, as it's a great laptop for everything I need (until this rather unconventional use). I am a technophile so not afraid of the learning curve.
I'm wondering if others have coded using this setup. I realize I need to use Parallels or VMWare and then install XP, but I also wonder if I can install the files on an external (eg, USB) drive and also whether the Apple USB to ENet cable works for this. I'm a little wary, as by the time I buy the virtualization software, XP, USB/ENet cable and Coding cable, I will have spent a bunch. Before I consider that, I'd love to hear some feedback.
Otherwise if someone can point me to a coding solution in the Miami area, that would also be welcome so I can assess my options. Thanks in advance!
Current: 2013 535i M Sport, Imperial Blue, Black Nappa, Premium/Technology/Cold Weather/DA/DA+/Ceramic Controls/Premium Sound
Retired: 2001 E39 530i Sport, 1976 2002
Old 09-17-2012, 01:44 AM
wdimagineer's Avatar
wdimagineer wdimagineer is offline
Mein Auto: 2013 M5
Yes. It works totally fine. I was using my MacBook Air and the Apple USB Ethernet adapter. I've since upgraded to a Retina MacBook Pro and have also coded using both the USB and Thunderbolt Ethernet adapters.
I don't have the driver file handy, but I found the USB Ethernet drivers for Windows by Googling.
Current: 2014 X5 xDrive50i ZMM - Alpine White/Mocha (Mods In Progress!)
Past: 2014 Jeep SRT - 2013 Tesla Model S P85+ - Bimmerpost Featured 2013 F10 M5 - 2012 550 xDrive - 2011 M3 ZCP
Old 09-17-2012, 04:53 AM
Thanks! Could I install the files needed (many GBs needed, I understand) on an external drive? My solid state drive is mostly full.
Old 09-17-2012, 10:48 AM
Mein Auto: 2013 M5
Yes. Just put the VM on the external storage. Everything will work just fine. VMware and Parallels are great for that. I have lots of VM's on USB sticks that we give to employees for testing, etc.
Old 09-17-2012, 10:56 AM
Thanks for the prompt and very helpful responses.
Old 01-07-2013, 05:27 AM
blair780 blair780 is offline
Mein Auto: X5, M4, M5
I'm running VMware on my MacBook but have been unable to get Windows in VM to connect to the car via ethernet cable. I DO have a green network connection on the Mac side but on the Windows side its showing yellow (limited or no connectivity). I've confirmed a bridged connection with VM but obviously there is something else wrong.
Old 01-07-2013, 06:08 AM
April1 April1 is offline
Mein Auto: X3 2011
Seeing limited connectivity between windows and car through ENET cable is very normal.
It takes about 50-60 seconds to show limited connectivity. You can note down this set IP address on your windows and set that as static on your windows. That would establish instant connection between windows and car and would not show limited connectivity. Note: even the limited connectivity is acceptable if you do not want to set an static ip on your windows for this connection.
Old 03-02-2013, 04:32 PM
spadae2 spadae2 is offline
Mein Auto: 2015 750ix
I used my MacBook Pro running VMFusion - Win Pro 7. Data on Mac HD, E-Sys installed on C drive. Works without issue.
Make sure you change the network adapter to Ethernet and set to DHCP.
__
2015 750i X-DRIVE, M-Sport, (born 3/6/2015), Moonstone Metallic, Ivory White/Black w/Honey Walnut, ARS, B&O Sound, Escort 9500ci. VO and FDL Coded. BMS Stage 1.
Old 03-03-2013, 08:51 AM
Merlosso's Avatar
Merlosso Merlosso is offline
Mein Auto: 2011 E90 M3 Sedan
I'm using a mid-2012 11" MacBook Air for coding E and F Series cars and it's awesome. I installed Windows 7 Pro using Bootcamp though; I prefer to boot directly into Windows rather than using a VM. For ethernet I'm using the Thunderbolt to ethernet adapter.
The small size is great for use in a car, the screen resolution is plenty for coding, the backlit keys are great in low-light areas, the solid aluminum chassis is as sturdy as can be, it's very light, and most importantly, this thing is FAST.
1995 E36 M3 Track Car
2011 E90 M3 | BMW Welt Delivery on 09.20.2011
2015 F22 M235i | BMW Welt Delivery on 09.29.14
Old 03-04-2013, 12:43 PM
Yobyot's Avatar
Yobyot Yobyot is offline
Mein Auto: F30
I use a mid-July 2011 MBA with a 256GB SSD and 4GB RAM. I code via a Parallels 8 VM in which I installed Windows 7.
In the VM, I stripped out EVERYTHING I didn't need -- no Office, no nuthin'.
To avoid having to duplicate the very large data files in the VM, I used the mklink command (new in Windows 7) to map one directory to the other. (I don't recall which two directories are duplicated, but this saves a fortune in disk space.)
And, I since don't code all the time, I just off-load the whole VM to a backup (spinning) drive and re-load it before a coding session.
Some notes:
  • BE SURE to turn off the WiFi adapter in the MBA and use ONLY the USB Ethernet adapter or the Thunderbolt adapter (I use USB)
  • Make sure to tell Parallels to BRIDGE (not SHARED NETWORK) the wired Ethernet adapter. If you don't, you get nothing since the OBD II port will not see the virtual adapter
  • I prefer to run the Windows VM in full-screen mode to avoid being distracted. It's just superstition, but I'd hate to lose the focus on the VM, not be able to get it back and have Parallels suspend the VM during an FDL code.
  • For that very reason, I turn off all sleeping settings anywhere and everywhere I find them.
If you do all this, you essentially turn the MBA into a temporary dedicated Windows machine -- with advantages others don't have. You can easily have multiple versions of the machine. You can create a VM that contains the as-shipped version of your car for backup of not just the CAFD files -- but the whole stinkin' environment needed to restore every ECU. You can try different levels of data and E-Sys easily.
It's more work, but coding from a VM is better, both from a flexibility and reliability standpoint. I'd do it no other way.
MY12 335i ZSL with a deep dive into the options list
Produced: 2012-06-22
ED: 2012-07-19; Arrived in Jersey City: 2012-08-23
Redelivered: 2012-09-12
Old 03-04-2013, 06:29 PM
shawnsheridan's Avatar
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Some notes:
FYI. Good thinking with mklink, but you are working off the original instructions which incorrectly had the files duplicated in both of these locations:
C:\ESysData\psdzdata\swe
C:\ESysData\SWE
This was a mistake. Nothing is needed in the C:\ESysData\SWE folder.
Also, for my money, if I was going to setup a VM, I would go with XP. There are "other" BMW Programs that simply will not run on anything but XP 32, but if you are only going to run E-Sys, then Win7 32 or even 64 will work fine.
Old 03-05-2013, 05:26 AM
Yobyot's Avatar
Mein Auto: F30
C:\ESysData\SWE
Good points -- I didn't know that the psdzdata\swe and swe duplicated directories were a mistake -- but you as you point out, no harm done in my VM since I used mklink.
I don't do anything more than coding on my BMW -- but what scares me is that there are BMW programs that still *require* Windows XP. Not to go off topic too much, but XP is ancient and totally insecure.
It scares me that BMW is doing things with control unit programming on an OS base that's archaic and dangerous.
Old 03-05-2013, 04:47 PM
TRIPLE_O TRIPLE_O is offline
OOO
Mein Auto: F80 M3
Yobyot, why don't you just run ESYS directly from Windows 8?
Old 03-05-2013, 05:11 PM
Yobyot's Avatar
Mein Auto: F30
I'm a security nut. Big Java apps -- which is what E-Sys is -- are weak in security by themselves. And they require you to keep Java installed on your real machine, which if you follow security news you know is the target of many exploits.
Plus, I am currently using a MacBook Air. I do have a new ThinkPad on order -- but that won't change the way I run E-Sys. I'll code from a virtual machine even when I run a PC.
Old 10-17-2014, 09:03 PM
DominikB DominikB is offline
Mein Auto: F10 535i 2011
I was struggling for about an hour with the USB to Ethernet adapter on MacBook air and Windows running in VMWare. (I think the same would apply to Parallels though).
It is best that you actually do not bridge any adapters.
Make sure the USB adapter (since it's a USB device) is not recognized in Mac OS, but instead recognized in virtual machine. Windows will install the drivers for that USB device (or find the driver online if it can't).
Then DISCONNECT and DISABLE any other network adapters in the virtual machine settings. The only available connection will be the USB connection.
Then ZGW magically appeared and everything started to work.
Old 10-18-2014, 06:05 AM
svc0x80 svc0x80 is offline
PM for free tokens.
Mein Auto: F82 (soon)
The biggest threat with java is having it enabled in the web browser...I can't think of a single reason why anyone would write a java applet in this age. Disabling java in the web browser takes care of this issue. I believe E-SYS comes with its own version of the JRE (Java 6), so you may not need to install java on the machine.
