Old 09-13-2012, 09:30 AM
Ionic202 Ionic202 is offline
Mein Auto: 2013 535i xDrive
HUD Turn Signals
I am trying to activate the HUD turn signal in my 2013 535ix.
1. HU_NET / HUD_TURNSIGNAL = aktiv
2. KOMBI/BLINKER_HUD_ENABLE = aktiv
There is no checkbox that shows up in the HUD settings. I have also found that the HUD_TURNSIGNAL is not in the 3000 HMI section as shown in the cheat sheet, but is in the 3001 EXBOX section on my car. Any ideas from the gurus?
2013 535i xDrive, Imperial Blue Metallic, Oyster and Black Nappa Leather, ZCW, ZDA, ZDH, ZLS, ZMP, ZPP, ZTP, 2TB, 323, 416, 4CE, 4U1, 5AC, 677, JB4 Tuner
Old 09-13-2012, 10:12 AM
bmguy bmguy is offline
Mein Auto: 550xi
When I enabled it; you had to click on "display options" first, then it gave you alist of itmees you can check, and uncheck; the "display Options" (maybe exact text is different) looks like a title for that menu, but when you select it, it brings up a bunch of things you can show or hide on the HUD, turn signals will appear in that list if you did everything right
Old 09-13-2012, 10:59 AM
The checkbox on the HUD display options is not coming up with the turn signal checkbox. I have checked the coding multiple times and it shows in the HU_NET and KOMBI that they are aktiv.
Old 09-13-2012, 12:40 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
What are the CAFD File names for your HU_NBT and Kombi ECU's?
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 09-13-2012, 01:02 PM
AutobahnCowboy AutobahnCowboy is offline
Mein Auto: BMW
ive set today the KOMBI/BLINKER_HUD_ENABLE to aktiv but not the second one.
id no access to internet while coding so i could only watch some pdf´s i got
currently ive the checkbox for "Blinker" in settings but no Blinker in HUD while driving around
i try to set the other option to aktiv too and will report
Old 09-13-2012, 01:56 PM
Originally Posted by shawnsheridan View Post
what are the cafd file names for your hu_nbt and kombi ecu's?
hud_nbt - cafd_00000ded_001_019_008
kombi - cafd_00000069_009_000_042
Old 09-13-2012, 06:17 PM
Well, it could be different in 2013, but I highly doubt it. Just to make triple sure though, please check the following:
1) Code KOMBI / BLINKER_HUD_ENABLE = aktiv - This actually enables the feature.
2) Code HU_NBT / HUD_TURNSIGNAL = aktiv - This adds the iDrive Checkbox to toggle the feature on and off.
3) Go into iDrive HUD Settings, and enable checkbox for Hud Turn Signals as shown in attached picture.
- BMWCCA #446923
- flick
Old 09-13-2012, 06:45 PM
1) yes
2) yes
3) no check box on settings screen.
Old 09-13-2012, 06:53 PM
Is your car a 2013 with the new HU_NBT, and can you confirm that your HUD Turn Signals are working?
- BMWCCA #446923
- flick
Old 09-13-2012, 06:55 PM
1) yes
2) yes
What options are shown on your HUD Settings Screen? Can you post a picture of it?
- BMWCCA #446923
- flick
Mein Auto: 550xi
No Sorry - I'm a 2012 Nov15/2012 build...
Old 09-13-2012, 07:02 PM
Ok. We need someone else with the new HU_NBT to see what is going on.
Paging @falcongeek ...
- BMWCCA #446923
- flick
Old 09-13-2012, 07:10 PM
falcongeek falcongeek is offline
I did try coding the HUD turn signals when I first started coding and was not able to get them working either. I set both KOMBI BLINKER_HUD_ENABLE and HU_NBT HUD_TURNSIGNAL as aktiv and also did not get a checkbox to show in the iDrive HUD settings.
I did some digging a while ago and couldn't find any additional settings that I though needed to be changed, but it is possible that I missed something.
Adam
Old 09-13-2012, 07:16 PM
It is the same as prior to coding.......
Name:	IMG_0295 (Small).JPG
Old 09-13-2012, 07:20 PM
Adam
Ok. Not good, but at least we know it is an HU_NBT issue. Thanks for confirming. So, we will need to keep digging.
- BMWCCA #446923
- flick
Old 09-13-2012, 07:23 PM
Adam
I have also been looking in other sections and CAFD files for anything that has turn or blinker. No luck so far. Does it being in the 3001 EXBOX instead of the 3000 HMI section maybe have something to do with it?
Old 09-13-2012, 07:28 PM
I have 47.1, is it possible that this is "fixed" in 47.4?
Old 09-13-2012, 07:34 PM
Maybe, but I think its an equal probability that if it will work it will work in 47.1 too and there is some other coding we need to find.
- BMWCCA #446923
- flick
Old 09-13-2012, 07:43 PM
I am in 47.4.......
Old 09-13-2012, 08:32 PM
I am in 47.4.......
Well, that confirms that. It is likely that the HU_NBT firmware went unchanged from 47.1 to 47.4, so the ECU is the same. So, it is find some other missing coding, or hope a future firmware corrects the issue.
- BMWCCA #446923
- flick
Old 09-14-2012, 06:24 AM
Mein Auto: BMW
i cant get it work on my F30
1. HU_CIC / HUD_TURNSIGNAL = aktiv
Checkbox is there and choosen
but no lights in HUD
Old 09-14-2012, 06:43 AM
I have never coded HUD Turn signals on an F30, so I can't say for sure whether it should work.
Has anyone coded an F30 and got it to work?
- BMWCCA #446923
- flick
Old 09-17-2012, 11:19 AM
digital digital is offline
Mein Auto: 2013 535i xDrive M-Sport
Hey guys, I had the same issue with my 2013 535i as well. I figured it out eventually. You need to set one of the PIA options to aktiv (I don't remember the name). I will post it here once I get home.
Old 09-17-2012, 11:24 AM
This will be good to know, although I hope it does not turn out to be a PIA setting that exists in F30 only and not F10 like this one:
Pia_Default_Tippblinken
http://www.bimmerfest.com/forums/sho...182&highlight=
- BMWCCA #446923
- flick
Old 09-17-2012, 11:26 AM
Mine is F10 2013 with the new Nav. I'll keep you posted.
