fog lights - Bimmerfest - BMW Forums
Old 09-17-2012, 01:45 PM
beemer1804's Avatar
beemer1804 beemer1804 is offline
WAR MACHINE
Send a message via AIM to beemer1804 Send a message via Yahoo to beemer1804
Mein Auto: 95 740IL
fog lights
if my fog light indicator comes on when switched to the on position eluminates but my fog lights are not coming on, does it mean my bulbs just need to be changed, keep in mind i have HID FOGS, if my ballast is not working of the bulb is just blown will my indicator turn on regardless? and on the cluster console it says to check foglamps, if anybody have any ideas please let me know.
Old 09-18-2012, 06:06 PM
Flyingman's Avatar
Flyingman Flyingman is offline
hang up and drive!
Mein Auto: 335d
Beemr, I see you got no takers.
I just got a fog light warning so before turning car off checked my lights. My Left Fog Light is burned out. The warning is present whether the light switch is on or not. They must monitor the resistance through the filament so when it is open (i.e. infinity) the computer recognizes that as a fault.
Now the big question: Is it covered by the maintenance agreement or not???
Or, how many BMW afficionados does it take to change a light bulb???
My experience over the years is that as soon as one light burns out, the other is sure to follow, so should go ahead and replace them both.
2016 Black 328D Sports Line/Premium, CPO (20k miles), Pirelli RFTs
2010 Black 335D Sport/Premium, Michelin PSS 235/265 (120k Club, now RET!)
2000 Silver Z3 3.0i (Ret)
1999 Silver R1200C (Ret)
1968 Black 1600 Coupe (Ret)
Old 09-19-2012, 12:29 PM
beemer1804's Avatar
WAR MACHINE
Mein Auto: 95 740IL
Yea, people tend to miss the simplest things, imna just change them out and see what happens.
War Machine
Old 09-20-2012, 07:36 PM
BMWFatherFigure's Avatar
Old School
E38 HID fogs? Must be after market. Standard globe is H3. IMO don't go over wattage as that can damage the unit (excess heat). Can go with +X% light output at same (55) watt power. Also HID's do not use filiments only cathode/anode/gas setup.
Current:
E38 Parts Car
Previous:
Old 09-20-2012, 07:39 PM
beemer1804's Avatar
WAR MACHINE
Mein Auto: 95 740IL
Can you dumb it down a bit for me? So what your saying is that either my lights are burnt out or my fog unit?
War Machine
Old 09-20-2012, 07:49 PM
Old School
Fog Unit?? I think you have H3 globes in the fog lights, not HID. Change the H3 globes. Stick to 55w. Use +x% output if you want to. If you do have HID (not to be confused with xenon globes) then I belive they will be aftermarket by a PO..
Current:
E38 Parts Car
Previous:
Old 09-20-2012, 07:55 PM
beemer1804's Avatar
WAR MACHINE
Mein Auto: 95 740IL
Yes they are aftermarket, but i will take them out and just put in H3's
War Machine
Old 09-20-2012, 08:08 PM
Old School
Current:
E38 Parts Car
Previous:
Old 09-25-2012, 05:57 PM
Flyingman's Avatar
hang up and drive!
Mein Auto: 335d
Be sure and check out the youtube videos on how to replace the drive/fog lights. Not as easy as it might seem at first glance. Involves possibly rasing vehicle up a bit and removing mud skirts, etc...
Old 10-04-2012, 08:38 PM
BimmerBro BimmerBro is offline
Mr_Bimmer
Send a message via AIM to BimmerBro Send a message via Yahoo to BimmerBro
Mein Auto: 2001 Bmw 740i
I think I read somewhere if you put in any higher wattage than the H3 55w's the system will give a fault. Something about the higher wattage it doesn't like. But can't you get the new h3's in the bright whites? almost xenon look?
Old 10-04-2012, 08:48 PM
beemer1804's Avatar
WAR MACHINE
Mein Auto: 95 740IL
Well i took out my fog lights and to mysurprise there was water in the connectors, i meed to get new hid's mu fog ligjts were gutted so i cant go back to stock without buying a new fog light assembly
War Machine
Old 10-05-2012, 09:52 PM
Old School
You can get H3 globes in lots of colours and wattages. IMO never exceed 55 watts. To get more light select a globe that gives X% more light. Works for me on my cars.
Current:
E38 Parts Car
Previous:
Old 10-06-2012, 02:05 PM
setconstr setconstr is offline
Mein Auto: 2001 740i spt 2008 cl550
re
I went through all the foglight changes that everyone has to get white looking fog lights to match the headlight , my advice is use stock BMW bulbs and oem Hella fog lamps the best price I have found is here : http://www.oembimmerparts.com/category_s/1929.htm if you want to go with hid 's then you need to get a kit but my experience is they still throw faults and it just bugged me to much so I went back to stock. I see some ass on Ebay selling what is supposed to be a hid fog lamp but all it is is a chinese fog lamp and an hid kit the whole thing would cost about 40 bucks apiece and he's asking $600.00 so anyway my opinion is go OEM and spend your money on a nice Dice Mediabridge thats something that works great on our cars .............
Old 10-06-2012, 11:16 PM
Old School
On the WATTage thread - Watts = HEAT. Heat in excess of the amount the enclosure is designed to disapate will build up and damage the unit to a greater or lesser extent. +X% LIGHT or colour has no effect on the enclosure.
Current:
E38 Parts Car
Previous:
