Old 09-15-2012, 02:22 AM
nsrahmed nsrahmed is offline
Mein Auto: E66 740 Li
Help needed for DIY on replacing head light lamp type D1S
Hi All,
I have 2006 E66 and its on e of the headlight is not working. BMW services guys are charging $500 for this but I did some research and found out its not a rocket science.
I manage to buy the replacement bulb at $27 and also manage to remove the lamp....
but
I am unable to remove the BLACK DISH fixed on the factory bulb.
Can any one help me or paste the video how to do it....
Very Much appreciated...
ID:	341934   Click image for larger version
ID:	341935   Click image for larger version
Old 09-16-2012, 01:58 PM
flash_n flash_n is offline
Mein Auto: 745Li
If I remember correctly, you had to turn the igition unit relative to the bulb to get it off.
Please check:
Assembly overview
On BMWfans.info you can browse to an overview of the headlight assembly. Unfortunately I can't insert a link, as it seems to be blocked (??)
Igniter Removal from TIS
http://tis.spaghetticoder.org/s/view.pl?1/07/57/00
Bulb removal from TIS
http://tis.spaghetticoder.org/s/view.pl?1/07/56/98
Good luck, flash_n
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer
next up:
headlight vertical aim, VCGs, P0492
Old 09-17-2012, 09:21 PM
Sorry pal but All I need to know is how to replace the ring fixed on the bulb
Please check:
Assembly overview
Good luck, flash_n
Old 11-05-2012, 10:40 PM
Adnan23 Adnan23 is offline
Mein Auto: 2006 750i
Originally Posted by nsrahmed View Post
Hi All,
but
On the black dish you should notice that there is a certain notch on it where you can un-hook it. Its very easy just look around it and it will un-hook so you can re-hook it to your new bulb.
Old 11-06-2012, 12:02 AM
tHANX
Thanks Adnan for your help. I wonder if you know how to change The Valve Stem Seals in same E66. Appreciate for your favorable response. Najam
Old 12-26-2012, 03:31 PM
theoutlander theoutlander is offline
The Outlander
Send a message via MSN to theoutlander
Mein Auto: 2003 BMW 745 LI
Did you have to take your bumper off for this or were you able to reach to the lights easily? I remember replacing the halos and those weren't too bad once you figured how to get to it.
