E34 (1989 - 1995)
Old 09-17-2012, 07:45 PM
Peter's 525I Peter's 525I is offline
Mein Auto: 95 e34 525i
Talking 1995 e34 525i fixer-upper... my project.
hello everyone.
i have recently bought a 1995 e34 525i that needs some love. yes Amalsinda needs Petes love.
this is my second 5 series. previously owned a 1987 535i 5speed. i miss her. drove her hard and fast and lost my license 1 or twice.
i replaced the thermostat and rad. thanks to the many wonderful forums in here. THANKS ALOT GUYS!! i've never done repairs on cars and this was by far the most complex work i have done on a car. soooo easy btw. even made the fan clucth tool! will post some pics soon.
i realized that my valve cover gasket is no good. found oil in the spark plug wells. NEXT JOB!! looking forwards to that as i really want to paint the cover. alsoo replacing fuel filter and pulling the starter to have it rebuilt. plus a couple of surprisesgoing to be working on her for 1 week slowly. now wheres my shopping list sheet.
Old 09-17-2012, 08:36 PM
Does anyone know where to get metal fan blades and metal fan shroud?
1995 e34 525i
M50 Auto K&N Sport Air Intake
THE TACK TACK TACK IS GOOOOOOOOONE!!!!!!!!!!! It's Like a new car!!!!!
Old 09-17-2012, 08:45 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Hi Pete . great project. i had great success using Bentleys repair manual. overhauling those items will prolong the cars life\ and improved drivable. I recently found you can solve gasket leaks by using a Small bead of High temp gasket sealer on the outer edges of gasket then let dry 1 day after instalation . I have even used High temp bearing grease rated for seawater. It has kept the new gaskets conditioned and mostly sealed.I think its the back leg lobes of gasket that can be problematic. The 14 I think rubber grommets to seal the bolts are a must have for a complete gasket change. Any one of them can become fatigued and leak.
ID:	342339   Click image for larger version
Old 09-17-2012, 09:01 PM
THANKS!
secretly im glad that i have to do this job because my valve cover exterior needs some maintenance too.
can you use it on the thermostat housing gaskets also?
i already have the bently's manual that also helped replace the rad and thermostat.
i like your valve cover and the fact u painted the bolts!
1995 e34 525i
Old 09-17-2012, 10:22 PM
luckydog's Avatar
Yes that s the idea to do as much to the area and parts as possible. Clean paint and replace gaskets and grommets. Thermostat gasket sealer is good with coolant leaks metal on metal. . For the valve cover gasket i would use regular engine gasket sealant sparely on at least upper top side on out 1/2 edge of gasket and out side of bolt pattern . painting the engine cover in the end, is like going on a date and your girls all prettied up
Old 09-17-2012, 10:46 PM
paperplane94 paperplane94 is offline
Mein Auto: 1989 525i M20B25
Why do you want a metal fan? You might kill someone...
Welcome.
Old 09-18-2012, 05:56 AM
Welcome.
u think so?
1995 e34 525i
Old 09-18-2012, 10:31 AM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
If you don't kill someone with the metal blades, you'll need a new hood if it ever comes apart on you. Go with OEM only on the fan blades. The aftermarket ones are of questionable quality and reliability.
Sent from my ADR6410LVW using Bimmer App
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 09-21-2012, 03:17 PM
changed the radiator coolant level sensor and fuel filter today. looked like its been a long while since that was last done.
Oil filter bracket sanded and 2 coats tremcladed rust paint.
going to take VANOS cover off tonight and sand and re-paint.
1995 e34 525i
Old 09-28-2012, 09:59 AM
took off vanos cover yesterday, had it sandblasted. brought her home and painted it this morning. now im waiting for the paint to dry 2 hrs. and in the oven for a couple of hours.
ID:	343588   Click image for larger version
ID:	343589   Click image for larger version
ID:	343590   Click image for larger version
1995 e34 525i
Old 09-28-2012, 05:12 PM
if your sexy and u know it!
done for today. going to finish her tomorrow. immediately after that's installed I'm going to get some red intake coupler hoses.
next i think I'm going to paint the oil filter cap and thermostat housing.
opinions please.
1995 e34 525i
Old 10-01-2012, 06:59 PM
Clean engine compartment!!
Color choice is a bit flashy though.
Old 10-02-2012, 12:22 AM
Tack tack TACK TACK TAcK TACK!!!!!
its goooooone!!!!! there used to be this tack sound coming from the engine. she kinda sounded like a diesel motor at times. it would tack low to high. it used to bother the beejesus out of me. ever since i did the valve cover gassket its gone!!!! im so happy. ive heard this noise comming from 1 other BMW a few months ago. i thought there was something wrong with my valves and it was 1 of the reasons i paid $500 for Amalsinda.
any one else experience this?
1995 e34 525i
Old 10-02-2012, 12:25 AM
nice fix!
Old 10-02-2012, 01:47 AM
Banned
Mein Auto: car
You do not need the clutch fan. Remove it and your ride will feel a little peppier and you'll have one less thing to worry about. Your auxiliary fan will suffice...it comes on at 2 speeds, low or high, depending on the temperature that is sensed via the sensor connected on the right of the rad.
You can test this out by driving for a few days with the fan restrained by a thin rope tied to one blade and the intake manifold.
Eventually, you'll need to change the resistor on your auxiliary fan as well, especially considering that you're using it for primary cooling. There is a newer, more modern solid-state resistor that is better than oem. Purchase that instead of the old spring-type version.
Old 10-02-2012, 02:53 AM
Thanks I love my BMW! she needs my care.
I'm debating whether or not I'm going to keep it like that. I have access to free nickle plating services need i say more? OK i will... I'm thinking Intake manifold (because i need to get to the starter), Vanos, Oil filter cap, and Thermostat housing are what I'm going to do first.
1995 e34 525i
Old 10-02-2012, 02:57 AM
well winter time is upon us here in Canada. we have two seasons up North, Winter and July/August. I'm probably going to remove the fan and leave it off when I remove the Thermostat housing to Nickle plate it. Heh heh heh. Come end of June I'll install a nice electric fan.
Thanks for the tip!!
1995 e34 525i
Old 10-22-2012, 04:43 AM
removing and rebuilding starter on Amalisinda today. any tips? will post pics later today.
1995 e34 525i
Old 10-22-2012, 07:25 AM
Banned
Mein Auto: car
Bad move, at least when it comes to the fan. More load on the engine, unnecessarily. I don't believe metal fans are sold, btw.
Why don't you remove your fan clutch and shroud entirely ?
http://www.bimmerfest.com/forums/sho...90#post7149990
And there's a long list of things you might like to consider doing, to bulletproof your aging E34. Please see :
http://www.bimmerfest.com/forums/sho...d.php?t=653050
cheers,
Roberto
Old 10-22-2012, 10:19 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Wow. where have i seen a red VC before....
#sincerestformofflattery #inb4
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
