Old 09-16-2012, 10:26 PM
joebruin joebruin is offline
Mein Auto: Mercedes
Condensation on OUTSIDE front windshield
Hi Guys, I just purchased a 2012 550i. I have noticed a lot of condensation on the front windshield, on the OUTSIDE, towards the bottom of the windshield. Any ideas??
Old 09-16-2012, 11:39 PM
schnell525 schnell525 is offline
Mein Auto: 12 550xi
check where you vents are positioned, especially center vents if they are set on "cold" (up is cold, blue box vs. red box). if you have a bunch of cold air at high blast aimed towards the windshield, you willl get condenseation and in the summer build on the exterior glass. place the vents to point inside the cabin. sync the temps to the same temp IMO, and use recirculate. blue ='s cold.
i live in a very fluctuative climate with dewpoints and humidity, and i haven't had a problem. good luck!
Auf Wiedersehen 12 550xi
Old 09-17-2012, 02:42 AM
Gran Turismo's Avatar
Gran Turismo Gran Turismo is offline
Alpina Addict
Mein Auto: '11 Alpina B5 Biturbo
Make sure the windscreen is not cooled down excessively by the AC (I dont' think it's a vent positioning thing, rather an air distribution setting issue to the defrost vents) or simply occasionally use the wipers.
Current: 2011 Alpina B5 Biturbo Saloon
Retired: 2007 650i SMG Coupe
"Really skilled drivers have smashed bugs on their side windows too" - Walter Röhrl
Old 09-17-2012, 08:25 AM
dunccfp dunccfp is offline
Mein Auto: F10
Simple. The air outside is warmer. You probably have the defrost vent turned on and the cold air cools the windshield and the air right around the windshield is cooler and cooler air holds less moisturer hence the condensation. Hit auto on your system and your problem will be alleviated.
Old 09-17-2012, 05:19 PM
markl53's Avatar
markl53 markl53 is online now
bimmerfest Supporting Member
Mein Auto: 2014 535i
I had an MB C-Class that did this all the time in hot, humid weather. The air distribution was set up to always deliver a very small amount of air through the upper defrost vents to help with overall cabin circulation. I've had my 535i for two years though, and have never noticed this, nor ever checked for air coming through the upper vents when in normal "hot weather" auto air distribution.
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Old 09-17-2012, 05:49 PM
mg650 mg650 is offline
Mein Auto: '13 550 XI, '11 M3cv
Maybe obvious but make sure your dash bents are open. If closed could be routing more air to the windshield.
Old 09-17-2012, 06:33 PM
Mein Auto: Mercedes
problem solved. I had the cold air coming out onto the windshield. No it is only coming out of the center vents and lower vents.
Old 09-19-2012, 08:38 PM
markl53's Avatar
Do you leave the air distribution in auto mode or do it yourself? Just curious if the auto mode was pushing air to the windshield.
BMW-CCA
Old 09-19-2012, 09:12 PM
Mein Auto: Mercedes
I do it manually, it is possible that in auto mode it was directing some cold air to the windshield
