Old 09-11-2012, 12:04 PM
stary stary is offline
Mein Auto: pending...
IPhone interface doesn't work
The car included an iPhone cable with both a USB and stereo iPhone adapter, which is supposed to be plug-and-play, allowing you to access the music on your phone via the stereo, but all i get is a "wrong cable" message displayed on the stereo. standard iPhone USB cable says the same thing (and dealer said that is supposed to work too. i tried with both the stereo jack and the USB jack, and neither work alone or together. the phone does get power from the USB jack though.
Anyone else having the same problem? i thought i remember reading something on this forum about that, but i can'y find anything on a search.
Old 09-11-2012, 01:40 PM
the_fox's Avatar
the_fox the_fox is offline
Custom User
Mein Auto: 428GC
Just curious, why do you need a cable at all? Shouldn't this work wirelessly through Bluetooth?
Do not fold, staple, or mutilate. Void where prohibited.
Old 09-11-2012, 08:14 PM
nope, maybe it does with the iDrive, but (even though that was also listed as "standard") we don't have it.
i plugged in a flash drive with some music on it and the stereo pulled it up just fine!
Old 09-11-2012, 08:40 PM
MNX1024 MNX1024 is offline
Mein Auto: Probably an X1
Now this is starting to scare me. I'm planning to go drop down the deposit this Friday at the dealership and all of this is kind of discouraging me.
Old 09-11-2012, 09:00 PM
kjboyd's Avatar
kjboyd kjboyd is online now
Drink the koolaid or else
Mein Auto: 2015 X1 sDrive XLine
What iPhone? And what software iOS? The cables are very temperamental.
Kevin
2015 X1 sDrive XLine - "Hamilton Maxwell"
2009 MINI Cooper Clubman - "Oxley"
2007 Volvo S60 2.5T
2007 X3.0si PlatBronze/Beige
2006 X3 3.0i, Flamenco Red/Beige
1997 528iA, Oxford/Tan
1994 318iS, Black/Gray
1979 528iA, RubyRed, Tan
1971 2002, Sahara, Saddle
Old 09-11-2012, 10:14 PM
iPhone 4S, OS 5.1.1
Using the supplied BMW "Video/audio adapter for Apple iPod/iPhone" cable SN 61-12-2-179-623
Old 09-11-2012, 10:15 PM
it's called the new model blues...
i'm sure this iPhone thing will be worked out shortly
Old 09-12-2012, 06:41 AM
mabrahams mabrahams is offline
Mein Auto: E30
The adapter is to control iPhone from wheel. You should be able to stream music via Bluetooth without the adapter.
http://www.bmwusa.com/Standard/Conte...a-51bfc4a0c532
(Yes this shows through iDrive, but it should still be the same function as non-iDrive models)
Also take a look at page 181 of the X1 drivers manual.
It was noted that if you have BMW Apps; the supplied cable doesn't work (but I'm not sure why the cable would be any different for BMW Apps?).
Old 09-12-2012, 10:24 AM
the_fox's Avatar
Custom User
Mein Auto: 428GC
They'll have to come up with a new cable/adapter for iPhone 5 folks as well...
Old 09-12-2012, 10:36 AM
Mein Auto: E30
The new iPhone will have a new adapter to old adapter dongle; shouldn't be a problem.
Old 09-12-2012, 02:27 PM
Justin@NCBMW Justin@NCBMW is offline
Past Sponsor
Mein Auto: MY13 X5 50i
Does your X1 have navigation? If yes use your own white "apple" cable
Old 09-12-2012, 05:35 PM
Thanks, I already read the manual and the phone syncs to make calls via Bluetooth but not music. There is nomusic choice on the non I Drive stereo
Old 09-12-2012, 05:37 PM
No IDrive so now nav.. thought IDrive was standard when I bought the car...tried regular iPhone cable and it doesn't work either
Old 09-12-2012, 06:51 PM
Mein Auto: E30
Ok... Did you try a shutdown of the phone and reboot it? Then remove both the USB and Headphone jack, plug it back in, connect the iPhone?
Old 09-12-2012, 07:29 PM
yeah, also, i deleted the phone from the sync with the car and then re-sync'ed it. it still says wrong cable. interesting tidbit is that the USB reading says "iPhone" when i attach the USB cable, instead of "USB"
Old 09-13-2012, 09:38 AM
Mein Auto: E30
I'd go back to the dealer and request a new cable.
Old 09-13-2012, 02:20 PM
talked with dealer and they don't know what's going on ... anyone else out there have the same problem?
Recap: cannot access music on iPhone through stereo via USB cable supplied by BMW
Old 09-13-2012, 03:31 PM
kjboyd's Avatar
Silly question... You DO HAVE music on the phone right?
Try this. Turn everything off. Not just sleep the phone but powered completely off. Then connect it all. Turn on phone. Wait for it to boot up. Does it show connect ON THE PHONE?, then turn on car. Then turn on radio and chose the mode button and go to iPod/phone.
Kevin
2007 Volvo S60 2.5T
Old 09-13-2012, 10:23 PM
yes there is music! i've tried playing it while connecting.
I tried your idea with iPhone restart and no dice. tried it with the BMW cable (usb, stereo jack alone, plus stereo and USB together), and the standard iPhone cable.
anyone else having this problem??? i guess we're the only ones on this forum with a non-iDrive X1 trying to sync music so far!
Old 09-14-2012, 03:23 AM
x3brian x3brian is offline
Mein Auto: X3
You might need a different cable.
I had a similar problem with my non I drive e88 (which audio is essentially the same as your e84) when I converted to the 4s although my issue was charging related.
I needed this:
http://www.shopbmwusa.com/ProductDet...ProductId=3241
Worth a try to ask the dealer.
Old 09-18-2012, 10:52 AM
dealer sent a new cable he tested on another car in the lot... if that doesn't work then it's our phone or the car
Old 09-21-2012, 11:43 AM
Got the new USB cable from the dealer and the interface works now!
2013 X1 sDrive 28i, M-Sport package, Mineral Grey
Old 04-18-2013, 03:22 PM
Scolty Scolty is offline
Mein Auto: NL
Heey got the same problem.
Wich cable do you got now?
Greetz
Old 04-18-2013, 04:22 PM
eric9610 eric9610 is offline
Mein Auto: '15 GLK350
I have idrive and Nav along with my Iphon 5, i can stream the music over Bluetooth or use my white cable to connect my phone to BMW APPS.
