Do-It-Yourself H.Q.
Old 08-22-2012, 02:09 AM
Danny Miro Danny Miro is offline
Mein Auto: 1993 BMW 325i
Boging down
My 1993 325i has started to bog down when I turn on the A/C. Sometimes it will run fine and other times bog. I have noticed it has been turning over slow when starting. I had the charging system and battery checked out and was told everything is fine. Do you think a bad connection in the battery cable would case this? I had the same problem happen last night without the A/C on.
Thanks you your help.
Old 09-22-2012, 04:22 AM
BMWFatherFigure's Avatar
Old School
Bogging sounds like the idle speed control is not responding to 'idle up'. Remove it and clean with carby cleaner. Check it for electrical problems. Slow starter - try inspecting every battery cable, joint and earth and remake any joint that is even slightly suspect. Dont forget engine to chassis earth.
Current:
E38 Parts Car
Previous:
