x5 e70 replaced brakes problem 2 reset - Bimmerfest - BMW Forums
Old 09-21-2012, 11:51 AM
stijndidden stijndidden is offline
Mein Auto: x5 e70
Question x5 e70 replaced brakes problem 2 reset
so i replaced the brakes and the warring light was still on the display so i replaced the sonde
ant the problem was not gone i try 2 reset with launch x431 diagun and it says no problems and i trait 2 go in the maintenance system selected brakes replaced ant it says check if you have 12v and have you riley replaced the brakes ? so i try another 10 times with the same effect so if you got anny tips let me no already thanks
Old 09-22-2012, 06:14 PM
1naztyx5 1naztyx5 is offline
Account Under Review
Mein Auto: E70 X5/E60 528i
Not sure what "sonde" is but. Did you replace the sensor ? If you did...
-put key in ignition )without starting car) as if you would open the "switch"
-press the trip reset button until you get the maintenance menus
-then press until you get to brakes
-press and HOLD until asked to "reset "
And your done...check YouTube dunno know if I am missing something but is the same process for the E60
