The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition. |
Will I need any special gear with this PC random orbital model?
Hello guys and gals.
I've been doing some research on how to properly care for my new-to-me space gray 328 coupe and I have decided that I need a nice PC random orbital. Recently I was looking to spend some rewards points and I found this exact model: http://www.portercable.com/products/...roductID=21428 My question is, since this is technically a sander, do I need anything to make this work as a polisher? Will this even work like the 7424 (or other commonly recommended models), or will the model in question operate in a different manner? I searched through this forum and a couple others and couldn't find anything on this exact model, or anything definitive regarding random orbital sanders. Any help is greatly appreciated! |
found this on garagejournal
http://www.garagejournal.com/forum/s...d.php?t=127918 take fwiw - don't know how credible this source is, but it appears to make sense If it doesn't come with a backing plate you'll need one, and you'll need pads. Check out detailersdomain.
2005 ///M3 Estoril Blue/Gray SMG 2012 740i Black Sapphire/Black Dakota M-Sport 2010 328i Titanium Silver/Black Dakota Sport (+1999 911 Carrera Cab, 1967 Morgan +4 SS, 2008 Nissan Armada) |
Thanks for the response, aray.
Yeah, it does make sense...I'm just concerned that this sander/polisher would have a slightly different motion to it. Kind of like those power sanders that vibrate as well as have a random orbit. So instead of a sanding backing plate, I would need a separate/different backing plate for the polishing pad? Not sure if I follow that part. |
The pad rotation of a duel-action is driven by its orbital speed. The faster the machine orbits, the more centrifugal force is applied to the backing plate, which results in its random elliptical centripetal orbit (OPM). A pad with a large contact area absorbs the orbital action due to its high surface resistance. Call Phil at Detailers Domain and ask him about the Uber foam pads and backing plate, he is very knowledable and extremly hepful
~ Providing unbiased opinions that Professionals and Enthusiasts Use and Trust ~ Blog-http://togwt1980.blogspot.com
Ok, so the only difference then is the backing plate. Thanks TOGWT.
I'll get in touch with Phil too. Thank again! |
Here's a kit that has everything you may need for the Porter Cable. You can buy the the backing plate, pads, etc. separately. The link has a good write up on the Porter Cable too.
