E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Hello bmw friends, im new to the forum and a new bmw owner. I need help in replacement of my engine fan. Im wondering is there a link with detailed instructions or could someone give me some instruction. thank you in advance.
Welcome to the fest!
Here is a detailed DIY article on cooling system work, including removing the fan. http://www.pelicanparts.com/BMW/tech...eplacement.htm Tell me, why are you replacing the fan? Did the car overheat? We STRONGLY suggest a complete cooling system overhaul/replacement every 70k-90k miles. If the car overheated, you may have far worse troubles than just a fan replacement.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
engine fan e36
no it hasent overheated, while i was driving i heard a thunk type of noise. I popped the hood and noticed the fan had pulled the fan shroud back towards the motor and was stuck under the shroud and the upper radiator hose. Im not sure how this happened I just assumed the shroud came loose. I secured the shroud and now need to replace the fan due to it broke off 1 blade. my car has 165,000 on it. i dont know what has been done to it because it was purchased second hand. is there something i should be weery of?
e36 engine fan
Thanks for the pelican parts link, that is very informative and helpful.
You're welcome! That link has a parts list for the cooling system overhaul.
