Old 09-14-2012, 05:09 PM
beemer1804's Avatar
beemer1804 beemer1804 is offline
WAR MACHINE
Send a message via AIM to beemer1804 Send a message via Yahoo to beemer1804
Mein Auto: 95 740IL
Rough idle
My 95 E38 idles rough when under 1500rpm, do anybody know why its like that? Any answers or suggestions are welcomed bmw bretheran.
War Machine
Old 09-23-2012, 03:14 PM
BMWFatherFigure's Avatar
Old School
Looooooooong list. Vacuum leaks, fuel pressure, TPS, Air Mass device, Fuel filter, Spark plug(s), Coil Packs; CPS; Throttle Body settings; VANOS problems; What Codes are being displayed/stored?; Blocked exhaust; Blocked Air Filter; Fuel pump; Loose wires on the EMC loom - That should do as a start
Current:
E38 Parts Car
Previous:
Old 09-23-2012, 03:23 PM
beemer1804's Avatar
WAR MACHINE
Mein Auto: 95 740IL
Only codes displayed were o2 sensor then a few weeks later it said lambda, i checked for air leaks and nothing, i always knew that my fuel filter was bad, i was actualy gonna change that already, and of course my o2's. Hopefully something changes.
War Machine
Old 09-23-2012, 03:30 PM
beemer1804's Avatar
WAR MACHINE
Mein Auto: 95 740IL
How do i check the vanos? And can my fuel filter cause war machine to shake, im guessing it effects my fuel pressure?
War Machine
Old 09-27-2012, 05:55 AM
Originally Posted by BMWFatherFigure View Post
Looooooooong list
Believe it or not, over a period of a few years, I tried to compile the COMPLETE list of what SOLVED rough idle misfires over here in the E39 bestlinks (all of which should apply equally well to the E38):
- How to diagnose a BMW E39 engine misfire (1)
Old 09-27-2012, 05:58 AM
BTW, this tool (or an equivalent) is indispensable for troubleshooting rough idle misfires:
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
Old 09-27-2012, 07:50 AM
beemer1804's Avatar
WAR MACHINE
Mein Auto: 95 740IL
I thought 95 740il doesnt have vanos?
War Machine
