BMW 750 lowering kit - Bimmerfest - BMW Forums
Old 09-23-2012, 03:21 PM
parasbajaj parasbajaj is offline
Paras Bajaj
Mein Auto: 2011 Bmw 750 Lix
Hey guys,
I have a 2011 bmw 750 lix.
I just put on 22" rennen r8 deep concave wheels.
I wanted to lower the car a bit to make it look neat.
Any suggestions without any warning lights on the dashboard?
Paras
Old 09-23-2012, 05:39 PM
Wolfman64 Wolfman64 is offline
Mein Auto: 750li, S550, SL550, ML350
Originally Posted by parasbajaj View Post
Hey guys,
Paras
I had the H&R Sport springs installed (front springs & rear links) and it makes a world of difference.
The xDrive for whatever reason sits much taller than the standard 750. Worse yet, the front sits higher than the rear with a larger gap, making it look like it's ready for liftoff
The H&R springs make the car like it should have looked from the get-go and drives like before. No impact to the electronics...
Now I am ready for 21" wheels
Wolfman
Old 09-23-2012, 06:46 PM
Paras Bajaj
Wolfman
does the kit interfere with the MMI system? How much did it cost you?
Old 09-23-2012, 09:29 PM
The kit doesn't interfere with anything. Simple, but more costly than lowering links since replacing springs appears to be more time consuming.
Paid around $330 for the kit, around $350 for the installation and $125 for a wheel alignment/camber adjustment, so around $800.
Definitely a must for an xdrive.
Old 09-23-2012, 09:56 PM
Paras Bajaj
hows the ride?
Old 09-23-2012, 10:18 PM
hows the ride?
More or less the same...
Old 10-05-2012, 03:44 PM
blue22flames00 blue22flames00 is offline
Mein Auto: 07 750LI
pix of the wheels?
750, air, bmw, lowering kit
