Z3 Z3 1996 Won't Start - Bimmerfest - BMW Forums
Old 09-20-2012, 05:55 AM
dr_rafiki dr_rafiki is offline
Mein Auto: Z3 1996
Question Z3 1996 Won't Start
The car ran fine and then it wouldn't start.
When I put in the key all the electrical comes on, but the starter won't engage (no sound at all) and the windows won't work; they are forever down. The key in the door will unlock one side, but not both at the same time.
I have ordered another key, but there are no buttons on the keys for this car.
The battery is fully charged.
The fuses all look good.
Any ideas?
Thanks.
Old 09-20-2012, 06:58 AM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: Z3 2.3iA/5MT 528iA VW GTI
Bad ignition switch?
1999 528iA
2000 Z3 2.3
2003 M5
Old 09-20-2012, 07:29 AM
FZbar FZbar is offline
Mein Auto: 2002 Z3 2.5 Roadster
Bad starter motor.
You might be able to jumper the battery to the starter motor directly just to momentarily test whether it's the starter switch or motor. Be careful though.
Fred
Old 09-20-2012, 09:39 AM
Mein Auto: Z3 1996
Question Windows
Why would the starter motor affect the windows?
Old 09-20-2012, 09:46 AM
wifesauto wifesauto is offline
Mein Auto: sloporsche
yo doc.....we need more [much more] [medical] history before a good diagnostic remedy can be recomended. how old is the batt ? how do you know its fully charged ? was it tested ? was it removed from the car ? with a good DVOM check and report voltage please
Old 09-22-2012, 05:59 AM
Mein Auto: Z3 1996
Battery
The battery is virtually new. It tested fine, and it has been fully charged. There is no doubt it is not the battery.
Old 09-23-2012, 11:05 AM
IgotBMW's Avatar
IgotBMW IgotBMW is offline
BE IRIE
Mein Auto: 98 540i, 03 X5
Is your alarm on by any chance?
Old 09-23-2012, 05:33 PM
Mein Auto: Z3 1996
I do not believe that it is. I am not even sure where it is. It has never been set off. The dealer said that if it has an alarm, it is an after market alarm. There are no buttons on the key, but there is a key fob with "unlock/disarm" and "lock/arm." These buttons do not appear to do anything except flash a little red LED on the fob.
Old 09-23-2012, 06:26 PM
IgotBMW's Avatar
BE IRIE
The only reason I asked was it has happened to me where I somehow get in my car with alarm on and when I turn the key nothing happens. After I press on disarm on the alarm fob, then everything is back to normal. So it was the alarm (oem) that was preventing the car from starting.
Other thing to check is to see if your ignition switch is actually engaging to provide power to the starter solenoid.
Old 05-17-2014, 06:02 PM
lombrado lombrado is offline
Mein Auto: 1996 bmw z3
My Z won't start either --- Help!!!!
Did you ever get this z3 won't start with the windows and the door lock issue resolved???? I have the exact same problem with the exact same car. Would appreciate your thoughts. Can you call me at cell 218 348 8718, home 218 720 3411. Or email me at dlombardi@clearwire.net. I am in Sunny Duluth, MN where convertible season is short.
Dick
Old 05-18-2014, 07:42 AM
Bob2.8 Bob2.8 is offline
Mein Auto: 1997 2.8
I'm guessing you are just getting out of storage? When did it last run? How is the battery? How are the battery connections? Any chance of mice while stored? I finally got mine out Friday.
Old 05-18-2014, 12:05 PM
Mein Auto: Z3 1996
I'm sorry to leave everybody hanging for so long. I fixed it and forgot about it. Here was the correct diagnosis: Power window relay was bad. Go figure.
The whole thing was very strange. I don't remember all the exact details. I did get another key and it had no effect at all. As far as I can tell there is no security system on the car. There was nothing wrong with the battery or the starter. I had previously replace one of the window switches, I think it was the passenger switch. I did some work on the driver door panel, and I'm pretty sure that triggered the whole episode by shorting out the window circuit.
At any rate, the whole thing disappeared when the relay was replaced. Strange symptoms, I think.
electrical, help advice needed, won't start
