Old 09-21-2012, 11:52 PM
Originally Posted by z_driver View Post
that doc's for three years, April 2008- April of 2011.
I couldn't find anything newer.
I suspect that's for rebranding.
I never understood brake pad rebranding.Seems to me the friction code should prevent us from being confused by the extensive use of brake Marketing rebranding but even AMEC is in cohoots with the brake marketeers.
For example, this document says the following about rebranding tests:
- AMEC Manufacturers Guide
"If the material is produced for other companies ... this information is considered to be proprietary and will not be released"
Be interesting to see what the Akebonos have imprinted 'under' their cover.
Indeed!
Maybe the law applies to pads only?
I hope not. But, we'd have to see some more shoes to be sure.
EDIT: This textbook on brake friction coefficients implies the edge code should be printed on the shoes:
- Brake Friction Theory textbook (pdf)
Brake pads and shoes have markings on the edges that give the approximate coefficient of friction at low and high temperatures.
Notice that this textbook says that you want the SAME cold & hot coefficients, which would imply that EF is not as good as EE or FF.
ID:	342833   Click image for larger version
Last edited by bluebee; 09-22-2012 at 12:12 AM. Reason: Added textbook on brake friction theory
Old 09-23-2012, 06:32 PM
z_driver z_driver is offline
Mein Auto: 528i
Jurid shoes
Well, here is a picture of the Jurid pads I replaced with Centic's. In general appearance the Jurids seem to be of higher quality and they have friction code markings that seem to correlate with pad regulations. HG in this case. Again, the Centric's had only a part code and date.
All stock '97 528iA -phone.
Old 09-23-2012, 07:00 PM
Christop55her Christop55her is offline
Banned
Mein Auto: VW
I'm surprised I did not find your Bosch edge code markings
Old 09-23-2012, 08:14 PM
Mein Auto: 528i
Yeah, not sure what to make of that other than that particular PDF doesn't appear to be the latest version.
My rudimentary attempt to decipher the code yeilds: (B)osch(N)orth(A)merica(Q)uietcast(1213)some proprietary formula(FF)OE equivalent friction rating.
Old 09-23-2012, 09:56 PM
HG in this case
Good! The document above indicated that both pads and shoes should have the edge code.
BTW, "H" is by far the highest friction grade we've seen yet!
Sorry about not finding a later PDF that might have Bosch covered.
Old 11-27-2012, 12:40 PM
It's nice to know this thread helped someone today on the E46 forum:
> E46 (1999 - 2006) > Brake pads need changing ...which ones to buy???
Old 11-27-2012, 02:43 PM
seemyad's Avatar
seemyad seemyad is offline
BMW ****ie
Mein Auto: 530i Sport Package
I just installed HAWK Performance Ceramic Pads.
Grade = FF
Reading suggests normal street driving doesn't rise to the occasion for FF. I think FF is the lowest track grade for racing cars. They should last a long time on street cars. I imagine track cars' brakes get much hotter than street driving. Hence the need for pads that retain their friction at higher temps.
Old 02-23-2013, 03:01 PM
Jurid Shoes: Well, here is a picture of the Jurid pads I replaced with Centic's. In general appearance the Jurids seem to be of higher quality and they have friction code markings that seem to correlate with pad regulations. HG in this case. Again, the Centric's had only a part code and date.
For the record, this was posted today:
Originally Posted by waehrik View Post
I just bought a set of Wagner Quickstop Z831 shoes for $20.46
Old 03-11-2013, 03:55 AM
Does the friction rating tell us anything about fading?
This was posted today:
Originally Posted by senser View Post
Akebono's FADE like crazy for me under hard driving.
Looking up the friction ratings, the recommended Akebonos have the highest shown (GG).
But does that tell us anything about fade?
Old 03-11-2013, 02:51 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Check the notes at the bottom of this document.
I've put about 70,000 miles on a set of Akebonos, and I have never noticed brake fade. My 530i has the same brakes as the 540i That said, the 530i is somewhat lighter than the 540i and I don't drive that hard.
Steve
OSRAM CBI
BMWCCA Member #337964
Old 03-11-2013, 03:49 PM
OK. So, the friction code 'is' also a fade code, of sorts:
The top clearly says:
This two letter edge code mandated by the DOT, and painted on all street legal brake pads, will give you some indication of their ability to resist fade. But only if you know how to read them. However, because of the wide range involved in each letter, it is only a rough indication.
The bottom says:
The second letter of the code represents the hot friction coefficient based on a fade and recovery test. We all should know what brake fade is. If you've ever had to use the front brake extensively and found that its effectiveness quickly diminished, that's fade. Recovery is basically the period where the brakes are gradually cooling off.
Lastly, it says a GG fades very rarely in the charts.
So, like many people, I suspect the poster is mistaken about the GG pads fading on him.
ID:	368537   Click image for larger version
Old 03-29-2014, 02:49 PM
While the friction grades are not (by any means) perfect, my thoughts on reviews of brake pad braking characteristics is summarized by this post today, which requested that anyone who installs brake pads on their E39, please post a picture of the friction ratings for this thread, so that we all benefit.
- Yet Another Brake Thread - Performance Edition
I do realize everyone's personality is quite different, and that mine is probably way off the charts for this forum audience ..... so, please take this only from me, a well-educated but Aspergers individual, who only believes in reproducible scientific truth, as much as it may exist.
I sometimes skim Tire Rack and other user reviews, but, almost always, I either laugh or cry at the sheer and utter garbage that is spewed out by the "boy racers" who write them.
Bearing in mind that almost everyone thinks they're better drivers than average (which is statistically impossible), the reviews seem to be written mostly by little boys who feel that they can, somehow, without any instruments or measurements whatsoever, write anything useful about the "bite" of a pad that they currently have on their vehicle.
Notwithstanding the clear fact that most of those boy racers don't even have the basic vocabulary to properly describe the brake bite, they still can't possibly tell me anything that the friction ratings don't already tell me, with respect to cold and hot friction (which is what a brake pad is all about).
Me?
I would simply go by the well-tested and reproducible friction ratings of the pads when it comes to braking forces. (I would also simply buy plain solid rotors since the friction coefficients are essentially the same for all carbon steel rotors.)
- What's the real difference between drilled, slotted, and solid rotors (1) & what's the difference between various brands of solid rotors (1)
What I would ask YOU to do though, since you've already ordered your pads, is to post a picture of the FRICTION RATINGS of the pads you do finally get, before you install them.
Then post that picture to this thread, so the rest of us benefit from your efforts.
- What friction grade (e.g., EE, FF, EF, etc.) is recommended for BMW E39 brake pads (1)
Old 04-10-2014, 10:53 AM
aioros aioros is offline
aioros
Mein Auto: 99 528i auto m-sport susp
napa ultra premium brake pads
napa ceramic brake pads are made by akebono. most of their pads are rated FF
Old 04-22-2014, 09:02 PM
Here's further confirmation of the GG friction ratings of the Akebono Euro:
> E39 (1997 - 2003) > Brake Parts Arrived Today
Originally Posted by helmet75 View Post
2- Akebono Euro Ceramic- GG rated ( I thought they were FF, but printed on the pad is GG). I'll take it although I'll probably never get them that hot.
Old 04-22-2014, 10:28 PM
For the record, the StopTech friction ratings are described here:
> E39 (1997 - 2003) > Yet Another Brake Thread - Performance Edition
Originally Posted by München View Post
So the StopTech Street Performance pad have arrived and I can confirm they are indeed FF. For you Bluebee.
Old 05-26-2014, 07:55 PM
Someone who just replaced E39 brake pads posted the first ever on Bimmerfest picture of FE pads over in this thread today:
> E39 (1997 - 2003) > Rebate on Bosch Brake Pads
Originally Posted by rexgo View Post
FYI - Purchased new pads from Autohaus - Bosch QuietCast™ and rec'd a $15 rebate per pair - so after rebates it's front & rear pads for ~$38 total
BTW - very easy replacement - easier than most cars I've done - thanks for the forum's help. (I already had a 7MM)
Maybe someone, who knows more than i do, can
explain what the implications of the FE friction rating will be as compared to the FF of the OEM pads.
Old 08-10-2014, 07:08 PM
This thread today shows a set of rear Pagid Reds, from Bavarian Autosport, so we asked the OP to snap a picture of the friction rating stamp...
> E39 (1997 - 2003) > Removing the Rear Brake Caliper Guide bolt
Old 01-07-2015, 10:16 AM
As a matter of habit, whenever someone recommends a brake pad for the E39, I feel we should at least know whether the pads meets minimum friction specifications.
To that end, the EBC pad friction ratings were fleshed out today ...
> E39 (1997 - 2003) > Brake rotors & pads
Originally Posted by mrblahh View Post
greenstuff are cf .41-.45 this is the high end of FF and low end of GG
yellowstuff are .46-.49 that's in GG range
bluestuff are over .55 that's HH range
ebcwebsite has the specs
Old 01-21-2015, 05:32 PM
Absolutely horrid friction grades were posted today for Wagner pads ...
> E39 (1997 - 2003) > What rotors are recommended for street use on the E39 (thread for newbies)
Originally Posted by speedchase View Post
Wagner pads friction grades are EE for front and FF for rear.
Old 02-03-2015, 05:15 PM
Here's an update just in today, on that prior post ...
For the record, stay away from Wagner pads for any decent car of yours. I was ignorant when I ordered the Wagner pads from Amazon for my E39 and it is outrageous that as bluebee pointed out the pad friction grade is EE for the front and FF for the rear. I did verify it is FF for the rear but don't have the pictures.
I am sending them back to Amazon.
Rear - http://amzn.com/B001KSCZ5Y
Front - http://amzn.com/B000C8YYAW
Old 03-01-2015, 11:09 AM
This thread today gives us the friction ratings of the Cool Carbon pads from BavAuto:
> E39 (1997 - 2003) > pagid, bosch , jurid or akebono ?
Originally Posted by TurnzSr View Post
I replaced the pads all the way around with Cool Carbon from BavAuto. They had about 45,000 miles on them last summer when I replaced the struts and looked to be only half worn. They are a combination ceramic compound and brass mixture. Current price for front and rear is $240 - not cheap but provides great stopping power and life.
Cold/Hot for the Cool Carbon pads is F/G according to the service tech at their website
Old 04-26-2015, 12:17 PM
One user sold another these Powerstop Z23 (Z23692A) pads for a 549i today, which apparently have a friction rating of FF...
> E39 (1997 - 2003) > Yet another brake pad question for a 540
Originally Posted by Zerodynamic View Post
...For the record, the pads I'm referencing are rated as "FF," however I misspoke (or typed) as the brand I'm getting is PowerStop, not centric from a bimmerforums member that gets a sweet discount. However, I used the centric cheap pads to hold me over until I decided what route I wanted to take.
http://www.rockauto.com/catalog/more...id=462&jpid=62
When you blow up the picture, you can see they are FF.
And if anyone is interested, here is the link for the hook up on bimmerforums:
http://www.bimmerforums.com/forum/sh...-Brakes-anyone
He quoted me 286 shipped for all 4 drilled/slotted rotors, pads, and brake sensors, for the 540. Sweet deal! Looking at that thread, everyone has been happy with them.
Old 04-26-2015, 12:32 PM
In consert to what our friend Edjack said, I'll clarify that *all* the religious subjects are ones where M-A-R-K-E-T-I-N-G is involved, attempting desperately (and, I must say, almost always successfully) to have you place a greater value on (what turns out to be) a meaningless "difference" between their pad and the other guys' pads.
Note that the MARKETING folks may be actually telling a lie in this case...
Old 05-24-2015, 03:43 PM
Over here today, we're going through reams of Hawk Marketing bs, and we still don't know, after days of looking and reading, what the friction rating of the Hawk PC pads are.
> E39 (1997 - 2003) > The ultimate dustless brake combo
Old 05-24-2015, 04:01 PM
It's appalling how successful Hawk MARKETING is in hiding their friction ratings from the public. They publish gorgeous document after document of almost total useless bs that sounds technical for anyone simple minded enough to be thoroughly fooled, but the good news is that, in my search for the friction rating of the Hawk PC pads, I found this nice magazine article on friction ratings:
brake dust, brake job diy, brake pads, friction grade
