E30 (1982 - 1993)
Old 09-20-2012, 04:34 AM
marineman2 marineman2 is offline
Mein Auto: 85 325e
325E hesitation on acceleration
Alright, so in my 85 325E, whenever I accelerate from a stop on a hot day, there is a long hesitation, and a big dip in the RPMs. And, my car will occasionally stall if I only put on the throttle for a short time from a standstill. The stalling however only happens when I am driving my car in the first 5 minutes after just starting it after it being off for only a few minutes. I'm not sure whether this might be dirty injectors, a fuel pressure/pump issue, a vacuum leak, or something else. Anyone had this problem before, or have any advice?
Old 09-20-2012, 04:56 AM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
Sounds like its not getting enough fuel try fuel filter
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 09-20-2012, 06:10 AM
Cletonius Cletonius is offline
Mein Auto: 1990 325is
Try testing and adjusting your TPS. I had similar hesitation issues and it ended up being the TPS
Old 09-20-2012, 05:08 PM
BMWFatherFigure's Avatar
Old School
and for good measure an injector clean. Vacuum leak would happen all the time.
Current:
E38 Parts Car
Previous:
Old 09-21-2012, 02:17 AM
Mein Auto: 85 325e
Alright. I'm gonna replace the fuel filter, but how do I check the TPS? And as far as cleaning the injectors, should I try seafoam or techron? Or something else?
Old 09-21-2012, 08:39 AM
alpinewhiteE30 alpinewhiteE30 is offline
Mein Auto: 1987 BMW 325e
Pop out yur injectors a clean the up a bit.. If tgere the original ones . U should get them replaced..
Sent from my SGH-T499 using Bimmer App
Old 09-21-2012, 07:39 PM
downhiller's Avatar
livin large
welcome to vapor lock. things i did to help stop it, wrap the fuel line and fuel filter with a heat wrap. also i did notice it happened alot to me when my intank pump was going bad. after i replaced the intank and wrapped the lines, it basically disappeared.
some other things you can do, do the electric fan conversion and set the fan thermostat to a lower temperature, put in a lower temp t.stat, and after doing a cooling system flush, use a 60-40 mix of water to coolant and add in either royal purples purple ice or redlines wetter water. youll want to use 3 bottles of either. thatll help keep engine temps down as well.
Old 09-21-2012, 09:29 PM
Old School
Injector clean: Whip them out and take them to a shop with a cleaning and flow testing rig. TPS: Normally set with a feeler gauge to register the datum point of 'just off tick over'. You need a DVM or similar to set it as it invilved the 'make and break' of a switch..
Current:
E38 Parts Car
Previous:
Old 09-23-2012, 09:09 PM
Mein Auto: 85 325e
How difficult is it to replace the in tank pump and the fuel filter?
Old 09-23-2012, 09:23 PM
Should be under an hour, fuel filter is in front of the left rear wheel.
http://eurowerks.org/showthread.php?t=28964&page=1
Old 09-24-2012, 04:35 PM
downhiller's Avatar
livin large
the intank isnt bad. pop off the rear seat cushion, remove the cover and theres the top of it. 3 lines a couple wires, twist and remove. now there is options for the intank pump. i did a write up on replacing it with a chevy vega pump to keep prices easy on the pocket.
fuel filter is easy, you may want to lift the drivers rear up a bit to get some room to slide under.
hesitation, stalling
