Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > F22 / F23 2 Series (2014 - Current)
The 2 Series coupe is the replacement for the E82/E88 1 series coupe. Production starts in November 2013 on the 228i (N20) and M235i (N55) coupes. Look for them in dealerships in February 2014. The convertible F23 2 series will follow in the fall of 2014.
Old 09-25-2012, 09:05 AM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Specifications of the BMW 1 Series M135i xDrive
BMW M135i xDrive specs
BMW has released the specs on the BMW M Performance Auto version of the 1 F20 Series, the M 135i xDrive. M Performance Autos are a blend of M car and non-M that is half way between a 135i and the 1M. It is hard to get too excited about the specs as it isn't likely we will see this car in the US, but a M Performance Auto variant of the 2 series coupe that is coming state side in the next year or so is likely.
If we do get a M 235i xDrive it will share similar engine and suspension details so that is worth getting a little excited about. A 320hp xDrive 2 series coupe would be a screamer!
BMW M135i xDrive M Performance Automobiles
Highlights from the M135i xDrive Spec Sheet
Engine Technology - M TwinPower Turbo technology with Twin Scroll turbocharger, direct injection system High Precision Injection, fully variable valve control (VALVETRONIC) and double VANOS variable camshaft timing
Engine Capacity - 2979 CC
Horsepower - 320 horsepower at 5800 RPMs
Torque - 331 pound feet of torque at a tire twisting low 1300 RPMs
Front Suspension - Double-joint aluminum control arms with M-specific geometry
Rear Suspension - Light steel five link with double elastic bearings
Front Brakes - Four piston aluminum floating calipers riding on vented disk brakes.
Rear Brakes - Two piston aluminum floating calipers on vented disk brakes.
Steering - BMW Electronic Power Steering (EPS) with variable sport
Does any other M135i xDrive specification pop out to you? Would you buy an M135i xDrive if they came to the US?
ID:	343245   Click image for larger version
File Type: pdf Specifications_BMW_1_Series_5door_M135i_xDrive_11_2012.pdf (117.7 KB, 193 views)
File Type: pdf Specifications_BMW_1_Series_3door_M135i_xDrive_11_2012.pdf (117.7 KB, 280 views)
bmw, bmw news, m performance automobiles, m135i xdrive, xdrive
