7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
Sunroof Leak
Hey guys My passanger side (UK Spec so passanger on left side) sunroof waqs leaking and now my passanger seat dont move back just front.
![]() I dont know if its the drains thats clogged or if the seal is gone, as only the left side leaked and now my whole passanger floor is soaking wet. Can someone help on as to what it can be i.e seat module? also is my sunroof seal gone or the drain clogged? Thanks in advance guys
Have just read many threads on regarding this and im guessing my Sunroof seal is probably most likely gone as the whole top left headliner is wet and have inspected the left piller which is soaking wet. the drivers side is fine its just the passanger left front side that is wet and as mentioned now my seat does not go back only goes forward.
Goign to get my mechanic to check the drainage on the left side but am sure the drain is not clogged as the sunrrof was closed due to heavy rainfall but for that much water to get in the seal must be bad. Also guys which part is the seal is it number 7 or 8?? http://realoem.com/bmw/showparts.do?...08&hg=54&fg=05
im having the same problem but it was my driver seat that stop working,because i left the sun roof lid open and the water got on the seat.after two months the seats started working fine.the sun roof still link but now that i keep the lid close it drips down the side panles ontop the floor
Mine is leaking through the A Pillar and onto my passenger floor. the reason being my Left (Passenger seat) stopped working is because when id rove off fro stand still last night a huge amount of water fell onto the passenger seat hence I'm guessing the water must of destroyed the Seat Module which is directly underneath the seat. Anyways I have dropped my car off to my mechanic who said he unblock the Drainage of the sunroof and check all drainage system and also i will get him to change the sunroof/moonroof seal.
Got an update from my mechanic and his checked all drainage system and has found the two left side sunroof drainage to be blocked.
He will strip everything down to double make sure all connections are fine, he also said he will pressure clean it as well as clean it with wires and while doing it with wires making sure no connectors come loose. Sent from my GT-I9300 using Bimmer App
Did he just remove the A panel or the headliner had to come off as well?
'11 328i '03 745Li '03 Acura TL-S '02 Infiniti QX4 |
But will find out tomorrow and get back to you. Sent from my GT-I9300 using Bimmer App
Appreciate it..
Just came back from the garage, he took the A Pillar off as well as the headliner (just the front left side) so he can see the drainage pipes
Ok cool. Thank you for the follow-up
No worries.
Im going to go pick up the seal tomorrow. Going to do the seal as soon as i get it tomorrow (just in case) ![]() Sent from my GT-I9300 using Bimmer App
Lol funniest thing is i never hear a Honda, Lexus or Nissan owner complaining about water leaking in....
We pay all this much for a car like this and the wound keeps getting bigger and bigger lol Sent from my GT-I9300 using Bimmer App
That's true. Although I did have a Acura Integra tht had a bad leak in the trunk. I called it my aquarium. But with a flagship car one would expect better. Nevertheless, I love my beast.
![]() All is forgotten once i take her for a ride lmao Sent from my GT-I9300 using Bimmer App
Ain't that the truth! Lol
