Old 09-21-2012, 03:53 PM
Newbie528 Newbie528 is offline
Send a message via Yahoo to Newbie528
Mein Auto: Corvette
.....I'm dead. Car died Nee Help...big time, Plzzz Help....
I had just written a thread a couple of weeks ago, about my car reaching 160k miles, and I was beginning to worry of the upcoming issues...specially tranny.
Well, it happened today. I stopped at a store, car wouldn't start. Gas was totally out, so I bought a can & poured 5 gallons of gas. Still won't start, but a little clicking noise. I thought battery is down. Got a jump and out started. But was getting brake light, traction light, ABS light flashing. I didn't stop but kept driving. In a little while I get a mssg "Trans failure"..."PROG...safe mode"... Car would not pull...very slow. In a few minutes totally died. Wouldn't start at all. Not even idle... Wth...
Does any of this relate to anything? Makes sense? What is this, and what are my options?
Plz Help.....I'm dying inside. No car for work...
2001 530i, 160k miles..
Thanks in advance!
Old 09-21-2012, 04:21 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Thanks in advance!
Sounds like you alternator died and you ran the battery down to the point that all of the electrical systems shut down. That's why you got all of the lights.
2000 540/6 Slightly tweeked...everywhere
Old 09-21-2012, 05:07 PM
Mein Auto: Corvette
You may be right...because I jumped it 5 mins ago, going from the trunk, it started. But died again in another 5 mins of idle. Would a bad alternator have such signs.... And what does it have to do with the tranny... And "trans failure" message...???...
Also, no prior warnings....just bang...
Old 09-21-2012, 07:46 PM
Read what I write again, the computers are shutting down, not enough voltage.
Old 09-21-2012, 07:58 PM
GSXRYDER GSXRYDER is offline
Mein Auto: Z4M Coupe, 540i,Silverado
OK so ...
This sounds simple enough...Get New battery, and a new alternator...install both. Start your car and drive it where ever you please...
To make sure what I would do is measure the voltage...measure it with the car sitting not running etc...get the jump keep the car running and check the voltage again...it should be 12.6 or so not running...then running it should go over 14.1 although anything over I think it is 13.6 is considered good...
If you cannot...pull the battery take it to an Advanced Auto or Auto Zone have them check it too...may be you just need an alternator...
Good Luck
99 540i-6 Sport & 07 Z4///M Coupe
Pure
Adrenalin!
Old 09-21-2012, 09:17 PM
Mein Auto: Corvette
Thanks guys... I'm beginning to see some light...
I'm glad it isn't the tranny....
So, meanwhile... how do I lock/unlock the car tonight. It's parked outside. The battery is totally dead, and will take a jump.... but how what do I do to lock it, and IF I lock it.............HOW DO I unlock it, cuz the trunk or the car won't open without a jump, which I can't do, without opening the car.........CATCH 22....
Old 09-21-2012, 09:36 PM
uhhh...
Key in the door...then key in the pass door...and you can always manually unlock the trunk lid by turning the key all the way to the left...
Pure
Adrenalin!
Old 09-21-2012, 11:22 PM
Would a bad alternator have such signs.... And "trans failure" message...
Yup. Ask me how I know:
- One users' example of total electrical failure (AAA towed away) alternator repair (1)
Yup. See above.
- How to open the hood (1) or trunk manually when you have a dead 12v car battery (1) (2) (3) & how to unlock the older E39 if the key is locked inside the trunk (1) (2)
Old 09-22-2012, 12:25 AM
Mein Auto: Corvette
Simple !!! It worked. So I was able to lock all the doors from the inside (passenger door last locked). To open the locks, I'm guessing I'll have to connect the battery from the trunk, and then use the remote to unlock the doors....right ?
Old 09-22-2012, 04:46 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
You realize the driver's door has a key hole right?
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 09-22-2012, 08:33 AM
Mein Auto: Corvette
Good Luck
If it's just the alternator, should I be changing the idler pulley, tensioner, belt, etc with it. I did change these items a couple of years ago, when I did the full cooling overhaul.
Also, where's a good place (inexpensive) to get one. I did a little online search on Ebay Motor parts and came up with this - http://www.ebay.com/sch/Car-Truck-Pa...%2520Aspirated Is this any good....???... (2001 530i)
Old 09-22-2012, 10:06 AM
champaign777's Avatar
so small things can save so much time
http://www.amazon.com/Equus-3721-Bat...=voltage+meter
Old 09-22-2012, 02:55 PM
Mein Auto: Corvette
Yup, but the key won't lock/unlock it. So I had tgo through pssngr door.
Old 09-22-2012, 02:57 PM
Normally you do the whole set, while you're there.
Only you can make the decision if the pulleys and belts and tensioners are relatively new.
- Recommended parts list for a complete belt drive system overhaul (1)
Old 09-22-2012, 03:05 PM
Mein Auto: Corvette
From reading all this, and talking to a friend... I feel it's the charging system. So how do I diagnose if it's the battery, alternator, or both...???
Thanks!
Old 09-22-2012, 07:34 PM
Go to the VERY best of E39 Links and type /battery F3 or /alternator F3.
You'll instantly find, among others:
- How to test a BMW E39 battery & alternator (1)
And, then, to preempt your next question, if it's the battery, see this:
- What is the most recommended battery for your E39 (1) and a simple E39 battery replacement DIY (1)
To preempt your next question, if it's the alternator:
- How to test your generator (1) & how to determine exactly what alternator you have (1) & a DIY for replacing the E39 I6 alternator (1) (2) (3) (4) or E39 V8 alternator (1) (2) (3) (4)
To preempt the question of just replacing the bearings on the alternator:
- Why rebuilding an alternator is preferable to replacing (1) & cn90 DIYs for rebuilding a 1998 air-cooled BMW Bosch alternator (1) (2) or his VW Bosch alternator (1) & cdawg246's quest for materials for a Bosch water cooled alternator rebuild (1) & Aioros' 1999 Valeo Alternator rebuild DIY (1) and his quest for materials (1) & Cn90's explanation of where to get hard-to-get alternator rebuild parts (1) & how to tell from the part number if a replacement alternator is actually rebuilt "by" Bosch (1) & a DIY for replacing the brushes in an (Audi) Valeo alternator (1) & a Bosch alternator bearing replacement from a 1997 MB S600 (1) & from a Range Rover (1).
And, to preempt the question of what else to do while you're there:
Common questions which need to be answered BEFORE you do an alternator and/or drive belt system overhaul:
- 1st: Physically, determine what type of tensioners you have (1)
- 2nd: Physically, determine exactly what alternator you have (1)
- 3rd: Determine which parts you need to buy for a complete drive belt system overhaul (1)
- 4th: Do the alternator and drive belt system DIY (belts, tensioners, pulleys, rollers, alternator) (1)
Old 09-22-2012, 11:13 PM
Mein Auto: Corvette
Bluebee.... You Sir are a wealth of Knowledge........
Thanks!
Old 09-23-2012, 11:14 AM
Albo's Avatar
Albo Albo is offline
Der Ursprüngliche....Albo
Mein Auto: OO=[][]=OO
Thanks!
Bluebee is not a sir.
2003 530i (Alpine White/Sand Beige) - 18x8.5 & 18x9.5 ACS Type II Wheels - BC Racing Coilovers - Eibach Sway Bars - Beastpower Sway Bar Brackets - M-Technic Replica Bumpers - Slimmbones CSL-Style Spltters - Magnaflow Muffler - Dinan CAI - TopSpeed Performance Strut Brace - Carbon Fiber Valve Cover Fascias - Zionsville Autosport Radiator/Fan Kit - Revmax Stage II Torque Converter - AMG Paddle Shifters
Old 09-23-2012, 11:31 PM
Mein Auto: Corvette
Hmmm... you could be more specific....
Old 09-25-2012, 08:28 PM
Mein Auto: Corvette
Okay..... So today I changed a new battery. Everything lights up, as it should, car started up like it should.
However, there's a Red color Battery sign (light) lit up on the dash. Does that mean the new battery is not compatible, or is it something else. I ran let the car idle for a few minutes, and then shut it off so I won't just run into more trouble.....
Suggestions please.... Thanks....
Old 09-25-2012, 08:57 PM
NZ BMW NZ BMW is offline
Mein Auto: 2007 X5
I'm pretty sure that's saying it's not charging the battery, meaning the alternator is dead. You need to get a volt meter and check the charge between the battery terminals while the car is running. Someone will know better than I but you should see say 12V while the car is sitting (engine off) and then when it's running it should be higher say 14 volts?
A mechanic can also check this for you.
Old 09-25-2012, 10:21 PM
Mein Auto: Corvette
Darn it....That's what I thought....Daaaangggg.. Can't believe I burnt out the alternator. Anyways, it was in the back of my mind...it was a possibility. So had bought one while I got the battery today. I was hoping to return it (if not needed). But I guess, I'll be replacing that too. I will do the volt meter check also.
I think I bought 2 new belts (drive belt & accessory belt) about 2 year ago, but didn't put them on...cuz the old belts were still fairly new. I figured since I have them, It's a good idea to put them on. How about any pulleys... should I change any pulleys too, while the mechanic is in working on it anyway. If yes, what kind of pulleys..?
Thanks a million guys... Plz keep it coming...
