Old 09-22-2012, 10:51 AM
Petlover Petlover is offline
Petlover
Mein Auto: BMW 530i
Spark Plugs & Ignition Coils Replacement
Whrn I replace all the Spark Plugs, do I need to replace all the Ignition Coils the same time so as to get the best performance.
Old 09-22-2012, 02:33 PM
poolman poolman is offline
Mein Auto: 525i station wagon
I have over 200k miles on my coils and still getting 30 miles or better out on the road--smooth as silk--I would suggest the NKG Iridium plugs--
Old 09-22-2012, 02:43 PM
Nobody does that as a routine measure.
Replace a single coil only when bad.
The consensus is they either work or they don't.
See also:
- One user's pictorial DIY for replacing the BMW M54 engine spark plugs (1)
Old 09-23-2012, 01:54 AM
Petlover
Mein Auto: BMW 530i
Is Bosch the OEM or NGK the OEM for the Spark Plug ?
I went into 2 different on line webs, one is ECS Tuning, they sell OEM Replacement Spark Plug - it says Genuine BMW Spark Plugs - Bosch for $105.29,
then the other named Auto Barn, they also say Genuine BMW - NGK - Laser Platium Spark Plugs for $8.99 / piece, it totally cost me about $54 which is half price less than the above.
So which one is exactly the OEM, does anyone have the clue?
Old 09-23-2012, 09:03 AM
johnstern's Avatar
johnstern johnstern is offline
Mein Auto: 2000 BMW 528iT/5, S/C
I believe BMW used both NGK and Bosch for OE plugs.
+1 on Poolman's recommendation for NGK Iridium plugs. I've used them for years with great results and zero problems.
BTW-OE plugs are platinum.
Old 09-23-2012, 11:25 AM
Petlover
Mein Auto: BMW 530i
Is NGK Laser Platinum plug higher grade than Iridium Plug?
Is Bosch or NGK last 100k before it is replaced again?
Old 09-23-2012, 12:18 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport, Scuderia
The oem platinum plugs with four prongs are claimed to last 100k. I have found noticeable improvement in fuel economy if replaced at the 60k point. (2 mpg)
You can use whichever you like, and they all seen to work fine, but you will definitely want to replace at 60k miles.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, ST X (KW) coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 09-23-2012, 05:42 PM
JimLev JimLev is offline
Iridium are suppose to last longer than platinum, both are great, get which ever one you want.
NGK's are my favorite, I'm using the iridium plugs for the last 3 years. No problems.
Old 09-26-2012, 10:48 AM
john@eac john@eac is offline
Past Sponsor
Mein Auto: Many
I always try to use what was originally installed in the vehicle. We have the Bosch listed as the OEM replacement and the NGK as a second. Spark Plug "High Power" - Bosch FGR-7-DQP (4417), NGK BKR6EQUP (3199)
http://www.eaceuroparts.com/parts/pa...ge/31/2004/375
Coil paks as needed. I agree with the 60k as the longest that I would run a sparkplug.
Old 09-26-2012, 12:54 PM
eparayno's Avatar
eparayno eparayno is offline
Mein Auto: 2001 530i
When swapping plugs change the coil boots. With the coils they're either good or bad. If yours are fine then no need to change them.
